проблема с мышем и клавай
Re: проблема с мышем и клавай
З.Ы. могу скинуть свой. Там нужно будет только дровину на видюху переписать.
- ИМХО
- Бытовой хакер
- ОС: Maui 2
BaHbKa писал(а):[spoiler]xorg.conf я не нашел
вот всё что похоже:
Xorg.0.log
[spoiler]X.Org X Server 1.6.5
Release Date: 2009-10-11
X Protocol Version 11, Revision 0
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux linux-19qv 2.6.31.5-0.1-default #1 SMP 2009-10-26 15:49:03 +0100 i686
Build Date: 02 November 2009 12:05:39PM
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 16 20:39:38 2010
(II) Loader magic: 0x3ac0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(++) using VT number 7
(--) PCI:*(0:1:0:0) 10de0000:0000 rev 161, Mem @ 0xde000000/16777216, 0xe0000000/134217728, BIOS @ 0x????????/131072
(==) Using default built-in configuration (48 lines)
(==) --- Start of built-in configuration ---
Section "Device"
Identifier "Builtin Default nvidia Device 0"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Builtin Default nvidia Screen 0"
Device "Builtin Default nvidia Device 0"
EndSection
Section "Device"
Identifier "Builtin Default nouveau Device 0"
Driver "nouveau"
EndSection
Section "Screen"
Identifier "Builtin Default nouveau Screen 0"
Device "Builtin Default nouveau Device 0"
EndSection
Section "Device"
Identifier "Builtin Default nv Device 0"
Driver "nv"
EndSection
Section "Screen"
Identifier "Builtin Default nv Screen 0"
Device "Builtin Default nv Device 0"
EndSection
Section "Device"
Identifier "Builtin Default fbdev Device 0"
Driver "fbdev"
EndSection
Section "Screen"
Identifier "Builtin Default fbdev Screen 0"
Device "Builtin Default fbdev Device 0"
EndSection
Section "Device"
Identifier "Builtin Default vesa Device 0"
Driver "vesa"
EndSection
Section "Screen"
Identifier "Builtin Default vesa Screen 0"
Device "Builtin Default vesa Device 0"
EndSection
Section "ServerLayout"
Identifier "Builtin Default Layout"
Screen "Builtin Default nvidia Screen 0"
Screen "Builtin Default nouveau Screen 0"
Screen "Builtin Default nv Screen 0"
Screen "Builtin Default fbdev Screen 0"
Screen "Builtin Default vesa Screen 0"
EndSection
(==) --- End of built-in configuration ---
(==) ServerLayout "Builtin Default Layout"
(**) |-->Screen "Builtin Default nvidia Screen 0" (0)
(**) | |-->Monitor "<default monitor>"
(**) | |-->Device "Builtin Default nvidia Device 0"
(==) No monitor specified for screen "Builtin Default nvidia Screen 0".
Using a default monitor configuration.
(**) |-->Screen "Builtin Default nouveau Screen 0" (1)
(**) | |-->Device "Builtin Default nouveau Device 0"
(==) No monitor specified for screen "Builtin Default nouveau Screen 0".
(**) |-->Screen "Builtin Default nv Screen 0" (2)
(**) | |-->Device "Builtin Default nv Device 0"
(==) No monitor specified for screen "Builtin Default nv Screen 0".
(**) |-->Screen "Builtin Default fbdev Screen 0" (3)
(**) | |-->Device "Builtin Default fbdev Device 0"
(==) No monitor specified for screen "Builtin Default fbdev Screen 0".
(**) |-->Screen "Builtin Default vesa Screen 0" (4)
(**) | |-->Device "Builtin Default vesa Device 0"
(==) No monitor specified for screen "Builtin Default vesa Screen 0".
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/TTF/" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/OTF" does not exist.
(==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/truetype/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled
(==) ModulePath set to "/usr/lib/xorg/modules/updates,/usr/lib/xorg/modules"
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(II) Open ACPI successful (/var/run/acpid.socket)
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules//extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules//extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules//extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules//extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules//extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules//extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(WW) Warning, couldn't open module nvidia
(II) UnloadModule: "nvidia"
(EE) Failed to load module "nvidia" (module does not exist, 0)
(II) LoadModule: "nouveau"
(WW) Warning, couldn't open module nouveau
(II) UnloadModule: "nouveau"
(EE) Failed to load module "nouveau" (module does not exist, 0)
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules//drivers/nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 2.1.14
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 5.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules//drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 0.4.1
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules//drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 2.2.1
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro NVS 440, Quadro FX 550,
Quadro FX 550, Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 7100 GS,
GeForce 6800, GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT,
GeForce 6200, GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7350 LE,
GeForce 7300 LE, GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300,
GeForce Go 7400, GeForce Go 7400 GS, Quadro NVS 110M,
Quadro NVS 120M, Quadro FX 350M, GeForce 7500 LE, Quadro FX 350,
GeForce 7300 GS, GeForce 7650 GS, GeForce 7600 GT, GeForce 7600 GS,
GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT, GeForce Go 7700,
GeForce Go 7600, GeForce Go 7600 GT, Quadro NVS 300M,
GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560, GeForce 7900 GTX,
GeForce 7900 GT, GeForce 7900 GS, GeForce 7950 GX2, GeForce 7950 GX2,
GeForce 7950 GT, GeForce Go 7950 GTX, GeForce Go 7900 GS,
GeForce Go 7900 GTX, Quadro FX 2500M, Quadro FX 1500M,
Quadro FX 5500, Quadro FX 3500, Quadro FX 1500, Quadro FX 4500 X2,
GeForce 6150, GeForce 6150 LE, GeForce 6100, GeForce Go 6150,
Quadro NVS 210S / NVIDIA GeForce 6150LE, GeForce Go 6100,
GeForce 6150SE, GeForce 6100 nForce 405, GeForce 6100 nForce 400,
GeForce 6100 nForce 420, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8600 GT, GeForce 8600 GS, GeForce 8400 GS,
GeForce 9500M GS, GeForce 8600M GT, GeForce 9650M GS,
GeForce 8700M GT, Quadro FX 370, Quadro NVS 320M, Quadro FX 570M,
Quadro FX 1600M, Quadro FX 570, Quadro FX 1700, GeForce 8400 SE,
GeForce 8500 GT, GeForce 8400 GS, GeForce 8300 GS, GeForce 8400 GS,
GeForce 8600M GS, GeForce 8400M GT, GeForce 8400M GS,
GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M, Quadro NVS 135M,
GeForce 9400 GT, Quadro FX 360M, GeForce 9300M G, Quadro NVS 290,
GeForce GTX 295, GeForce GTX 280, GeForce GTX 260, GeForce GTX 285,
Quadro CX, Quadro FX 5800, Quadro FX 4800, Quadro FX 3800,
GeForce 8800 GTS 512, GeForce 9800 GT, GeForce 8800 GT,
GeForce 9800 GX2, GeForce 9800 GT, GeForce 8800 GS,
GeForce 9800M GTX, GeForce 8800M GTS, GeForce 9800M GT,
GeForce 8800M GTX, GeForce 8800 GS, GeForce 9600 GSO,
GeForce 8800 GT, GeForce 9800 GTX, GeForce 9800 GTX+,
GeForce 9800 GT, GeForce GTS 250, GeForce 9800M GTX, Quadro FX 3700,
Quadro FX 3600M, Quadro FX 3700M, GeForce 9600 GT, GeForce 9600 GS,
GeForce 9600 GSO 512, GeForce GT 130, GeForce GT 140,
GeForce 9800M GTS, GeForce 9700M GTS, GeForce 9800M GS,
GeForce 9800M GTS, Quadro FX 1800, Quadro FX 2700M, GeForce 9500 GT,
GeForce 9400 GT, GeForce 9500 GT, GeForce GT 120, GeForce 9600M GT,
GeForce 9600M GS, GeForce 9600M GT, GeForce 9700M GT,
GeForce 9500M G, GeForce 9650M GT, GeForce 9500 GT, Quadro FX 380,
Quadro FX 580, Quadro FX 770M, GeForce 9300 GE, GeForce 9300 GS,
GeForce 8400 GS, GeForce 9300M GS, GeForce G100, GeForce 9200M GS,
GeForce 9300M GS, Quadro NVS 150M, Quadro NVS 160M, Quadro NVS 420,
Quadro FX 370 LP, Quadro NVS 450, Quadro NVS 295
(II) FBDEV: driver for framebuffer: fbdev
(II) VESA: driver for VESA chipsets: vesa
(II) Primary Device is: PCI 01@00:00:0
(--) NV: Found NVIDIA GeForce FX 5200 at 01@00:00:0
(WW) Falling back to old probe method for fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 0.0.2
(WW) Falling back to old probe method for vesa
(II) resource ranges after probing:
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Chipset: "GeForce FX 5200"
(II) NV(0): Creating default Display subsection in Screen section
"Builtin Default nv Screen 0" for depth/fbbpp 24/32
(==) NV(0): Depth 24, (--) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 0.1.0
(==) NV(0): Using HW cursor
(--) NV(0): Linear framebuffer at 0xE0000000
(--) NV(0): MMIO registers at 0xDE000000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for analog device on output A...
(--) NV(0): ...found one
(II) NV(0): Probing for analog device on output B...
(--) NV(0): ...can't find one
(II) NV(0): Probing for EDID on I2C bus A...
(II) NV(0): I2C device "DDC:E-EDID segment register" registered at address 0x60.
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: GSM Model: 4366 Serial#: 198671
(II) NV(0): Year: 2004 Week: 8
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) NV(0): Signal levels configurable
(II) NV(0): Sync: Separate
(II) NV(0): Max Image Size [cm]: horiz.: 33 vert.: 24
(II) NV(0): Gamma: 2.81
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): First detailed timing is preferred mode
(II) NV(0): redX: 0.636 redY: 0.327 greenX: 0.278 greenY: 0.600
(II) NV(0): blueX: 0.145 blueY: 0.064 whiteX: 0.283 whiteY: 0.298
(II) NV(0): Supported established timings:
(II) NV(0): 720x400@70Hz
(II) NV(0): 720x400@88Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@67Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@56Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@87Hz (interlaced)
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): 1152x870@75Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported standard timings:
(II) NV(0): #0: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) NV(0): #1: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) NV(0): #2: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) NV(0): #3: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) NV(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): #5: hsize: 1280 vsize 960 refresh: 70 vid: 19073
(II) NV(0): Supported detailed timing:
(II) NV(0): clock: 94.5 MHz Image Size: 310 x 230 mm
(II) NV(0): h_active: 1024 h_sync: 1072 h_sync_end 1168 h_blank_end 1376 h_border: 0
(II) NV(0): v_active: 768 v_sync: 769 v_sync_end 772 v_blanking: 808 v_border: 0
(II) NV(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 71 kHz, PixClock max 110 MHz
(II) NV(0): Monitor name: T710BH
(II) NV(0): EDID (in hex):
(II) NV(0): 00ffffffffffff001e6d66430f080300
(II) NV(0): 080e0103182118b5eaf629a253479925
(II) NV(0): 10484cfffe803159714f455961598180
(II) NV(0): 814a01010101ea240060410028303060
(II) NV(0): 130036e61000001e000000fd0032a01e
(II) NV(0): 470b000a202020202020000000fc0054
(II) NV(0): 37313042480a202020202020000000fc
(II) NV(0): 000a2020202020202020202020200043
(II) NV(0): Probing for EDID on I2C bus B...
