Зеркало обновления для Avira
Re: Зеркало обновления для Avira
wd1000
Возможно vbase031.vdf.gz не был докачен.
На данный момент проблем нет
26.10.2011
Настроил сбор обновлений для Avira 10 RU
Лезет на внешку
16:20:54 [UPD] [INFO] Downloading of 'http://212.42.102.209/update/wks_avira1 ... nfo.dat.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\wks_avira10\win32\en\pecl\en-us\prodinfo.dat.gz'.
16:20:54 [UPDLIB] [ERROR] Checksum of file 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\wks_avira10\win32\en\pecl\en-us\prodinfo.dat.gz' does not match its description from the control file.
16:20:54 [UPD] [INFO] The control files will be downloaded again.
16:20:54 [UPD] [INFO] Checking whether newer files are available.
16:20:54 [UPD] [INFO] Select update server 'http://89.105.213.18/update'.
16:20:54 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/master.idx' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\master.idx'.
16:20:58 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/wks_avi ... n-pecl.idx' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\wks_avira10-win32-en-pecl.idx'.
16:20:58 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/wks_avi ... cl.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\wks_avira10-win32-en-pecl.info.gz'.
16:20:58 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/webcat- ... nt.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\webcat-common-int.info.gz'.
16:20:59 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/vdf.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\vdf.info.gz'.
16:20:59 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/rdf-common-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\rdf-common-int.info.gz'.
16:20:59 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/ave2-win32-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\ave2-win32-int.info.gz'.
16:20:59 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/wks_avi ... fo.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\wks_avira10-win32-en-pecl-info.info.gz'.
16:20:59 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/hips-win32-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\hips-win32-int.info.gz'.
16:20:59 [UPD] [INFO] Downloading of 'http://89.105.213.18/update/idx/detrep- ... nt.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\detrep-win32-int.info.gz'.
16:21:00 [UPD] [INFO] Compare local files with status of update server
Скорее всего, запланированный сбор обновлений совпал с обновлением файлов на сервере Avira. Контрольная сумма файла prodinfo.dat.gz не совпала и программа обновления переключилась на официальный сервер.
В ближайшее время проблема будет устранена.
vernu
Благодарю за проявленную бдительность.
vernu
Faust
Это вам спасибо за зеркало...
vernu
Всегда пожалуйста.
Всем
Забыл сообщить, что в прошлый раз воспользовался случаем и настроил сбор обновлений для Avira 12 RU.
Проверил на себе - работает. Если понадобится 12 EN - сообщите. Так же сообщите какие info.gz и idx файлы она требует при обновлении.
Всегда пожалуйста.
Всем
Faust
думается будет нужно, только вот кто бы список файла скинул...
Конечно, можно попробовать заменить в путях "ru" на "en", но боюсь, что это не даст 100%. Сам лог принесёт больше пользы.
Настроил сбор обновлений для Avira 13 EN. Как обычно, проверил на себе. Обновился вроде без ошибок.