(II) NV(0): ... none found
(--) NV(0): CRTC 0 appears to have a CRT attached
(II) NV(0): Using CRT on CRTC 0
(II) NV(0): EDID vendor "GSM", prod id 17254
(II) NV(0): Using EDID range info for horizontal sync
(II) NV(0): Using EDID range info for vertical refresh
(II) NV(0): Printing DDC gathered Modelines:
(II) NV(0): Modeline "1024x768"x0.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(II) NV(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) NV(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) NV(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) NV(0): Modeline "720x400"x0.0 35.50 720 738 846 900 400 421 423 449 -hsync -vsync (39.4 kHz)
(II) NV(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) NV(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) NV(0): Modeline "1024x768"x0.0 44.90 1024 1032 1208 1264 768 768 772 817 interlace +hsync +vsync (35.5 kHz)
(II) NV(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) NV(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) NV(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) NV(0): Modeline "640x480"x0.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) NV(0): Modeline "800x600"x0.0 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(II) NV(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) NV(0): Modeline "1280x960"x70.0 120.84 1280 1368 1504 1728 960 961 964 999 -hsync +vsync (69.9 kHz)
(--) NV(0): VideoRAM: 131072 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): <default monitor>: Using hsync range of 30.00-71.00 kHz
(II) NV(0): <default monitor>: Using vrefresh range of 50.00-160.00 Hz
(II) NV(0): <default monitor>: Using maximum pixel clock of 110.00 MHz
(II) NV(0): Estimated virtual size for aspect ratio 1.3750 is 1280x960
(II) NV(0): Clock range: 12.00 to 350.00 MHz
(II) NV(0): Not using default mode "1280x960" (hsync out of range)
(II) NV(0): Not using default mode "640x480" (hsync out of range)
(II) NV(0): Not using default mode "1280x1024" (height too large for virtual size)
(II) NV(0): Not using default mode "640x512" (hsync out of range)
(II) NV(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "800x600" (hsync out of range)
(II) NV(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) NV(0): Not using default mode "896x672" (hsync out of range)
(II) NV(0): Not using default mode "1856x1392" (width too large for virtual size)
(II) NV(0): Not using default mode "928x696" (hsync out of range)
(II) NV(0): Not using default mode "1920x1440" (width too large for virtual size)
(II) NV(0): Not using default mode "960x720" (hsync out of range)
(II) NV(0): Not using default mode "1400x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "700x525" (hsync out of range)
(II) NV(0): Not using default mode "2048x1536" (width too large for virtual size)
(II) NV(0): Not using default mode "1024x768" (hsync out of range)
(II) NV(0): Not using driver mode "1280x1024" (height too large for virtual size)
(II) NV(0): Not using driver mode "1280x960" (mode clock too high)
(--) NV(0): Virtual size is 1280x960 (pitch 1280)
(**) NV(0): *Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
(**) NV(0): *Driver mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(**) NV(0): *Default mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(**) NV(0): *Driver mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(II) NV(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(**) NV(0): *Driver mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(**) NV(0): *Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(**) NV(0): *Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(**) NV(0): *Driver mode "1024x768": 44.9 MHz, 35.5 kHz, 86.9 Hz (I)
(II) NV(0): Modeline "1024x768"x86.9 44.90 1024 1032 1208 1264 768 768 772 817 interlace +hsync +vsync (35.5 kHz)
(**) NV(0): *Default mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(**) NV(0): *Default mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz
(**) NV(0): *Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NV(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NV(0): *Default mode "1024x768": 44.9 MHz, 35.5 kHz, 86.9 Hz (I)
(II) NV(0): Modeline "1024x768"x86.9 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz)
(**) NV(0): *Driver mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(**) NV(0): *Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NV(0): *Driver mode "800x600": 56.2 MHz, 53.7 kHz, 85.1 Hz
(II) NV(0): Modeline "800x600"x85.1 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(**) NV(0): *Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(**) NV(0): *Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(**) NV(0): *Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(**) NV(0): *Driver mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(**) NV(0): *Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) NV(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(**) NV(0): *Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NV(0): *Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NV(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NV(0): *Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NV(0): *Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz)
(**) NV(0): *Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz)
(**) NV(0): *Driver mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(II) NV(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(**) NV(0): *Driver mode "640x480": 30.2 MHz, 35.0 kHz, 66.7 Hz
(II) NV(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(**) NV(0): *Driver mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz
(II) NV(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(**) NV(0): *Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(**) NV(0): *Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NV(0): *Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) NV(0): *Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz
(**) NV(0): *Driver mode "720x400": 35.5 MHz, 39.4 kHz, 87.8 Hz
(II) NV(0): Modeline "720x400"x87.8 35.50 720 738 846 900 400 421 423 449 -hsync -vsync (39.4 kHz)
(**) NV(0): *Driver mode "720x400": 28.3 MHz, 31.5 kHz, 70.1 Hz
(II) NV(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(**) NV(0): *Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
(II) NV(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz)
(**) NV(0): *Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
(**) NV(0): *Default mode "512x384": 47.2 MHz, 68.7 kHz, 85.0 Hz (D)
(II) NV(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz)
(**) NV(0): *Default mode "512x384": 39.4 MHz, 60.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz)
(**) NV(0): *Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz)
(**) NV(0): *Default mode "512x384": 22.4 MHz, 35.5 kHz, 86.6 Hz (D)
(II) NV(0): Modeline "512x384"x86.6 22.45 512 516 604 632 384 384 388 409 interlace doublescan +hsync +vsync (35.5 kHz)
(**) NV(0): *Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz)
(**) NV(0): *Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz)
(**) NV(0): *Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) NV(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz)
(**) NV(0): *Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz)
(**) NV(0): *Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz)
(**) NV(0): *Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
(II) NV(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz)
(**) NV(0): *Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz)
(**) NV(0): *Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(II) NV(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz)
(**) NV(0): *Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz)
(**) NV(0): *Default mode "360x200": 17.8 MHz, 37.9 kHz, 85.0 Hz (D)
(II) NV(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "320x175": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz)
(**) NV(0): Display dimensions: (330, 240) mm
(**) NV(0): DPI set to (98, 101)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.2.1
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules//drivers/fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) UnloadModule: "vesa"
(II) Unloading /usr/lib/xorg/modules//drivers/vesa_drv.so
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
(II) NV(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) XKB: reuse xkmfile /var/lib/xkb/compiled/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
(EE) config/hal: couldn't initialise context: unknown error (null)[/spoiler]
[b]20.xorg-x11-driver-video
[spoiler]vendor.id pci 0x10de
&device.id pci 0x016a
+device.name GeForce 7100 GS
+driver.xfree 4|nv
&device.id pci 0x0401
+device.name GeForce 8600 GT
+driver.xfree 4|nv
&device.id pci 0x0424
+device.name GeForce 8400 GS
+driver.xfree 4|nv
&device.id pci 0x0602
+device.name GeForce 8800 GT
+driver.xfree 4|nv
&device.id pci 0x0606
+device.name GeForce 8800 GS
+driver.xfree 4|nv
&device.id pci 0x060D
+driver.xfree 4|nv
&device.id pci 0x0611
+driver.xfree 4|nv
&device.id pci 0x0640
+device.name GeForce 9500 GT
+driver.xfree 4|nv
&device.id pci 0x0403
+device.name GeForce 8600 GS
+driver.xfree 4|nv
&device.id pci 0x042C
+device.name GeForce 9400 GT
+driver.xfree 4|nv
&device.id pci 0x0613
+device.name GeForce 9800 GTX+
+driver.xfree 4|nv
&device.id pci 0x0614
+driver.xfree 4|nv
&device.id pci 0x0623
+device.name GeForce 9600 GS
+driver.xfree 4|nv
&device.id pci 0x0628
+device.name GeForce 9800M GTS
+driver.xfree 4|nv
&device.id pci 0x062A
+device.name GeForce 9700M GTS
+driver.xfree 4|nv
&device.id pci 0x062C
+driver.xfree 4|nv
&device.id pci 0x06E1
+device.name GeForce 9300 GS
+driver.xfree 4|nv
&device.id pci 0x06EA
+device.name Quadro NVS 150M
+driver.xfree 4|nv
&device.id pci 0x06EB
+device.name Quadro NVS 160M
+driver.xfree 4|nv
&device.id pci 0x05e1
+device.name GeForce GTX 280
+driver.xfree 4|nv
&device.id pci 0x05e2
+device.name GeForce GTX 260
+driver.xfree 4|nv
&device.id pci 0x0408
+device.name GeForce 9650M GS
+driver.xfree 4|nv
&device.id pci 0x042e
+device.name GeForce 9300M G
+driver.xfree 4|nv
&device.id pci 0x0647
+device.name GeForce 9600M GT
+driver.xfree 4|nv
&device.id pci 0x0648
+device.name GeForce 9600M GS
+driver.xfree 4|nv
&device.id pci 0x0649
+driver.xfree 4|nv
&device.id pci 0x064b
+device.name GeForce 9500M G
+driver.xfree 4|nv
&device.id pci 0x06e5
+device.name GeForce 9300M GS
+driver.xfree 4|nv
&device.id pci 0x06e8
+device.name GeForce 9200M GS
+driver.xfree 4|nv
&device.id pci 0x06e9
+driver.xfree 4|nv
&device.id pci 0x01d1
+device.name GeForce 7300 LE
+driver.xfree 4|vesa
&device.id pci 0x0242
&subvendor.id pci 0x1462
&subdevice.id pci 0x7207
+device.name GeForce 6100 Micro-Star
+driver.xfree 4|nv
&device.id pci 0x0610
+device.name GeForce 9600 GSO
+driver.xfree 4|nv
&device.id pci 0x0612
+device.name GeForce 9800GTX
+driver.xfree 4|nv
&device.id pci 0x0405
+device.name GeForce 9500M GS
+driver.xfree 4|nv
&device.id pci 0x0420
+device.name GeForce 8400 SE
+driver.xfree 4|nv
&device.id pci 0x0600
+device.name GeForce 8800 GTS 512
+driver.xfree 4|nv
&device.id pci 0x0604
+device.name GeForce 9800 GX2
+driver.xfree 4|nv
&device.id pci 0x0609
+device.name GeForce 8800M GTS
+driver.xfree 4|nv
&device.id pci 0x060c
+device.name GeForce 8800M GTX
+driver.xfree 4|nv
&device.id pci 0x061c
+device.name Quadro FX 3600M
+driver.xfree 4|nv
&device.id pci 0x00f6
+device.name GeForce 6800 GS
+driver.xfree 4|nv
&device.id pci 0x014a
+device.name Quadro NVS 440
+driver.xfree 4|nv
+driver.xfree 4|nv
&device.id pci 0x061a
+device.name Quadro FX 3700
+driver.xfree 4|nv
&device.id pci 0x0622
+device.name GeForce 9600 GT
+driver.xfree 4|nv
vendor.id pci 0x8086
&device.id pci 0x2A42
+device.name Mobile IntelВ® GM45 Express Chipset
+driver.xfree 4|intel
+driver.xfree 4|intel|3d
&device.id pci 0x2E02
+device.name Intel Integrated Graphics Device
&device.id pci 0x2E22
+device.name G45/G43
&device.id pci 0x2E12
+device.name Q45/Q43
vendor.id pci 0x1002
&device.id pci 0x4756
+device.name 3D Rage IIC 215IIC
+driver.xfree 4|ati
vendor.id pci 0x102b
&device.id pci 0x0530
+device.name G200 VE
+driver.xfree 4|mga
&device.id pci 0x0532
+device.name G200 eW
+driver.xfree 4|mga
&device.id pci 014A
+driver.xfree 4|nv
&device.id pci 01D0
+device.name GeForce 7350 LE
+driver.xfree 4|nv
&device.id pci 0390
+device.name GeForce 7650 GS
+driver.xfree 4|nv
&device.id pci 0293
+device.name GeForce 7950 GX2
+driver.xfree 4|nv
&device.id pci 0294
+driver.xfree 4|nv
&device.id pci 0295
+device.name GeForce 7950 GT
+driver.xfree 4|nv
&device.id pci 0297
+device.name GeForce Go 7950 GTX
+driver.xfree 4|nv
&device.id pci 0245
+device.name Quadro NVS 210S / NVIDIA GeForce 6150LE
+driver.xfree 4|nv
&device.id pci 03D0
+device.name GeForce 6150SE
+driver.xfree 4|nv
&device.id pci 03D1
+device.name GeForce 6100 nForce 405
+driver.xfree 4|nv
&device.id pci 03D2
+device.name GeForce 6100 nForce 400
+driver.xfree 4|nv
&device.id pci 03D5
+device.name GeForce 6100 nForce 420
+driver.xfree 4|nv
&device.id pci 05E0
+device.name GeForce GTX 295
+driver.xfree 4|nv
&device.id pci 05E3
+device.name GeForce GTX 285
+driver.xfree 4|nv
&device.id pci 05F9
+device.name Quadro CX
+driver.xfree 4|nv
&device.id pci 05FD
+device.name Quadro FX 5800
+driver.xfree 4|nv
&device.id pci 05FE
+device.name Quadro FX 4800
+driver.xfree 4|nv
&device.id pci 05FF
+device.name Quadro FX 3800
+driver.xfree 4|nv
&device.id pci 0601
+driver.xfree 4|nv
&device.id pci 0605
+driver.xfree 4|nv
&device.id pci 0608
+device.name GeForce 9800M GTX
+driver.xfree 4|nv
&device.id pci 060B
+driver.xfree 4|nv
&device.id pci 0615
+device.name GeForce GTS 250
+driver.xfree 4|nv
&device.id pci 0617
+driver.xfree 4|nv
&device.id pci 061E
+device.name Quadro FX 3700M
+driver.xfree 4|nv
&device.id pci 0625
+device.name GeForce 9600 GSO 512
+driver.xfree 4|nv
&device.id pci 0626
+device.name GeForce GT 130
+driver.xfree 4|nv
&device.id pci 0627
+device.name GeForce GT 140
+driver.xfree 4|nv
&device.id pci 062B
+device.name GeForce 9800M GS
+driver.xfree 4|nv
&device.id pci 0638
+device.name Quadro FX 1800
+driver.xfree 4|nv
&device.id pci 063A
+device.name Quadro FX 2700M
+driver.xfree 4|nv
&device.id pci 0641
+driver.xfree 4|nv
&device.id pci 0643
+driver.xfree 4|nv
&device.id pci 0646
+device.name GeForce GT 120
+driver.xfree 4|nv
&device.id pci 064A
+driver.xfree 4|nv
&device.id pci 064C
+device.name GeForce 9650M GT
+driver.xfree 4|nv
&device.id pci 0656
+driver.xfree 4|nv
&device.id pci 0658
+driver.xfree 4|nv
&device.id pci 0659
+driver.xfree 4|nv
&device.id pci 065C
+device.name Quadro FX 770M
+driver.xfree 4|nv
&device.id pci 06E0
+device.name GeForce 9300 GE
+driver.xfree 4|nv
&device.id pci 06E6
+device.name GeForce G100
+driver.xfree 4|nv
&device.id pci 06F8
+device.name Quadro NVS 420
+driver.xfree 4|nv
&device.id pci 06F9
+device.name Quadro FX 370 LP
+driver.xfree 4|nv
&device.id pci 06FA
+device.name Quadro NVS 450
+driver.xfree 4|nv
&device.id pci 06FD
+device.name Quadro NVS 295
+driver.xfree 4|nv[/spoiler]
20.xorg-x11-driver-video-radeonhd
[spoiler]vendor.id pci 0x1002
&device.id pci 0x7100
+device.name Radeon X1800
+driver.xfree 4|radeonhd
&device.id pci 0x7101
+device.name Mobility Radeon X1800 XT
&device.id pci 0x7102
&device.id pci 0x7103
+device.name Mobility FireGL V7200
&device.id pci 0x7104
+device.name FireGL V7200
&device.id pci 0x7105
+device.name FireGL V5300
&device.id pci 0x7106
+device.name Mobility FireGL V7100
&device.id pci 0x7108
&device.id pci 0x7109
&device.id pci 0x710A
&device.id pci 0x710B
&device.id pci 0x710C
&device.id pci 0x710E
+device.name FireGL V7300
&device.id pci 0x710F
+device.name FireGL V7350
&device.id pci 0x7140
+device.name Radeon X1600/X1550
&device.id pci 0x7141
+device.name RV505
&device.id pci 0x7142
+device.name Radeon X1300/X1550
&device.id pci 0x7143
+device.name Radeon X1550
&device.id pci 0x7144
+device.name M54-GL
&device.id pci 0x7145
+device.name Mobility Radeon X1400
&device.id pci 0x7146
&device.id pci 0x7147
+device.name Radeon X1550 64-bit
&device.id pci 0x7149
+device.name Mobility Radeon X1300
&device.id pci 0x714A
&device.id pci 0x714B
&device.id pci 0x714C
&device.id pci 0x714D
&device.id pci 0x714E
&device.id pci 0x714F
+device.name RV505
&device.id pci 0x7151
+device.name RV505
&device.id pci 0x7152
+device.name FireGL V3300
&device.id pci 0x7153
+device.name FireGL V3350
&device.id pci 0x715E
&device.id pci 0x715F
&device.id pci 0x7180
&device.id pci 0x7181
&device.id pci 0x7183
&device.id pci 0x7186
+device.name Mobility Radeon X1450
&device.id pci 0x7187
&device.id pci 0x7188
+device.name Mobility Radeon X2300
&device.id pci 0x718A
&device.id pci 0x718B
+device.name Mobility Radeon X1350
&device.id pci 0x718C
&device.id pci 0x718D
&device.id pci 0x718F
&device.id pci 0x7193
&device.id pci 0x7196
&device.id pci 0x719B
+device.name FireMV 2250
&device.id pci 0x719F
&device.id pci 0x71C0
&device.id pci 0x71C1
+device.name Radeon X1650
&device.id pci 0x71C2
&device.id pci 0x71C3
&device.id pci 0x71C4
+device.name Mobility FireGL V5200
+driver.xfree 4|radeonhd|3d
&device.id pci 0x71C5
+device.name Mobility Radeon X1600
&device.id pci 0x71C6
&device.id pci 0x71C7
&device.id pci 0x71CD
&device.id pci 0x71CE
+device.name Radeon X1300 XT/X1600 Pro
&device.id pci 0x71D2
+device.name FireGL V3400
&device.id pci 0x71D4
+device.name Mobility FireGL V5250
&device.id pci 0x71D5
+device.name Mobility Radeon X1700
&device.id pci 0x71D6
+device.name Mobility Radeon X1700 XT
&device.id pci 0x71DA
+device.name FireGL V5200
&device.id pci 0x71DE
&device.id pci 0x7200
+device.name Radeon X2300HD
&device.id pci 0x7210
+device.name Mobility Radeon HD 2300
&device.id pci 0x7211
&device.id pci 0x7240
+device.name Radeon X1950
&device.id pci 0x7243
+device.name Radeon X1900
&device.id pci 0x7244
&device.id pci 0x7245
&device.id pci 0x7246
&device.id pci 0x7247
&device.id pci 0x7248
&device.id pci 0x7249
&device.id pci 0x724A
&device.id pci 0x724B
&device.id pci 0x724C
&device.id pci 0x724D
&device.id pci 0x724E
+device.name AMD Stream Processor
&device.id pci 0x724F
&device.id pci 0x7280
&device.id pci 0x7281
+device.name RV560
&device.id pci 0x7283
+device.name RV560
&device.id pci 0x7284
+device.name Mobility Radeon X1900
&device.id pci 0x7287
+device.name RV560
&device.id pci 0x7288
+device.name Radeon X1950 GT
&device.id pci 0x7289
+device.name RV570
&device.id pci 0x728B
+device.name RV570
&device.id pci 0x728C
+device.name ATI FireGL V7400
&device.id pci 0x7290
+device.name RV560
&device.id pci 0x7291
&device.id pci 0x7293
&device.id pci 0x7297
+device.name RV560
&device.id pci 0x791E
+device.name Radeon X1200
&device.id pci 0x791F
&device.id pci 0x793F
+device.name Radeon Xpress 1200
&device.id pci 0x7941
&device.id pci 0x7942
+device.name Radeon Xpress 1200 (M)
&device.id pci 0x796C
+device.name RS740
&device.id pci 0x796D
+device.name RS740M
&device.id pci 0x796E
+device.name ATI Radeon 2100 RS740
&device.id pci 0x796F
+device.name RS740M
&device.id pci 0x9400
+device.name Radeon HD 2900 XT
&device.id pci 0x9401
&device.id pci 0x9402
&device.id pci 0x9403
+device.name Radeon HD 2900 Pro
&device.id pci 0x9405
+device.name Radeon HD 2900 GT
&device.id pci 0x940A
+device.name FireGL V8650
&device.id pci 0x940B
+device.name FireGL V8600
&device.id pci 0x940F
+device.name FireGL V7600
&device.id pci 0x9440
+device.name ATI Radeon 4800 Series
&device.id pci 0x9441
+device.name ATI Radeon 4870 X2
&device.id pci 0x9442
&device.id pci 0x9443
+device.name ATI Radeon 4850 X2
&device.id pci 0x9444
+device.name Everest ATI FirePro Graphics Accelerator
&device.id pci 0x9446
+device.name K2 ATI FirePro Graphics Accelerator
&device.id pci 0x9447
+device.name ATI FirePro V8700 Duo
&device.id pci 0x944A
+device.name ATI MOBILITY RADEON HD 4850
&device.id pci 0x944B
+device.name ATI MOBILITY RADEON HD 4850 X2
&device.id pci 0x944C
+device.name ATI RADEON HD 4800 Series
&device.id pci 0x944E
+device.name RV770
&device.id pci 0x944F
+device.name RHD_DEVICE_MATCH( 0x944F, RHD_R700 ),
&device.id pci 0x9450
+device.name AMD FireStream 9270
&device.id pci 0x9452
+device.name AMD FireStream 9250
&device.id pci 0x9456
+device.name Denali ATI FirePro Graphics Accelerator
&device.id pci 0x945A
+device.name ATI MOBILITY RADEON HD 4870
&device.id pci 0x945B
+device.name M98
&device.id pci 0x9460
+device.name RV790
&device.id pci 0x9462
+device.name RV790
&device.id pci 0x946A
+device.name M98
&device.id pci 0x946B
+device.name M98
&device.id pci 0x947A
+device.name M98
&device.id pci 0x947B
+device.name M98
&device.id pci 0x9480
+device.name ATI MOBILITY RADEON HD 4650
&device.id pci 0x9487
+device.name RV730
&device.id pci 0x9488
+device.name ATI MOBILITY RADEON HD 4670
&device.id pci 0x9489
+device.name M96M GL
&device.id pci 0x948F
+device.name RV730
&device.id pci 0x9490
+device.name ATI RADEON HD 4670
&device.id pci 0x9491
+device.name ATI RADEON E4600
&device.id pci 0x9495
+device.name ATI Radeon HD 4600 Series
&device.id pci 0x9498
+device.name ATI RADEON HD 4650
&device.id pci 0x949C
+device.name ATI FirePro V7750
&device.id pci 0x949E
+device.name ATI FirePro V5700
&device.id pci 0x949F
+device.name ATI FirePro V3750
&device.id pci 0x94A0
+device.name Mobility Radeon HD 4830
&device.id pci 0x94A1
+device.name Mobility Radeon HD 4850
&device.id pci 0x94A3
+device.name ATI FirePro M7740
&device.id pci 0x94B1
+device.name RV740
&device.id pci 0x94B3
+device.name Radeon HD 4770
&device.id pci 0x94B4
+device.name Radeon HD 4700 Series
&device.id pci 0x94B5
&device.id pci 0x94B9
+device.name ATI FirePro M5750
&device.id pci 0x94C0
+device.name RV610
&device.id pci 0x94C1
+device.name Radeon HD 2400 XT
&device.id pci 0x94C3
+device.name Radeon HD 2400 Pro
&device.id pci 0x94C4
+device.name ATI Radeon HD 2400 PRO AGP
&device.id pci 0x94C5
+device.name FireGL V4000
&device.id pci 0x94C6
+device.name RV610
&device.id pci 0x94C7
+device.name ATI Radeon HD 2350
&device.id pci 0x94C8
+device.name Mobility Radeon HD 2400 XT
&device.id pci 0x94C9
&device.id pci 0x94CB
+device.name ATI RADEON E2400
&device.id pci 0x94CC
&device.id pci 0x94CD
+device.name ATI FireMV 2260
&device.id pci 0x9500
+device.name RV670
&device.id pci 0x9501
+device.name ATI Radeon HD3870
&device.id pci 0x9504
+device.name ATI Mobility Radeon HD 3850
&device.id pci 0x9505
+device.name ATI Radeon HD3850
&device.id pci 0x9506
+device.name ATI Mobility Radeon HD 3850 X2
&device.id pci 0x9507
+device.name ATI RADEON HD 3830
&device.id pci 0x9508
+device.name ATI Mobility Radeon HD 3870
&device.id pci 0x9509
+device.name ATI Mobility Radeon HD 3870 X2
&device.id pci 0x950F
+device.name ATI Radeon HD3870 X2
&device.id pci 0x9511
+device.name ATI FireGL V7700
&device.id pci 0x9513
+device.name ATI RADEON HD 3850 X2
&device.id pci 0x9515
+device.name ATI Radeon HD 3850 AGP
&device.id pci 0x9517
+device.name ATI Radeon HD 3960
&device.id pci 0x9519
+device.name FireStream 9170
&device.id pci 0x9540
+device.name ATI RADEON HD 4550
&device.id pci 0x9541
+device.name 0x9541
&device.id pci 0x9542
+device.name 0x9542
&device.id pci 0x954E
+device.name 0x954E
&device.id pci 0x954F
+device.name ATI RADEON HD 4350
&device.id pci 0x9552
+device.name Mobility Radeon HD 4300 Series
&device.id pci 0x9553
+device.name Mobility Radeon HD 4500 Series
&device.id pci 0x9555
+device.name Mobility Radeon M93
&device.id pci 0x9557
+device.name ATI FirePro RG220
&device.id pci 0x9580
+device.name RV630
&device.id pci 0x9581
+device.name Mobility Radeon HD 2600
&device.id pci 0x9583
+device.name Mobility Radeon HD 2600 XT
&device.id pci 0x9586
+device.name ATI Radeon HD 2600 XT AGP
&device.id pci 0x9587
+device.name ATI Radeon HD 2600 Pro AGP
&device.id pci 0x9588
+device.name Radeon HD 2600 XT
&device.id pci 0x9589
+device.name Radeon HD 2600 Pro
&device.id pci 0x958A
+device.name Gemini RV630
&device.id pci 0x958B
+device.name Gemini ATI Mobility Radeon HD 2600 XT
&device.id pci 0x958C
+device.name FireGL V5600
&device.id pci 0x958D
+device.name FireGL V3600
&device.id pci 0x958E
+device.name ATI Radeon HD 2600 LE
&device.id pci 0x958F
+device.name ATI Mobility FireGL Graphics Processor
&device.id pci 0x9590
+device.name ATI Radeon HD 3600 Series
&device.id pci 0x9591
+device.name Mobility Radeon HD 3650
&device.id pci 0x9592
+device.name 0x9592
&device.id pci 0x9593
+device.name Mobility Radeon HD 3670
&device.id pci 0x9595
+device.name Mobility FireGL V5700
&device.id pci 0x9596
+device.name ATI Radeon HD 3650 AGP
&device.id pci 0x9597
&device.id pci 0x9598
+device.name ATI Radeon HD 3670
&device.id pci 0x9599
&device.id pci 0x959B
+device.name ATI Mobility FireGL V5725
&device.id pci 0x95C0
+device.name ATI Radeon HD 3470
&device.id pci 0x95C2
+device.name ATI Mobility Radeon HD 3430 (M82)
&device.id pci 0x95C4
+device.name Mobility Radeon HD 3400 Series (M82)
&device.id pci 0x95C5
+device.name ATI Radeon HD 3450
&device.id pci 0x95C6
&device.id pci 0x95C7
+device.name ATI Radeon HD 3430
&device.id pci 0x95C9
&device.id pci 0x95CC
+device.name Fire PRO Professional Graphics ASIC
&device.id pci 0x95CD
+device.name ATI FireMV 2450
&device.id pci 0x95CE
&device.id pci 0x95CF
&device.id pci 0x9610
+device.name ATI Radeon HD 3200 Graphics
&device.id pci 0x9611
+device.name ATI Radeon 3100 Graphics
&device.id pci 0x9612
&device.id pci 0x9613
&device.id pci 0x9614
+device.name ATI Radeon HD 3300 Graphics
&device.id pci 0x9615
&device.id pci 0x9616
+device.name ATI Radeon HD 3000 Graphics
&device.id pci 0x9710
+device.name ATI Radeon HD Graphics
&device.id pci 0x9711
+device.name ATI Radeon Graphics
&device.id pci 0x9712
+device.name ATI Mobility Radeon HD Graphics
&device.id pci 0x9713
+device.name ATI Mobility Radeon Graphics
&device.id pci 0x9714
+driver.xfree 4|radeonhd[/spoiler]
Cards.20.xorg-x11-driver-video
[spoiler]NVidia: GeForce 7100 GS {
Driver = nv
NVidia: GeForce 8600 GT {
Driver = nv
NVidia: GeForce 8400 GS {
Driver = nv
NVidia: GeForce 8800 GS {
Driver = nv
NVidia: GeForce 8800 GT {
Driver = nv
NVidia: GeForce 9500 GT {
Driver = nv
NVidia: GeForce 8600 GS {
Driver = nv
NVidia: GeForce 9400 GT {
Driver = nv
NVidia: GeForce 9800 GTX+ {
Driver = nv
NVidia: GeForce 9800 GT {
Driver = nv
NVidia: GeForce 9600 GS {
Driver = nv
NVidia: GeForce 9800M GTS {
Driver = nv
NVidia: GeForce 9700M GTS {
Driver = nv
Driver = nv
NVidia: GeForce 9300 GS {
Driver = nv
NVidia: Quadro NVS 150M {
Driver = nv
NVidia: Quadro NVS 160M {
Driver = nv
NVidia: GeForce GTX 280 {
Driver = nv
NVidia: GeForce GTX 260 {
Driver = nv
NVidia: GeForce 9650M GS {
Driver = nv
NVidia: GeForce 9300M G {
Driver = nv
NVidia: GeForce 9600M GT {
Driver = nv
NVidia: GeForce 9600M GS {
Driver = nv
NVidia: GeForce 9500M G {
Driver = nv
NVidia: GeForce 9300M GS {
Driver = nv
NVidia: GeForce 9200M GS {
Driver = nv
NVidia: GeForce 7300 LE {
Driver = vesa
NVidia: GeForce 6100 Micro-Star {
Driver = vesa
NVidia: GeForce 9500 {
Driver = nv
NVidia: GeForce 9600 GSO {
Driver = nv
NVidia: GeForce 9800 GTX {
Driver = nv
NVidia: GeForce 9500M GS {
Driver = nv
NVidia: GeForce 8400 SE {
Driver = nv
NVidia: GeForce 8800 GTS 512 {
Driver = nv
NVidia: GeForce 9800 GX2 {
Driver = nv
NVidia: GeForce 8800M GTS {
Driver = nv
NVidia: GeForce 8800M GTX {
Driver = nv
NVidia: Quadro FX 3600M {
Driver = nv
NVidia: GeForce 6800 GS {
Driver = nv
NVidia: Quadro NVS 440 {
Driver = nv
NVidia: GeForce 6100 {
Driver = nv
NVidia: Quadro FX 3700 {
Driver = nv
NVidia: GeForce 9600 GT {
Driver = nv
Intel: Mobile IntelВ® GM45 Express Chipset {
Profile = Virtual
3DProfile = Virtual
3DDriver = intel
Flag = 3D
Extension = dri
Driver = intel
Intel: Intel Integrated Graphics Device {
Profile = Virtual
3DProfile = Virtual
3DDriver = intel
Flag = 3D
Extension = dri
Driver = intel
Intel: G45/G43 {
Profile = Virtual
3DProfile = Virtual
3DDriver = intel
Flag = 3D
Extension = dri
Driver = intel
Intel: Q45/Q43 {
Profile = Virtual
3DProfile = Virtual
3DDriver = intel
Flag = 3D
Extension = dri
Driver = intel
ATI: 3D Rage IIC 215IIC {
Driver = ati
Matrox:G200 EV {
Driver = mga
Matrox:G200 eW {
Driver = mga
Driver = nv
NVidia: GeForce 7350 LE {
Driver = nv
NVidia: GeForce 7650 GS {
Driver = nv
NVidia: GeForce 7950 GX2 {
Driver = nv
Driver = nv
NVidia: GeForce 7950 GT {
Driver = nv
NVidia: GeForce Go 7950 GTX {
Driver = nv
NVidia: Quadro NVS 210S / NVIDIA GeForce 6150LE {
Driver = nv
NVidia: GeForce 6150SE {
Driver = nv
NVidia: GeForce 6100 nForce 405 {
Driver = nv
NVidia: GeForce 6100 nForce 400 {
Driver = nv
NVidia: GeForce 6100 nForce 420 {
Driver = nv
NVidia: GeForce GTX 295 {
Driver = nv
NVidia: GeForce GTX 285 {
Driver = nv
NVidia: Quadro CX {
Driver = nv
NVidia: Quadro FX 5800 {
Driver = nv
NVidia: Quadro FX 4800 {
Driver = nv
NVidia: Quadro FX 3800 {
Driver = nv
Driver = nv
Driver = nv
NVidia: GeForce 9800M GTX {
Driver = nv
NVidia: GeForce 9800M GT {
Driver = nv
NVidia: GeForce GTS 250 {
Driver = nv
Driver = nv
NVidia: Quadro FX 3700M {
Driver = nv
NVidia: GeForce 9600 GSO 512 {
Driver = nv
NVidia: GeForce GT 130 {
Driver = nv
NVidia: GeForce GT 140 {
Driver = nv
NVidia: GeForce 9800M GS {
Driver = nv
NVidia: Quadro FX 1800 {
Driver = nv
NVidia: Quadro FX 2700M {
Driver = nv
Driver = nv
Driver = nv
NVidia: GeForce GT 120 {
Driver = nv
NVidia: GeForce 9700M GT {
Driver = nv
NVidia: GeForce 9650M GT {
Driver = nv
Driver = nv
NVidia: Quadro FX 380 {
Driver = nv
NVidia: Quadro FX 580 {
Driver = nv
NVidia: Quadro FX 770M {
Driver = nv
NVidia: GeForce 9300 GE {
Driver = nv
NVidia: GeForce G100 {
Driver = nv
NVidia: Quadro NVS 420 {
Driver = nv
NVidia: Quadro FX 370 LP {
Driver = nv
NVidia: Quadro NVS 450 {
Driver = nv
NVidia: Quadro NVS 295 {
Driver = nv
}[/spoiler]
Cards.20.xorg-x11-driver-video-radeonhd
[spoiler]ATI:Radeon X1800 {
Driver = radeonhd
ATI:Mobility Radeon X1800 XT {
Driver = radeonhd
ATI:Mobility Radeon X1800 {
Driver = radeonhd
ATI:Mobility FireGL V7200 {
Driver = radeonhd
ATI:FireGL V7200 {
Driver = radeonhd
ATI:FireGL V5300 {
Driver = radeonhd
ATI:Mobility FireGL V7100 {
Driver = radeonhd
ATI:Radeon X1800 {
Driver = radeonhd
ATI:Radeon X1800 {
Driver = radeonhd
ATI:Radeon X1800 {
Driver = radeonhd
ATI:Radeon X1800 {
Driver = radeonhd
ATI:Radeon X1800 {
Driver = radeonhd
ATI:FireGL V7300 {
Driver = radeonhd
ATI:FireGL V7350 {
Driver = radeonhd
ATI:Radeon X1600/X1550 {
Driver = radeonhd
ATI:RV505 {
Driver = radeonhd
ATI:Radeon X1300/X1550 {
Driver = radeonhd
ATI:Radeon X1550 {
Driver = radeonhd
ATI:M54-GL {
Driver = radeonhd
ATI:Mobility Radeon X1400 {
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X1550 64-bit {
Driver = radeonhd
ATI:Mobility Radeon X1300 {
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X1300 {
Driver = radeonhd
ATI:Radeon X1300 {
Driver = radeonhd
ATI:RV505 {
Driver = radeonhd
ATI:RV505 {
Driver = radeonhd
ATI:FireGL V3300 {
Driver = radeonhd
ATI:FireGL V3350 {
Driver = radeonhd
ATI:Radeon X1300 {
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X1600 {
Driver = radeonhd
Driver = radeonhd
ATI:Mobility Radeon X1450 {
Driver = radeonhd
Driver = radeonhd
ATI:Mobility Radeon X2300 {
Driver = radeonhd
Driver = radeonhd
ATI:Mobility Radeon X1350 {
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X1300 {
Driver = radeonhd
ATI:Radeon X1550 {
Driver = radeonhd
Driver = radeonhd
ATI:FireMV 2250 {
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X1600 {
Driver = radeonhd
ATI:Radeon X1650 {
Driver = radeonhd
ATI:Radeon X1600 {
Driver = radeonhd
ATI:Radeon X1600 {
Driver = radeonhd
ATI:Mobility FireGL V5200 {
Driver = radeonhd
ATI:Mobility Radeon X1600 {
Driver = radeonhd
ATI:Radeon X1650 {
Driver = radeonhd
ATI:Radeon X1650 {
Driver = radeonhd
ATI:Radeon X1600 {
Driver = radeonhd
ATI:Radeon X1300 XT/X1600 Pro {
Driver = radeonhd
ATI:FireGL V3400 {
Driver = radeonhd
ATI:Mobility FireGL V5250 {
Driver = radeonhd
ATI:Mobility Radeon X1700 {
Driver = radeonhd
ATI:Mobility Radeon X1700 XT {
Driver = radeonhd
ATI:FireGL V5200 {
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X2300HD {
Driver = radeonhd
ATI:Mobility Radeon HD 2300 {
Driver = radeonhd
Driver = radeonhd
ATI:Radeon X1950 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1950 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:AMD Stream Processor {
Driver = radeonhd
ATI:Radeon X1900 {
Driver = radeonhd
ATI:Radeon X1950 {
Driver = radeonhd
ATI:RV560 {
Driver = radeonhd
ATI:RV560 {
Driver = radeonhd
ATI:Mobility Radeon X1900 {
Driver = radeonhd
ATI:RV560 {
Driver = radeonhd
ATI:Radeon X1950 GT {
Driver = radeonhd
ATI:RV570 {
Driver = radeonhd
ATI:RV570 {
Driver = radeonhd
ATI:ATI FireGL V7400 {
Driver = radeonhd
ATI:RV560 {
Driver = radeonhd
ATI:Radeon X1650 {
Driver = radeonhd
ATI:Radeon X1650 {
Driver = radeonhd
ATI:RV560 {
Driver = radeonhd
ATI:Radeon X1200 {
Driver = radeonhd
ATI:Radeon X1200 {
Driver = radeonhd
ATI:Radeon Xpress 1200 {
Driver = radeonhd
Driver = radeonhd
ATI:Radeon Xpress 1200 (M) {
Driver = radeonhd
ATI:RS740 {
Driver = radeonhd
ATI:RS740M {
Driver = radeonhd
ATI:ATI Radeon 2100 RS740 {
Driver = radeonhd
ATI:RS740M {
Driver = radeonhd
ATI:Radeon HD 2900 XT {
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
ATI:Radeon HD 2900 Pro {
Driver = radeonhd
ATI:Radeon HD 2900 GT {
Driver = radeonhd
ATI:FireGL V8650 {
Driver = radeonhd
ATI:FireGL V8600 {
Driver = radeonhd
ATI:FireGL V7600 {
Driver = radeonhd
ATI:ATI Radeon 4800 Series {
Driver = radeonhd
ATI:ATI Radeon 4870 X2 {
Driver = radeonhd
Driver = radeonhd
ATI:ATI Radeon 4850 X2 {
Driver = radeonhd
ATI:Everest ATI FirePro Graphics Accelerator {
Driver = radeonhd
ATI:K2 ATI FirePro Graphics Accelerator {
Driver = radeonhd
ATI:ATI FirePro V8700 Duo {
Driver = radeonhd
ATI:ATI MOBILITY RADEON HD 4850 {
Driver = radeonhd
ATI:ATI MOBILITY RADEON HD 4850 X2 {
Driver = radeonhd
ATI:ATI RADEON HD 4800 Series {
Driver = radeonhd
ATI:RV770 {
Driver = radeonhd
ATI:RHD_DEVICE_MATCH( 0x944F, RHD_R700 ), {
Driver = radeonhd
ATI:AMD FireStream 9270 {
Driver = radeonhd
ATI:AMD FireStream 9250 {
Driver = radeonhd
ATI:Denali ATI FirePro Graphics Accelerator {
Driver = radeonhd
ATI:ATI MOBILITY RADEON HD 4870 {
Driver = radeonhd
ATI:M98 {
Driver = radeonhd
ATI:RV790 {
Driver = radeonhd
ATI:RV790 {
Driver = radeonhd
ATI:M98 {
Driver = radeonhd
ATI:M98 {
Driver = radeonhd
ATI:M98 {
Driver = radeonhd
ATI:M98 {
Driver = radeonhd
ATI:ATI MOBILITY RADEON HD 4650 {
Driver = radeonhd
ATI:RV730 {
Driver = radeonhd
ATI:ATI MOBILITY RADEON HD 4670 {
Driver = radeonhd
ATI:M96M GL {
Driver = radeonhd
ATI:RV730 {
Driver = radeonhd
ATI:ATI RADEON HD 4670 {
Driver = radeonhd
ATI:ATI RADEON E4600 {
Driver = radeonhd
ATI:ATI Radeon HD 4600 Series {
Driver = radeonhd
ATI:ATI RADEON HD 4650 {
Driver = radeonhd
ATI:ATI FirePro V7750 {
Driver = radeonhd
ATI:ATI FirePro V5700 {
Driver = radeonhd
ATI:ATI FirePro V3750 {
Driver = radeonhd
ATI:Mobility Radeon HD 4830 {
Driver = radeonhd
ATI:Mobility Radeon HD 4850 {
Driver = radeonhd
ATI:ATI FirePro M7740 {
Driver = radeonhd
ATI:RV740 {
Driver = radeonhd
ATI:Radeon HD 4770 {
Driver = radeonhd
ATI:Radeon HD 4700 Series {
Driver = radeonhd
Driver = radeonhd
ATI:ATI FirePro M5750 {
Driver = radeonhd
ATI:RV610 {
Driver = radeonhd
ATI:Radeon HD 2400 XT {
Driver = radeonhd
ATI:Radeon HD 2400 Pro {
Driver = radeonhd
ATI:ATI Radeon HD 2400 PRO AGP {
Driver = radeonhd
ATI:FireGL V4000 {
Driver = radeonhd
ATI:RV610 {
Driver = radeonhd
ATI:ATI Radeon HD 2350 {
Driver = radeonhd
ATI:Mobility Radeon HD 2400 XT {
Driver = radeonhd
ATI:Mobility Radeon HD 2400 {
Driver = radeonhd
ATI:ATI RADEON E2400 {
Driver = radeonhd
ATI:ATI Radeon HD 2400 {
Driver = radeonhd
ATI:ATI FireMV 2260 {
Driver = radeonhd
ATI:RV670 {
Driver = radeonhd
ATI:ATI Radeon HD3870 {
Driver = radeonhd
ATI:ATI Mobility Radeon HD 3850 {
Driver = radeonhd
ATI:ATI Radeon HD3850 {
Driver = radeonhd
ATI:ATI Mobility Radeon HD 3850 X2 {
Driver = radeonhd
ATI:ATI RADEON HD 3830 {
Driver = radeonhd
ATI:ATI Mobility Radeon HD 3870 {
Driver = radeonhd
ATI:ATI Mobility Radeon HD 3870 X2 {
Driver = radeonhd
ATI:ATI Radeon HD3870 X2 {
Driver = radeonhd
ATI:ATI FireGL V7700 {
Driver = radeonhd
ATI:ATI RADEON HD 3850 X2 {
Driver = radeonhd
ATI:ATI Radeon HD 3850 AGP {
Driver = radeonhd
ATI:ATI Radeon HD 3960 {
Driver = radeonhd
ATI:FireStream 9170 {
Driver = radeonhd
ATI:ATI RADEON HD 4550 {
Driver = radeonhd
ATI:0x9541 {
Driver = radeonhd
ATI:0x9542 {
Driver = radeonhd
ATI:0x954E {
Driver = radeonhd
ATI:ATI RADEON HD 4350 {
Driver = radeonhd
ATI:Mobility Radeon HD 4300 Series {
Driver = radeonhd
ATI:Mobility Radeon HD 4500 Series {
Driver = radeonhd
ATI:Mobility Radeon M93 {
Driver = radeonhd
ATI:ATI FirePro RG220 {
Driver = radeonhd
ATI:RV630 {
Driver = radeonhd
ATI:Mobility Radeon HD 2600 {
Driver = radeonhd
ATI:Mobility Radeon HD 2600 XT {
Driver = radeonhd
ATI:ATI Radeon HD 2600 XT AGP {
Driver = radeonhd
ATI:ATI Radeon HD 2600 Pro AGP {
Driver = radeonhd
ATI:Radeon HD 2600 XT {
Driver = radeonhd
ATI:Radeon HD 2600 Pro {
Driver = radeonhd
ATI:Gemini RV630 {
Driver = radeonhd
ATI:Gemini ATI Mobility Radeon HD 2600 XT {
Driver = radeonhd
ATI:FireGL V5600 {
Driver = radeonhd
ATI:FireGL V3600 {
Driver = radeonhd
ATI:ATI Radeon HD 2600 LE {
Driver = radeonhd
ATI:ATI Mobility FireGL Graphics Processor {
Driver = radeonhd
ATI:ATI Radeon HD 3600 Series {
Driver = radeonhd
ATI:Mobility Radeon HD 3650 {
Driver = radeonhd
ATI:0x9592 {
Driver = radeonhd
ATI:Mobility Radeon HD 3670 {
Driver = radeonhd
ATI:Mobility FireGL V5700 {
Driver = radeonhd
ATI:ATI Radeon HD 3650 AGP {
Driver = radeonhd
Driver = radeonhd
ATI:ATI Radeon HD 3670 {
Driver = radeonhd
Driver = radeonhd
ATI:ATI Mobility FireGL V5725 {
Driver = radeonhd
ATI:ATI Radeon HD 3470 {
Driver = radeonhd
ATI:ATI Mobility Radeon HD 3430 (M82) {
Driver = radeonhd
ATI:Mobility Radeon HD 3400 Series (M82) {
Driver = radeonhd
ATI:ATI Radeon HD 3450 {
Driver = radeonhd
Driver = radeonhd
ATI:ATI Radeon HD 3430 {
Driver = radeonhd
Driver = radeonhd
ATI:Fire PRO Professional Graphics ASIC {
Driver = radeonhd
ATI:ATI FireMV 2450 {
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
ATI:ATI Radeon HD 3200 Graphics {
Driver = radeonhd
ATI:ATI Radeon 3100 Graphics {
Driver = radeonhd
Driver = radeonhd
Driver = radeonhd
ATI:ATI Radeon HD 3300 Graphics {
Driver = radeonhd
Driver = radeonhd
ATI:ATI Radeon HD 3000 Graphics {
Driver = radeonhd
ATI:ATI Radeon HD Graphics {
Driver = radeonhd
ATI:ATI Radeon Graphics {
Driver = radeonhd
ATI:ATI Mobility Radeon HD Graphics {
Driver = radeonhd
ATI:ATI Mobility Radeon Graphics {
Driver = radeonhd
Driver = radeonhd
}[/spoiler]
Identity.map.20.xorg-x11-driver-video
[spoiler]NAME=NVidia&DEVICE=GeForce 7100 GS&VID=0x10de&DID=0x016A&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8600 GT&VID=0x10de&DID=0x0401&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8400 GS&VID=0x10de&DID=0x0424&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800 GT&VID=0x10de&DID=0x0602&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800 GS&VID=0x10de&DID=0x0606&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800 GS&VID=0x10de&DID=0x060D&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800 GT&VID=0x10de&DID=0x0611&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9500 GT&VID=0x10de&DID=0x0640&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8600 GS&VID=0x10de&DID=0x0403&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9400 GT&VID=0x10de&DID=0x042C&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800 GTX+&VID=0x10de&DID=0x0613&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800 GT&VID=0x10de&DID=0x0614&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600 GS&VID=0x10de&DID=0x0623&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800M GTS&VID=0x10de&DID=0x0628&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9700M GTS&VID=0x10de&DID=0x062A&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800M GTS&VID=0x10de&DID=0x062C&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9300 GS&VID=0x10de&DID=0x06E1&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 150M&VID=0x10de&DID=0x06EA&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 160M&VID=0x10de&DID=0x06EB&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GTX 280&VID=0x10de&DID=0x05E1&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GTX 260&VID=0x10de&DID=0x05E2&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9650M GS&VID=0x10de&DID=0x0408&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9300M G&VID=0x10de&DID=0x042E&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600M GT&VID=0x10de&DID=0x0647&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600M GS&VID=0x10de&DID=0x0648&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600M GT&VID=0x10de&DID=0x0649&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9500M G&VID=0x10de&DID=0x064B&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9300M GS&VID=0x10de&DID=0x06E5&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9200M GS&VID=0x10de&DID=0x06E8&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9300M GS&VID=0x10de&DID=0x06E9&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 7300 LE&VID=0x10de&DID=0x01D1&SERVER=vesa&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6100 Micro-Star&VID=0x10de&DID=0x0242&SERVER=vesa&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT&SUBVENDOR=0x1462&SUBDEVICE=0x7207
NAME=NVidia&DEVICE=GeForce 9500&VID=0x10de&DID=0x0640&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600 GSO&VID=0x10de&DID=0x0610&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800 GTX&VID=0x10de&DID=0x0612&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9500M GS&VID=0x10de&DID=0x0405&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8400 SE&VID=0x10de&DID=0x0420&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800 GTS 512&VID=0x10de&DID=0x0600&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800 GX2&VID=0x10de&DID=0x0604&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800M GTS&VID=0x10de&DID=0x0609&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 8800M GTX&VID=0x10de&DID=0x060C&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 3600M&VID=0x10de&DID=0x061C&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6800 GS&VID=0x10de&DID=0x00F6&SERVER=nv&EXT=&OPT=&RAW=Option "HWCursor" "off"&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 440&VID=0x10de&DID=0x014A&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6100&VID=0x10de&DID=0x0242&SERVER=nv&EXT=&OPT=&RAW=Option "HWCursor" "off"&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 3700&VID=0x10de&DID=0x061a&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600 GT&VID=0x10de&DID=0x0622&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Intel&DEVICE=Mobile IntelВ® GM45 Express Chipset&VID=0x8086&DID=0x2A42&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Intel&DEVICE=Mobile IntelВ® GM45 Express Chipset&VID=0x8086&DID=0x2A42&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=3D
NAME=Intel&DEVICE=Intel Integrated Graphics Device&VID=0x8086&DID=0x2E02&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Intel&DEVICE=Intel Integrated Graphics Device&VID=0x8086&DID=0x2E02&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=3D
NAME=Intel&DEVICE=G45/G43&VID=0x8086&DID=0x2E22&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Intel&DEVICE=G45/G43&VID=0x8086&DID=0x2E22&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=3D
NAME=Intel&DEVICE=Q45/Q43&VID=0x8086&DID=0x2E12&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Intel&DEVICE=Q45/Q43&VID=0x8086&DID=0x2E12&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=3D
NAME=Intel&DEVICE=G41&VID=0x8086&DID=0x2E32&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Intel&DEVICE=G41&VID=0x8086&DID=0x2E32&SERVER=intel&EXT=&OPT=EXANoComposite&RAW=&PROFILE=Virtual&SCRIPT3D=&PACKAGE3D=&FLAG=3D
NAME=ATI&DEVICE=3D Rage IIC 215IIC &VID=0x1002&DID=0x4756&SERVER=ati&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Matrox&DEVICE=G200 EV&VID=0x102b&DID=0x0530&SERVER=mga&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=Matrox&DEVICE=G200 eW&VID=0x102b&DID=0x0532&SERVER=mga&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 440&VID=0x10de&DID=014A&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 7350 LE&VID=0x10de&DID=01D0&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 7650 GS&VID=0x10de&DID=0390&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 7950 GX2&VID=0x10de&DID=0293&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 7950 GX2&VID=0x10de&DID=0294&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 7950 GT&VID=0x10de&DID=0295&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce Go 7950 GTX&VID=0x10de&DID=0297&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 210S / NVIDIA GeForce 6150LE&VID=0x10de&DID=0245&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6150SE&VID=0x10de&DID=03D0&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6100 nForce 405&VID=0x10de&DID=03D1&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6100 nForce 400&VID=0x10de&DID=03D2&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 6100 nForce 420&VID=0x10de&DID=03D5&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GTX 295&VID=0x10de&DID=05E0&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GTX 285&VID=0x10de&DID=05E3&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro CX&VID=0x10de&DID=05F9&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 5800&VID=0x10de&DID=05FD&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 4800&VID=0x10de&DID=05FE&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 3800&VID=0x10de&DID=05FF&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800 GT&VID=0x10de&DID=0601&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800 GT&VID=0x10de&DID=0605&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800M GTX&VID=0x10de&DID=0608&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800M GT&VID=0x10de&DID=060B&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GTS 250&VID=0x10de&DID=0615&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800M GTX&VID=0x10de&DID=0617&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 3700M&VID=0x10de&DID=061E&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9600 GSO 512&VID=0x10de&DID=0625&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GT 130&VID=0x10de&DID=0626&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GT 140&VID=0x10de&DID=0627&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9800M GS&VID=0x10de&DID=062B&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 1800&VID=0x10de&DID=0638&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 2700M&VID=0x10de&DID=063A&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9400 GT&VID=0x10de&DID=0641&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9500 GT&VID=0x10de&DID=0643&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce GT 120&VID=0x10de&DID=0646&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9700M GT&VID=0x10de&DID=064A&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9650M GT&VID=0x10de&DID=064C&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9500 GT&VID=0x10de&DID=0656&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 380&VID=0x10de&DID=0658&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 580&VID=0x10de&DID=0659&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 770M&VID=0x10de&DID=065C&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce 9300 GE&VID=0x10de&DID=06E0&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=GeForce G100&VID=0x10de&DID=06E6&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 420&VID=0x10de&DID=06F8&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro FX 370 LP&VID=0x10de&DID=06F9&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 450&VID=0x10de&DID=06FA&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=NVidia&DEVICE=Quadro NVS 295&VID=0x10de&DID=06FD&SERVER=nv&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT[/spoiler]
Identity.map.20.xorg-x11-driver-video-radeonhd
[spoiler]NAME=ATI&DEVICE=Radeon X1800&VID=0x1002&DID=0x7100&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1800 XT&VID=0x1002&DID=0x7101&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1800&VID=0x1002&DID=0x7102&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility FireGL V7200&VID=0x1002&DID=0x7103&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V7200&VID=0x1002&DID=0x7104&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V5300&VID=0x1002&DID=0x7105&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility FireGL V7100&VID=0x1002&DID=0x7106&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1800&VID=0x1002&DID=0x7108&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1800&VID=0x1002&DID=0x7109&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1800&VID=0x1002&DID=0x710A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1800&VID=0x1002&DID=0x710B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1800&VID=0x1002&DID=0x710C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V7300&VID=0x1002&DID=0x710E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V7350&VID=0x1002&DID=0x710F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1600/X1550&VID=0x1002&DID=0x7140&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV505&VID=0x1002&DID=0x7141&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300/X1550&VID=0x1002&DID=0x7142&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1550&VID=0x1002&DID=0x7143&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M54-GL&VID=0x1002&DID=0x7144&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1400&VID=0x1002&DID=0x7145&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300/X1550&VID=0x1002&DID=0x7146&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1550 64-bit&VID=0x1002&DID=0x7147&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1300&VID=0x1002&DID=0x7149&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1300&VID=0x1002&DID=0x714A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1300&VID=0x1002&DID=0x714B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1300&VID=0x1002&DID=0x714C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300&VID=0x1002&DID=0x714D&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300&VID=0x1002&DID=0x714E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV505&VID=0x1002&DID=0x714F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV505&VID=0x1002&DID=0x7151&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V3300&VID=0x1002&DID=0x7152&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V3350&VID=0x1002&DID=0x7153&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300&VID=0x1002&DID=0x715E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1550 64-bit&VID=0x1002&DID=0x715F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300/X1550&VID=0x1002&DID=0x7180&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1600&VID=0x1002&DID=0x7181&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300/X1550&VID=0x1002&DID=0x7183&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1450&VID=0x1002&DID=0x7186&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300/X1550&VID=0x1002&DID=0x7187&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X2300&VID=0x1002&DID=0x7188&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X2300&VID=0x1002&DID=0x718A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1350&VID=0x1002&DID=0x718B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1350&VID=0x1002&DID=0x718C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1450&VID=0x1002&DID=0x718D&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300&VID=0x1002&DID=0x718F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1550&VID=0x1002&DID=0x7193&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1350&VID=0x1002&DID=0x7196&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireMV 2250&VID=0x1002&DID=0x719B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1550 64-bit&VID=0x1002&DID=0x719F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1600&VID=0x1002&DID=0x71C0&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1650&VID=0x1002&DID=0x71C1&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1600&VID=0x1002&DID=0x71C2&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1600&VID=0x1002&DID=0x71C3&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility FireGL V5200&VID=0x1002&DID=0x71C4&SERVER=radeonhd&EXT=&OPT=DRI&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1600&VID=0x1002&DID=0x71C5&SERVER=radeonhd&EXT=&OPT=DRI&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1650&VID=0x1002&DID=0x71C6&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1650&VID=0x1002&DID=0x71C7&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1600&VID=0x1002&DID=0x71CD&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1300 XT/X1600 Pro&VID=0x1002&DID=0x71CE&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V3400&VID=0x1002&DID=0x71D2&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility FireGL V5250&VID=0x1002&DID=0x71D4&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1700&VID=0x1002&DID=0x71D5&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1700 XT&VID=0x1002&DID=0x71D6&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V5200&VID=0x1002&DID=0x71DA&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1700&VID=0x1002&DID=0x71DE&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X2300HD&VID=0x1002&DID=0x7200&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 2300&VID=0x1002&DID=0x7210&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 2300&VID=0x1002&DID=0x7211&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1950&VID=0x1002&DID=0x7240&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x7243&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1950&VID=0x1002&DID=0x7244&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x7245&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x7246&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x7247&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x7248&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x7249&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x724A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x724B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x724C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x724D&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=AMD Stream Processor&VID=0x1002&DID=0x724E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1900&VID=0x1002&DID=0x724F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1950&VID=0x1002&DID=0x7280&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV560&VID=0x1002&DID=0x7281&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV560&VID=0x1002&DID=0x7283&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon X1900&VID=0x1002&DID=0x7284&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV560&VID=0x1002&DID=0x7287&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1950 GT&VID=0x1002&DID=0x7288&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV570&VID=0x1002&DID=0x7289&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV570&VID=0x1002&DID=0x728B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FireGL V7400&VID=0x1002&DID=0x728C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV560&VID=0x1002&DID=0x7290&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1650&VID=0x1002&DID=0x7291&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1650&VID=0x1002&DID=0x7293&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV560&VID=0x1002&DID=0x7297&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1200&VID=0x1002&DID=0x791E&SERVER=radeonhd&EXT=&OPT=DRI&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon X1200&VID=0x1002&DID=0x791F&SERVER=radeonhd&EXT=&OPT=DRI&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon Xpress 1200&VID=0x1002&DID=0x793F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon Xpress 1200&VID=0x1002&DID=0x7941&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon Xpress 1200 (M)&VID=0x1002&DID=0x7942&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RS740&VID=0x1002&DID=0x796C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RS740M&VID=0x1002&DID=0x796D&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 2100 RS740&VID=0x1002&DID=0x796E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RS740M&VID=0x1002&DID=0x796F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2900 XT&VID=0x1002&DID=0x9400&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2900 XT&VID=0x1002&DID=0x9401&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2900 XT&VID=0x1002&DID=0x9402&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2900 Pro&VID=0x1002&DID=0x9403&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2900 GT&VID=0x1002&DID=0x9405&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V8650&VID=0x1002&DID=0x940A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V8600&VID=0x1002&DID=0x940B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V7600&VID=0x1002&DID=0x940F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 4800 Series&VID=0x1002&DID=0x9440&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 4870 X2&VID=0x1002&DID=0x9441&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 4800 Series&VID=0x1002&DID=0x9442&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 4850 X2&VID=0x1002&DID=0x9443&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Everest ATI FirePro Graphics Accelerator&VID=0x1002&DID=0x9444&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=K2 ATI FirePro Graphics Accelerator&VID=0x1002&DID=0x9446&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro V8700 Duo&VID=0x1002&DID=0x9447&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI MOBILITY RADEON HD 4850&VID=0x1002&DID=0x944A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI MOBILITY RADEON HD 4850 X2&VID=0x1002&DID=0x944B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 4800 Series&VID=0x1002&DID=0x944C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV770&VID=0x1002&DID=0x944E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RHD_DEVICE_MATCH( 0x944F, RHD_R700 ),&VID=0x1002&DID=0x944F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=AMD FireStream 9270&VID=0x1002&DID=0x9450&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=AMD FireStream 9250&VID=0x1002&DID=0x9452&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Denali ATI FirePro Graphics Accelerator&VID=0x1002&DID=0x9456&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI MOBILITY RADEON HD 4870&VID=0x1002&DID=0x945A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M98&VID=0x1002&DID=0x945B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV790&VID=0x1002&DID=0x9460&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV790&VID=0x1002&DID=0x9462&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M98&VID=0x1002&DID=0x946A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M98&VID=0x1002&DID=0x946B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M98&VID=0x1002&DID=0x947A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M98&VID=0x1002&DID=0x947B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI MOBILITY RADEON HD 4650&VID=0x1002&DID=0x9480&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV730&VID=0x1002&DID=0x9487&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI MOBILITY RADEON HD 4670&VID=0x1002&DID=0x9488&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=M96M GL&VID=0x1002&DID=0x9489&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV730&VID=0x1002&DID=0x948F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 4670&VID=0x1002&DID=0x9490&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON E4600&VID=0x1002&DID=0x9491&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 4600 Series&VID=0x1002&DID=0x9495&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 4650&VID=0x1002&DID=0x9498&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro V7750&VID=0x1002&DID=0x949C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro V5700&VID=0x1002&DID=0x949E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro V3750&VID=0x1002&DID=0x949F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 4830&VID=0x1002&DID=0x94A0&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 4850&VID=0x1002&DID=0x94A1&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro M7740&VID=0x1002&DID=0x94A3&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV740&VID=0x1002&DID=0x94B1&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 4770&VID=0x1002&DID=0x94B3&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 4700 Series&VID=0x1002&DID=0x94B4&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 4770&VID=0x1002&DID=0x94B5&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro M5750&VID=0x1002&DID=0x94B9&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV610&VID=0x1002&DID=0x94C0&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2400 XT&VID=0x1002&DID=0x94C1&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2400 Pro&VID=0x1002&DID=0x94C3&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 2400 PRO AGP&VID=0x1002&DID=0x94C4&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V4000&VID=0x1002&DID=0x94C5&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV610&VID=0x1002&DID=0x94C6&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 2350&VID=0x1002&DID=0x94C7&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 2400 XT&VID=0x1002&DID=0x94C8&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 2400&VID=0x1002&DID=0x94C9&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON E2400&VID=0x1002&DID=0x94CB&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 2400&VID=0x1002&DID=0x94CC&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FireMV 2260&VID=0x1002&DID=0x94CD&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV670&VID=0x1002&DID=0x9500&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD3870&VID=0x1002&DID=0x9501&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon HD 3850&VID=0x1002&DID=0x9504&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD3850&VID=0x1002&DID=0x9505&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon HD 3850 X2&VID=0x1002&DID=0x9506&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 3830&VID=0x1002&DID=0x9507&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon HD 3870&VID=0x1002&DID=0x9508&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon HD 3870 X2&VID=0x1002&DID=0x9509&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD3870 X2&VID=0x1002&DID=0x950F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FireGL V7700&VID=0x1002&DID=0x9511&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 3850 X2&VID=0x1002&DID=0x9513&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3850 AGP&VID=0x1002&DID=0x9515&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3960&VID=0x1002&DID=0x9517&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireStream 9170&VID=0x1002&DID=0x9519&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 4550&VID=0x1002&DID=0x9540&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=0x9541&VID=0x1002&DID=0x9541&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=0x9542&VID=0x1002&DID=0x9542&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=0x954E&VID=0x1002&DID=0x954E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI RADEON HD 4350&VID=0x1002&DID=0x954F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 4300 Series&VID=0x1002&DID=0x9552&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 4500 Series&VID=0x1002&DID=0x9553&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon M93&VID=0x1002&DID=0x9555&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FirePro RG220&VID=0x1002&DID=0x9557&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=RV630&VID=0x1002&DID=0x9580&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 2600&VID=0x1002&DID=0x9581&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 2600 XT&VID=0x1002&DID=0x9583&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 2600 XT AGP&VID=0x1002&DID=0x9586&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 2600 Pro AGP&VID=0x1002&DID=0x9587&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2600 XT&VID=0x1002&DID=0x9588&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Radeon HD 2600 Pro&VID=0x1002&DID=0x9589&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Gemini RV630&VID=0x1002&DID=0x958A&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Gemini ATI Mobility Radeon HD 2600 XT&VID=0x1002&DID=0x958B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V5600&VID=0x1002&DID=0x958C&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=FireGL V3600&VID=0x1002&DID=0x958D&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 2600 LE&VID=0x1002&DID=0x958E&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility FireGL Graphics Processor&VID=0x1002&DID=0x958F&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3600 Series&VID=0x1002&DID=0x9590&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 3650&VID=0x1002&DID=0x9591&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=0x9592&VID=0x1002&DID=0x9592&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 3670&VID=0x1002&DID=0x9593&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility FireGL V5700&VID=0x1002&DID=0x9595&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3650 AGP&VID=0x1002&DID=0x9596&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3600 Series&VID=0x1002&DID=0x9597&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3670&VID=0x1002&DID=0x9598&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3600 Series&VID=0x1002&DID=0x9599&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility FireGL V5725&VID=0x1002&DID=0x959B&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3470&VID=0x1002&DID=0x95C0&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon HD 3430 (M82)&VID=0x1002&DID=0x95C2&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Mobility Radeon HD 3400 Series (M82)&VID=0x1002&DID=0x95C4&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3450&VID=0x1002&DID=0x95C5&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3450&VID=0x1002&DID=0x95C6&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3430&VID=0x1002&DID=0x95C7&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3450&VID=0x1002&DID=0x95C9&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=Fire PRO Professional Graphics ASIC&VID=0x1002&DID=0x95CC&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FireMV 2450&VID=0x1002&DID=0x95CD&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FireMV 2260&VID=0x1002&DID=0x95CE&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI FireMV 2260&VID=0x1002&DID=0x95CF&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3200 Graphics&VID=0x1002&DID=0x9610&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 3100 Graphics&VID=0x1002&DID=0x9611&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3200 Graphics&VID=0x1002&DID=0x9612&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon 3100 Graphics&VID=0x1002&DID=0x9613&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3300 Graphics&VID=0x1002&DID=0x9614&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3200 Graphics&VID=0x1002&DID=0x9615&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD 3000 Graphics&VID=0x1002&DID=0x9616&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon HD Graphics&VID=0x1002&DID=0x9710&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon Graphics&VID=0x1002&DID=0x9711&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon HD Graphics&VID=0x1002&DID=0x9712&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Mobility Radeon Graphics&VID=0x1002&DID=0x9713&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT
NAME=ATI&DEVICE=ATI Radeon Graphics&VID=0x1002&DID=0x9714&SERVER=radeonhd&EXT=&OPT=&RAW=&PROFILE=&SCRIPT3D=&PACKAGE3D=&FLAG=DEFAULT[/spoiler]
sysconfig.displaymanager-xorg-x11-server
[spoiler]## Type: string(Xorg)
## Path: Desktop/Display manager
## Default: "Xorg"
DISPLAYMANAGER_XSERVER="Xorg"[/spoiler]
xorg.aug
[spoiler](*
Module: Xorg
Parses /etc/X11/xorg.conf
Author: Raphael Pinson <raphink@gmail.com>
About: Reference
This lens tries to keep as close as possible to `man xorg.conf` where
possible.
The definitions from `man xorg.conf` are put as commentaries for reference
throughout the file. More information can be found in the manual.
About: License
This file is licensed under the GPL.
About: Lens Usage
Sample usage of this lens in augtool
* Get the identifier of the devices with a "Clone" option:
> match "/files/etc/X11/xorg.conf/Device[Option = 'Clone']/Identifier"
About: Quotes in values
In this file, values may or may not be quoted (with double quotes) unless
they contain spaces or tabulations. For this reason, the quotes are
included in the parsed values when present. New values with no spaces will
not have quotes by default, unless you type the quotes yourself around
them. New values with spaces will not be accepted unless they are
explicitely surrounded by double qutoes.
About: Configuration files
This lens applies to /etc/X11/xorg.conf. See <filter>.
module Xorg =
autoload xfm
* Group: USEFUL PRIMITIVES
(* Group: Generic primitives *)
(* Variable: eol *)
let eol = Util.eol
(* Variable: indent *)
let indent = Util.indent
(* Variable: comment *)
let comment = Util.comment
(* Variable: empty *)
let empty = Util.empty
(* Group: Separators *)
(* Variable: sep_spc *)
let sep_spc = Util.del_ws_spc
(* Variable: sep_dquote *)
let sep_dquote = Util.del_str "\""
(* Group: Fields and values *)
(* Variable: entry_re *)
let entry_re = /[^# \t\n\/]+/ - "Option"
(* Variable: word_space
* TODO: refine possible values by Section
* words with spaces require quotes
let word_space = /"[^"\n]+"/
* Variable: word
* Words without spaces may have quotes or not
* the quotes are then part of the value
let word = /[^" \t\n]+/
(* Variable: quoted_word *)
let quoted_word = /"[^" \t\n]+"/ (* " relax Emacs *)
(* Variable: word_all *)
let word_all = word_space | word | quoted_word
* Group: ENTRIES AND OPTIONS
(* View: entry *)
let entry = [ indent . key entry_re
. sep_spc . store word_all . eol ]
(* View: option_value *)
let option_value =
[ label "value" . store word_all ]
(* View: option *)
let option = [ indent . key "Option" . sep_spc
. store word_all
. (sep_spc . option_value)* . eol ]
(* View: section_entry *)
let section_entry = empty | comment | entry | option
* Group: SECTIONS
* Variable: section_re
* Known values for Section names
* Definition:
* > The section names are:
* > Files File pathnames
* > ServerFlags Server flags
* > Module Dynamic module loading
* > InputDevice Input device description
* > Device Graphics device description
* > VideoAdaptor Xv video adaptor description
* > Monitor Monitor description
* > Modes Video modes descriptions
* > Screen Screen configuration
* > ServerLayout Overall layout
* > DRI DRI-specific configuration
* > Vendor Vendor-specific configuration
let section_re = /(Files|ServerFlags|Module|InputDevice|Device|VideoAdaptor
|Monitor|Modes|Screen|ServerLayout|DRI|Vendor)/
* Variable: secton_re_obsolete
* The following obsolete section names are still recognised for
* compatibility purposes. In new config files, the InputDevice
* section should be used instead.
* Definition:
* > Keyboard Keyboard configuration
* > Pointer Pointer/mouse configuration
let section_re_obsolete = /(Keyboard|Pointer)/
* View: section
* A section in xorg.conf
* Definition:
* > Section "SectionName"
* > SectionEntry
* > EndSection
let section = [ indent . del "Section" "Section"
. sep_spc . sep_dquote
. key (section_re|section_re_obsolete) . sep_dquote
. eol
. section_entry*
. indent . del "EndSection" "EndSection" . eol ]
* View: lns
* The xorg.conf lens
let lns = ( empty | comment | section )*
(* Variable: filter *)
let filter = (incl "/etc/X11/xorg.conf")
let xfm = transform lns filter[/spoiler]
xorg.conf.install
[spoiler]Section "Device"
Identifier "vboxvideo"
Driver "vboxvideo"
EndSection
Section "Screen"
Device "vboxvideo"
EndSection
Section "Device"
Identifier "vmware"
Driver "vmware"
EndSection
Section "Screen"
Identifier "vmware"
Device "vmware"
EndSection
Section "Device"
Identifier "cirrus"
Driver "cirrus"
EndSection
Section "Screen"
Identifier "cirrus"
Device "cirrus"
EndSection
Section "Device"
Identifier "fbdev"
Driver "fbdev"
EndSection
Section "Screen"
Identifier "fbdev"
Device "fbdev"
EndSection
Section "Device"
Identifier "vesa"
Driver "vesa"
EndSection
Section "Screen"
Identifier "vesa"
Device "vesa"
EndSection
Section "ServerLayout"
Identifier "Layout"
Screen "vboxvideo"
Screen "vmware"
Screen "cirrus"
Screen "fbdev"
Screen "vesa"[/spoiler]
EndSection[/spoiler]
![Круто! *COOL*](./images/smilies/good2.gif)
Ишшо добавим домашний адресс , телефон, дату рождения всех членов семьи - и будет полная инфа - акромя самого главного
![Сочуствие *EMPHANTY*](./images/smilies/empathy3.gif)
- BaHbKa
- Эникейщик
- ОС: Slackware & Windows7
Re: проблема с мышем и клавай
Нету у меня там xorg.conf
[spoiler]
[/spoiler]
еще это нашел
xorg.conf.5
[spoiler].\" $XdotOrg: xserver/xorg/hw/xfree86/doc/man/xorg.conf.man.pre,v 1.7 2006/05/26 00:12:18 reed Exp $
.\" shorthand for double quote that works everywhere.
.ds q \N'34'
.TH xorg.conf 5 "xorg-server 1.6.5" "X Version 11"
.SH NAME
xorg.conf \- configuration File for Xorg X server
.SH INTRODUCTION
.B Xorg
supports several mechanisms for supplying/obtaining configuration and
run-time parameters: command line options, environment variables, the
xorg.conf configuration file, auto-detection, and fallback defaults.
When the same information is supplied in more than one way, the highest
precedence mechanism is used. The list of mechanisms is ordered from
highest precedence to lowest. Note that not all parameters can be
supplied via all methods. The available command line options and
environment variables (and some defaults) are described in the Xserver(1)
and Xorg(1) manual pages. Most configuration file parameters, with
their defaults, are described below. Driver and module specific
configuration parameters are described in the relevant driver or module
manual page.
.SH DESCRIPTION
.B Xorg
uses a configuration file called
.I xorg.conf
for its initial setup.
This configuration file is searched for in the following places when the
server is started as a normal user:
.PP
.RS 4
.nf
.IR /etc/X11/ <cmdline>
.IR /usr/etc/X11/ <cmdline>
.IB /etc/X11/ $XORGCONFIG
.IB /usr/etc/X11/ $XORGCONFIG
.I /etc/X11/xorg.conf\-4
.I /etc/xorg.conf
.IR /usr/etc/X11/xorg.conf. <hostname>
.I /usr/etc/X11/xorg.conf\-4
.IR /usr/lib/X11/xorg.conf. <hostname>
.I /usr/lib/X11/xorg.conf\-4
.fi
.RE
.PP
where
.I <cmdline>
is a relative path (with no \(lq..\(rq components) specified with the
.B \-config
command line option,
.B $XORGCONFIG
is the relative path (with no \(lq..\(rq components) specified by that
environment variable, and
.I <hostname>
is the machine's hostname as reported by
.BR gethostname (3).
.PP
When the Xorg server is started by the \(lqroot\(rq user, the config file
search locations are as follows:
.PP
.RS 4
.nf
<cmdline>
.B $XORGCONFIG
.I /etc/xorg.conf
.fi
.RE
.PP
where
.I <cmdline>
is the path specified with the
.B \-config
command line option (which may be absolute or relative),
.B $XORGCONFIG
is the path specified by that
environment variable (absolute or relative),
.B $HOME
is the path specified by that environment variable (usually the home
directory), and
.I <hostname>
.PP
The
.I xorg.conf
file is composed of a number of sections which may be present in any order.
Each section has the form:
.PP
.RS 4
.nf
.BI "Section \*q" SectionName \*q
.RI " " SectionEntry
.B EndSection
.fi
.RE
.PP
.PP
.RS 4
.nf
.BR "Files " "File pathnames"
.BR "ServerFlags " "Server flags"
.BR "Module " "Dynamic module loading"
.BR "Extensions " "Extension enabling"
.BR "InputDevice " "Input device description"
.BR "Device " "Graphics device description"
.BR "VideoAdaptor " "Xv video adaptor description"
.BR "Monitor " "Monitor description"
.BR "Modes " "Video modes descriptions"
.BR "Screen " "Screen configuration"
.BR "ServerLayout " "Overall layout"
.BR "DRI " "DRI\-specific configuration"
.BR "Vendor " "Vendor\-specific configuration"
.fi
.RE
.PP
The following obsolete section names are still recognised for compatibility
purposes.
.B InputDevice
.PP
.RS 4
.nf
.BR "Keyboard " "Keyboard configuration"
.BR "Pointer " "Pointer/mouse configuration"
.fi
.RE
.PP
The old
.B XInput
section is no longer recognised.
.PP
The
.B ServerLayout
sections are at the highest level.
They bind together the input and output devices that will be used in a session.
The input devices are described in the
.B InputDevice
sections.
Output devices usually consist of multiple independent components (e.g.,
a graphics board and a monitor).
These multiple components are bound together in the
.B Screen
sections, and it is these that are referenced by the
.B ServerLayout
section.
Each
.B Screen
section binds together a graphics board and a monitor.
The graphics boards are described in the
.B Device
sections, and the monitors are described in the
.B Monitor
sections.
.PP
Config file keywords are case\-insensitive, and \(lq_\(rq characters are
ignored.
Most strings (including
.B Option
names) are also case-insensitive, and insensitive to white space and
\(lq_\(rq characters.
.PP
Each config file entry usually takes up a single line in the file. They
consist of a keyword, which is possibly followed by one or more arguments,
with the number and types of the arguments depending on the keyword.
The argument types are:
.PP
.RS 4
.nf
.BR "Integer " "an integer number in decimal, hex or octal"
.BR "Real " "a floating point number"
.BR "String " "a string enclosed in double quote marks (\*q)"
.fi
.RE
.PP
Note: hex integer values must be prefixed with \(lq0x\(rq, and octal values
with \(lq0\(rq.
.PP
A special keyword called
.B Option
may be used to provide free\-form data to various components of the server.
The
.B Option
keyword takes either one or two string arguments.
The first is the option name, and the optional second argument is the
option value.
Some commonly used option value types include:
.PP
.RS 4
.nf
.BR "String " "a sequence of characters"
.BR "Boolean " "a boolean value (see below)"
.BR "Frequency " "a frequency value (see below)"
.fi
.RE
.PP
Note that
.I all
.B Option
values, not just strings, must be enclosed in quotes.
.PP
Boolean options may optionally have a value specified.
When no value is specified, the option's value is
.BR TRUE .
The following boolean option values are recognised as
.BR TRUE :
.PP
.RS 4
.BR 1 ,
.BR on ,
.BR true ,
.B yes
.RE
.PP
and the following boolean option values are recognised as
.BR FALSE :
.PP
.RS 4
.BR 0 ,
.BR off ,
.BR false ,
.B no
.RE
.PP
If an option name is prefixed with
.RB \*q No \*q,
then the option value is negated.
.PP
Example: the following option entries are equivalent:
.PP
.RS 4
.nf
.B "Option \*qAccel\*q \*qOff\*q"
.B "Option \*qNoAccel\*q"
.B "Option \*qNoAccel\*q \*qOn\*q"
.B "Option \*qAccel\*q \*qfalse\*q"
.B "Option \*qAccel\*q \*qno\*q"
.fi
.RE
.PP
Frequency option values consist of a real number that is optionally
followed by one of the following frequency units:
.PP
.RS 4
.BR Hz ,
.BR k ,
.BR kHz ,
.BR M ,
.B MHz
.RE
.PP
When the unit name is omitted, the correct units will be determined from
the value and the expectations of the appropriate range of the value.
It is recommended that the units always be specified when using frequency
option values to avoid any errors in determining the value.
.SH "FILES SECTION"
The
.B Files
section is used to specify some path names required by the server.
Some of these paths can also be set from the command line (see
.BR Xserver (1)
and
.BR Xorg (1)).
The command line settings override the values specified in the config
file.
The
.B Files
section is optional, as are all of the entries that may appear in it.
.PP
The entries that can appear in this section are:
.TP 7
.BI "FontPath \*q" path \*q
sets the search path for fonts.
This path is a comma separated list of font path elements which the Xorg
server searches for font databases.
Multiple
.B FontPath
entries may be specified, and they will be concatenated to build up the
fontpath used by the server. Font path elements can be absolute
directory paths, catalogue directories or a font server identifier. The
formats of the later two are explained below:
.PP
.RS 7
Catalogue directories:
.PP
.RS 4
Catalogue directories can be specified using the prefix \fBcatalogue:\fR
before the directory name. The directory can then be populated with
symlinks pointing to the real font directories, using the following
syntax in the symlink name:
.PP
.RS 4
.IR <identifier> : [attribute]: pri= <priority>
.RE
.PP
where
.I <identifier>
is an alphanumeric identifier,
.I [attribute]
is an attribute which will be passed to the underlying FPE and
.I <priority>
is a number used to order the fontfile FPEs. Examples:
.PP
.RS 4
.nf
.I 75dpi:unscaled:pri=20 -> /usr/share/X11/fonts/75dpi
.I gscript:pri=60 -> /usr/share/fonts/default/ghostscript
.I misc:unscaled:pri=10 \-> /usr/share/X11/fonts/misc
.fi
.PP
.RE .RE .RE
.PP
.RS 7
Font server identifiers:
.PP
.RS 4
Font server identifiers have the form:
.RS 4
.PP
.IR <trans> / <hostname> : <port\-number>
.RE
.PP
where
.I <trans>
is the transport type to use to connect to the font server (e.g.,
.B unix
for UNIX\-domain sockets or
.B tcp
for a TCP/IP connection),
.I <hostname>
is the hostname of the machine running the font server, and
.I <port\-number>
is the port number that the font server is listening on (usually 7100).
.RE
.PP
When this entry is not specified in the config file, the server falls back
to the compiled\-in default font path, which contains the following
font path elements (which can be set inside a catalogue directory):
.PP
.RS 4
.nf
.I /usr/lib/X11/fonts/misc/
.I /usr/lib/X11/fonts/TTF/
.I /usr/lib/X11/fonts/Type1/
.I /usr/lib/X11/fonts/75dpi/
.I /usr/lib/X11/fonts/100dpi/
.fi
.RE
.PP
The recommended font path contains the following font path elements:
.PP
.RS 4
.nf
.I /usr/lib/X11/fonts/local/
.I /usr/lib/X11/fonts/75dpi/:unscaled
.I /usr/lib/X11/fonts/100dpi/:unscaled
.fi
.RE
.PP
Font path elements that are found to be invalid are removed from the
font path when the server starts up.
.RE
.TP 7
.BI "ModulePath \*q" path \*q
sets the search path for loadable Xorg server modules.
This path is a comma separated list of directories which the Xorg server
searches for loadable modules loading in the order specified.
Multiple
.B ModulePath
entries may be specified, and they will be concatenated to build the
module search path used by the server.
.\" The LogFile keyword is not currently implemented
.ig
.TP 7
.BI "LogFile \*q" path \*q
sets the name of the Xorg server log file.
The default log file name is
.PP
.RS 11
.RI /var/log/Xorg. <n> .log
.RE
.PP
.RS 7
where
.I <n>
is the display number for the Xorg server.
.SH "SERVERFLAGS SECTION"
In addition to options specific to this section (described below), the
.B ServerFlags
section is used to specify some global
Xorg server options.
All of the entries in this section are
.BR Options ,
although for compatibility purposes some of the old style entries are
still recognised.
Those old style entries are not documented here, and using them is
discouraged.
The
.B ServerFlags
section is optional, as are the entries that may be specified in it.
.PP
.B Options
specified in this section (with the exception of the
.B \*qDefaultServerLayout\*q
.BR Option )
may be overridden by
.B Options
specified in the active
.B ServerLayout
section.
Options with command line equivalents are overridden when their command
line equivalent is used.
The options recognised by this section are:
.TP 7
.BI "Option \*qDefaultServerLayout\*q \*q" layout\-id \*q
This specifies the default
.B ServerLayout
section to use in the absence of the
.B \-layout
command line option.
.TP 7
.BI "Option \*qNoTrapSignals\*q \*q" boolean \*q
This prevents the Xorg server from trapping a range of unexpected fatal
signals and exiting cleanly.
Instead, the Xorg server will die and drop core where the fault occurred.
The default behaviour is for the Xorg server to exit cleanly, but still drop a
core file.
In general you never want to use this option unless you are debugging an Xorg
server problem and know how to deal with the consequences.
.TP 7
.BI "Option \*qDontVTSwitch\*q \*q" boolean \*q
This disallows the use of the
.BI Ctrl+Alt+F n
sequence (where
.RI F n
refers to one of the numbered function keys).
That sequence is normally used to switch to another \*qvirtual terminal\*q
on operating systems that have this feature.
When this option is enabled, that key sequence has no special meaning and
is passed to clients.
Default: off.
.TP 7
.BI "Option \*qDontZap\*q \*q" boolean \*q
.B Terminate_Server
XKB action (usually on Ctrl+Alt+Backspace, depending on XKB options).
This action is normally used to terminate the Xorg server.
When this option is enabled, the action has no effect.
Default: off.
.TP 7
.BI "Option \*qZapWarning\*q \*q" boolean \*q
This warns the user loudly when the
.B Ctrl+Alt+Backspace
sequence is pressed for the first time but still terminates the Xorg
server when this key-sequence is pressed again shortly after.
Default: on.
.TP 7
.BI "Option \*qDontZoom\*q \*q" boolean \*q
.B Ctrl+Alt+Keypad\-Plus
and
.B Ctrl+Alt+Keypad\-Minus
sequences.
These sequences allows you to switch between video modes.
When this option is enabled, those key sequences have no special meaning
and are passed to clients.
Default: off.
.TP 7
.BI "Option \*qDisableVidModeExtension\*q \*q" boolean \*q
This disables the parts of the VidMode extension used by the xvidtune client
that can be used to change the video modes.
Default: the VidMode extension is enabled.
.TP 7
.BI "Option \*qAllowNonLocalXvidtune\*q \*q" boolean \*q
This allows the xvidtune client (and other clients that use the VidMode
extension) to connect from another host.
Default: off.
.TP 7
.BI "Option \*qAllowMouseOpenFail\*q \*q" boolean \*q
This allows the server to start up even if the mouse device can't be
opened/initialised.
Default: false.
.TP 7
.BI "Option \*qVTSysReq\*q \*q" boolean \*q
enables the SYSV\-style VT switch sequence for non\-SYSV systems
which support VT switching.
This sequence is
.B Alt\-SysRq
followed by a function key
.RB ( Fn ).
This prevents the Xorg server trapping the
keys used for the default VT switch sequence, which means that clients can
access them.
Default: off.
.TP 7
.BI "Option \*qXkbDisable\*q \*q" boolean \*q
disable/enable the XKEYBOARD extension.
The \-kb command line option overrides this config file option.
Default: XKB is enabled.
.\" The following four options are "undocumented".
.ig
.TP 7
.BI "Option \*qPciProbe1\*q"
Use PCI probe method 1.
Default: set.
.TP 7
.BI "Option \*qPciProbe2\*q"
Use PCI probe method 2.
Default: not set.
.TP 7
.BI "Option \*qPciForceConfig1\*q"
Force the use PCI config type 1.
Default: not set.
.TP 7
.BI "Option \*qPciForceConfig2\*q"
Force the use PCI config type 2.
Default: not set.
.TP 7
.BI "Option \*qBlankTime\*q \*q" time \*q
sets the inactivity timeout for the
.B blank
phase of the screensaver.
.I time
is in minutes.
This is equivalent to the Xorg server's
.B \-s
flag, and the value can be changed at run\-time with
.BR xset(1).
Default: 10 minutes.
.TP 7
.BI "Option \*qStandbyTime\*q \*q" time \*q
.B standby
phase of DPMS mode.
.I time
is in minutes, and the value can be changed at run\-time with
.BR xset(1).
Default: 20 minutes.
This is only suitable for VESA DPMS compatible monitors, and may not be
supported by all video drivers.
It is only enabled for screens that have the
.B \*qDPMS\*q
option set (see the MONITOR section below).
.TP 7
.BI "Option \*qSuspendTime\*q \*q" time \*q
.B suspend
phase of DPMS mode.
.I time
.BR xset(1).
Default: 30 minutes.
.B \*qDPMS\*q
.TP 7
.BI "Option \*qOffTime\*q \*q" time \*q
.B off
phase of DPMS mode.
.I time
.BR xset(1).
Default: 40 minutes.
.B \*qDPMS\*q
.TP 7
.BI "Option \*qPixmap\*q \*q" bpp \*q
This sets the pixmap format to use for depth 24.
Allowed values for
.I bpp
are 24 and 32.
Default: 32 unless driver constraints don't allow this (which is rare).
Note: some clients don't behave well when this value is set to 24.
.TP 7
.BI "Option \*qPC98\*q \*q" boolean \*q
Specify that the machine is a Japanese PC\-98 machine.
This should not be enabled for anything other than the Japanese\-specific
PC\-98 architecture.
Default: auto\-detected.
.\" Doubt this should be documented.
.ig
.TP 7
.BI "Option \*qEstimateSizesAggressively\*q \*q" value \*q
This option affects the way that bus resource sizes are estimated.
Default: 0.
.TP 7
.BI "Option \*qNoPM\*q \*q" boolean \*q
Disables something to do with power management events.
Default: PM enabled on platforms that support it.
.TP 7
.BI "Option \*qXinerama\*q \*q" boolean \*q
enable or disable XINERAMA extension.
Default is disabled.
.TP 7
.BI "Option \*qHandleSpecialKeys\*q \*q" when \*q
This option controls when the server uses the builtin handler to process
special key combinations (such as
.BR Ctrl+Alt+Backspace ).
Normally the XKEYBOARD extension keymaps will provide mappings for each of
the special key combinations, so the builtin handler is not needed unless
the XKEYBOARD extension is disabled.
The value of
.I when
can be
.BR Always ,
.BR Never ,
or
.BR WhenNeeded .
Default: Use the builtin handler only if needed.
The server will scan the keymap for a mapping to the
.B Terminate
action and, if found, use XKEYBOARD for processing actions, otherwise
the builtin handler will be used.
.TP 7
.BI "Option \*qAIGLX\*q \*q" boolean \*q
enable or disable AIGLX. AIGLX is enabled by default.
.TP 7
.BI "Option \*qGlxVisuals\*q \*q" string \*q
This option controls how many GLX visuals the GLX modules sets up.
The default value is
.BR "typical" ,
which will setup up a typical subset of
the GLXFBConfigs provided by the driver as GLX visuals. Other options are
.BR "minimal" ,
which will set up the minimal set allowed by the GLX specification and
.BR "all"
which will setup GLX visuals for all GLXFBConfigs.
.TP 7
.BI "Option \*qUseDefaultFontPath\*q \*q" boolean \*q
Include the default font path even if other paths are specified in
xorg.conf. If enabled, other font paths are included as well. Enabled by
default.
.TP 7
.BI "Option \*qIgnoreABI\*q \*q" boolean \*q
Allow modules built for a different, potentially incompatible version of
the X server to load. Disabled by default.
.TP 7
.BI "Option \*qAllowEmptyInput\*q \*q" boolean \*q
If enabled, don't add the standard keyboard and mouse drivers, if there are no
input devices in the config file. Enabled by default if AutoAddDevices and
AutoEnableDevices is enabled, otherwise disabled.
If AllowEmptyInput is on, devices using the kbd, mouse or vmmouse driver are ignored.
.TP 7
.BI "Option \*qAutoAddDevices\*q \*q" boolean \*q
If this option is disabled, then no devices will be added from HAL events.
Enabled by default.
.TP 7
.BI "Option \*qAutoEnableDevices\*q \*q" boolean \*q
If this option is disabled, then the devices will be added (and the
DevicePresenceNotify event sent), but not enabled, thus leaving policy up
to the client.
Enabled by default.
.TP 7
.BI "Option \*qLog\*q \*q" string \*q
This option controls whether the log is flushed and/or synced to disk after
each message.
Possible values are
.B flush
or
.BR sync .
Unset by default.
.SH "MODULE SECTION"
The
.B Module
section is used to specify which Xorg server modules should be loaded.
This section is ignored when the Xorg server is built in static form.
The types of modules normally loaded in this section are Xorg server
extension modules, and font rasteriser modules.
Most other module types are loaded automatically when they are needed via
other mechanisms.
The
.B Module
section is optional, as are all of the entries that may be specified in
it.
.PP
Entries in this section may be in two forms.
The first and most commonly used form is an entry that uses the
.B Load
keyword, as described here:
.TP 7
.BI "Load \*q" modulename \*q
This instructs the server to load the module called
.IR modulename .
The module name given should be the module's standard name, not the
module file name.
The standard name is case\-sensitive, and does not include the \(lqlib\(rq
prefix, or the \(lq.a\(rq, \(lq.o\(rq, or \(lq.so\(rq suffixes.
.PP
.RS 7
Example: the FreeType font rasteriser can be loaded with the following entry:
.PP
.RS 4
.B "Load \*qfreetype\*q"
.RE
.RE
.TP 7
.BI "Disable \*q" modulename \*q
This instructs the server to not load the module called
.IR modulename .
Some modules are loaded by default in the server, and this overrides that
default. If a
.B Load
instruction is given for the same module, it overrides the
.B Disable
instruction and the module is loaded. The module name given should be the
module's standard name, not the module file name. As with the
.B Load
instruction, the standard name is case-sensitive, and does not include the
"lib" prefix, or the ".a", ".o", or ".so" suffixes.
.PP
The second form of entry is a
.BR SubSection,
with the subsection name being the module name, and the contents of the
.B SubSection
being
.B Options
that are passed to the module when it is loaded.
.PP
Example: the extmod module (which contains a miscellaneous group of
server extensions) can be loaded, with the XFree86\-DGA extension
disabled by using the following entry:
.PP
.RS 4
.nf
.B "SubSection \*qextmod\*q"
.B " Option \*qomit XFree86\-DGA\*q"
.B EndSubSection
.fi
.RE
.PP
Modules are searched for in each directory specified in the
.B ModulePath
search path, and in the drivers, input, extensions, fonts, and
internal subdirectories of each of those directories.
In addition to this, operating system specific subdirectories of all
the above are searched first if they exist.
.PP
To see what font and extension modules are available, check the contents
of the following directories:
.PP
.RS 4
.nf
/usr/lib/modules/fonts
/usr/lib/modules/extensions
.fi
.RE
.PP
The \(lqextmod\(rq, \(lqdbe\(rq, \(lqglx\(rq, and \(lqdri\(rq extension
modules are loaded automatically, unless disabled with \*qDisable\*q entries.
It is recommended
that at very least the \(lqextmod\(rq extension module be loaded.
If it isn't, some commonly used server extensions (like the SHAPE
extension) will not be available.
.SH "EXTENSIONS SECTION"
The
.B Extensions
section is used to specify which X11 protocol extensions should be enabled
or disabled.
The
.B Extensions
it.
.PP
Entries in this section are listed as Option statements with the name of
the extension as the first argument, and a boolean value as the second.
The extension name is case\-sensitive, and matches the form shown in the output
of \*qXorg -extension ?\*q.
.PP
.RS 7
Example: the MIT-SHM extension can be disabled with the following entry:
.PP
.RS 4
.nf
.B "Section \*qExtensions\*q"
.B " Option \*qMIT-SHM\*q \*qDisable\*q"
.B "EndSection"
.fi
.RE
.RE
.SH "INPUTDEVICE SECTION"
The config file may have multiple
.B InputDevice
sections.
There will normally be at least two: one for the core (primary) keyboard,
and one of the core pointer.
If either of these two is missing, a default configuration for the missing
ones will be used.
Currently the default configuration may not work as expected on all platforms.
.PP
.B InputDevice
sections have the following format:
.PP
.RS 4
.nf
.B "Section \*qInputDevice\*q"
.BI " Identifier \*q" name \*q
.BI " Driver \*q" inputdriver \*q
.I " options"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
and
.B Driver
entries are required in all
.B InputDevice
sections.
All other entries are optional.
.PP
The
.B Identifier
entry specifies the unique name for this input device.
The
.B Driver
entry specifies the name of the driver to use for this input device.
When using the loadable server, the input driver module
.RI \*q inputdriver \*q
will be loaded for each active
.B InputDevice
section.
An
.B InputDevice
section is considered active if it is referenced by an active
.B ServerLayout
section, if it is referenced by the
.B \-keyboard
or
.B \-pointer
command line options, or if it is selected implicitly as the core pointer
or keyboard device in the absence of such explicit references.
The most commonly used input drivers are
.BR evdev (4)
on Linux systems, and
.BR kbd (4)
and
.BR mouse (4)
on other platforms.
.PP
In the absence of an explicitly specified core input device, the first
.B InputDevice
marked as
.B CorePointer
(or
.BR CoreKeyboard )
is used.
If there is no match there, the first
.B InputDevice
that uses the \(lqmouse\(rq (or \(lqkbd\(rq) driver is used.
The final fallback is to use built\-in default configurations.
.PP
.B InputDevice
sections recognise some driver\-independent
.BR Options ,
which are described here.
See the individual input driver manual pages for a description of the
device\-specific options.
.TP 7
.BI "Option \*qCorePointer\*q"
When this is set, the input device is installed as the core (primary)
pointer device.
There must be exactly one core pointer.
If this option is not set here, or in the
.B ServerLayout
section, or from the
.B \-pointer
command line option, then the first input device that is capable of
being used as a core pointer will be selected as the core pointer.
This option is implicitly set when the obsolete
.B Pointer
section is used.
.TP 7
.BI "Option \*qCoreKeyboard\*q"
When this is set, the input device is to be installed as the core
(primary) keyboard device.
There must be exactly one core keyboard.
If this option is not set here, in the
.B ServerLayout
.B \-keyboard
being used as a core keyboard will be selected as the core keyboard.
.B Keyboard
section is used.
.TP 7
.BI "Option \*qAlwaysCore\*q \*q" boolean \*q
.TP 7
.BI "Option \*qSendCoreEvents\*q \*q" boolean \*q
Both of these options are equivalent, and when enabled cause the
input device to always report core events.
This can be used, for example, to allow an additional pointer device to
generate core pointer events (like moving the cursor, etc).
.TP 4
.BI "Option \*qHistorySize\*q \*q" number \*q
Sets the motion history size.
Default: 0.
.TP 7
.BI "Option \*qSendDragEvents\*q \*q" boolean \*q
.SH "DEVICE SECTION"
.B Device
sections.
There must be at least one, for the video card being used.
.PP
.B Device
.PP
.RS 4
.nf
.B "Section \*qDevice\*q"
.BI " Driver \*q" driver \*q
.I " entries"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
and
.B Driver
.B Device
sections. All other entries are optional.
.PP
The
.B Identifier
entry specifies the unique name for this graphics device.
The
.B Driver
entry specifies the name of the driver to use for this graphics device.
When using the loadable server, the driver module
.RI \*q driver \*q
.B Device
section.
A
.B Device
.B Screen
section.
.PP
.B Device
sections recognise some driver\-independent entries and
.BR Options ,
Not all drivers make use of these
driver\-independent entries, and many of those that do don't require them
to be specified because the information is auto\-detected.
See the individual graphics driver manual pages for further information
about this, and for a description of the device\-specific options.
Note that most of the
.B Options
listed here (but not the other entries) may be specified in the
.B Screen
section instead of here in the
.B Device
section.
.TP 7
.BI "BusID \*q" bus\-id \*q
This specifies the bus location of the graphics card.
For PCI/AGP cards,
the
.I bus\-id
string has the form
.BI PCI: bus : device : function
(e.g., \(lqPCI:1:0:0\(rq might be appropriate for an AGP card).
This field is usually optional in single-head configurations when using
the primary graphics card.
In multi-head configurations, or when using a secondary graphics card in a
single-head configuration, this entry is mandatory.
Its main purpose is to make an unambiguous connection between the device
section and the hardware it is representing.
This information can usually be found by running the pciaccess tool
scanpci.
.TP 7
.BI "Screen " number
This option is mandatory for cards where a single PCI entity can drive more
than one display (i.e., multiple CRTCs sharing a single graphics accelerator
and video memory).
One
.B Device
section is required for each head, and this
parameter determines which head each of the
.B Device
sections applies to.
The legal values of
.I number
range from 0 to one less than the total number of heads per entity.
Most drivers require that the primary screen (0) be present.
.TP 7
.BI "Chipset \*q" chipset \*q
This usually optional entry specifies the chipset used on the graphics
board.
In most cases this entry is not required because the drivers will probe the
hardware to determine the chipset type.
Don't specify it unless the driver-specific documentation recommends that you
do.
.TP 7
.BI "Ramdac \*q" ramdac\-type \*q
This optional entry specifies the type of RAMDAC used on the graphics
board.
This is only used by a few of the drivers, and in most cases it is not
required because the drivers will probe the hardware to determine the
RAMDAC type where possible.
do.
.TP 7
.BI "DacSpeed " speed
.TP 7
.BI "DacSpeed " "speed\-8 speed\-16 speed\-24 speed\-32"
This optional entry specifies the RAMDAC speed rating (which is usually
printed on the RAMDAC chip).
The speed is in MHz.
When one value is given, it applies to all framebuffer pixel sizes.
When multiple values are given, they apply to the framebuffer pixel sizes
8, 16, 24 and 32 respectively.
This is not used by many drivers, and only needs to be specified when the
speed rating of the RAMDAC is different from the defaults built in to
driver, or when the driver can't auto-detect the correct defaults.
do.
.TP 7
.BI "Clocks " "clock ..."
specifies the pixel that are on your graphics board.
The clocks are in MHz, and may be specified as a floating point number.
The value is stored internally to the nearest kHz.
The ordering of the clocks is important.
It must match the order in which they are selected on the graphics board.
Multiple
.B Clocks
lines may be specified, and each is concatenated to form the list.
Most drivers do not use this entry, and it is only required for some older
boards with non-programmable clocks.
Don't specify this entry unless the driver-specific documentation explicitly
recommends that you do.
.TP
.BI "ClockChip \*q" clockchip\-type \*q
This optional entry is used to specify the clock chip type on graphics
boards which have a programmable clock generator.
Only a few Xorg drivers support programmable clock chips.
For details, see the appropriate driver manual page.
.TP 7
.BI "VideoRam " "mem"
This optional entry specifies the amount of video ram that is installed
This is measured in kBytes.
In most cases this is not required because the Xorg server probes
the graphics board to determine this quantity.
The driver-specific documentation should indicate when it might be needed.
.TP 7
.BI "BiosBase " "baseaddress"
This optional entry specifies the base address of the video BIOS for
the VGA board.
This address is normally auto-detected, and should only be specified if the
driver-specific documentation recommends it.
.TP 7
.BI "MemBase " "baseaddress"
This optional entry specifies the memory base address of a graphics
board's linear frame buffer.
This entry is not used by many drivers, and it should only be specified if
the driver-specific documentation recommends it.
.TP 7
.BI "IOBase " "baseaddress"
This optional entry specifies the IO base address.
.TP 7
.BI "ChipID " "id"
This optional entry specifies a numerical ID representing the chip type.
For PCI cards, it is usually the device ID.
This can be used to override the auto-detection, but that should only be done
when the driver-specific documentation recommends it.
.TP 7
.BI "ChipRev " "rev"
This optional entry specifies the chip revision number.
.TP 7
.BI "TextClockFreq " "freq"
This optional entry specifies the pixel clock frequency that is used
for the regular text mode.
The frequency is specified in MHz.
This is rarely used.
.TP 7
.BI "Option \*qModeDebug\*q \*q" boolean \*q
Enable printing of additional debugging information about modesetting to
the server log.
.ig
.TP 7
This optional entry allows an IRQ number to be specified.
.TP 7
.B Options
Option flags may be specified in the
.B Device
sections.
These include driver\-specific options and driver\-independent options.
The former are described in the driver\-specific documentation.
Some of the latter are described below in the section about the
.B Screen
section, and they may also be included here.
.SH "VIDEOADAPTOR SECTION"
Nobody wants to say how this works.
Maybe nobody knows ...
.SH "MONITOR SECTION"
.B Monitor
sections.
There should normally be at least one, for the monitor being used,
but a default configuration will be created when one isn't specified.
.PP
.B Monitor
.PP
.RS 4
.nf
.B "Section \*qMonitor\*q"
.I " entries"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The only mandatory entry in a
.B Monitor
section is the
.B Identifier
entry.
.PP
The
.B Identifier
entry specifies the unique name for this monitor.
The
.B Monitor
section may be used to provide information about the specifications of the
monitor, monitor-specific
.BR Options ,
and information about the video modes to use with the monitor.
.PP
With RandR 1.2-enabled drivers, monitor sections may be tied to specific
outputs of the video card. Using the name of the output defined by the video
driver plus the identifier of a monitor section, one associates a monitor
section with an output by adding an option to the Device section in the
following format:
.B Option \*qMonitor-outputname\*q \*qmonitorsection\*q
(for example,
.B Option \*qMonitor-VGA\*q \*qVGA monitor\*q
for a VGA output)
.PP
In the absence of specific association of monitor sections to outputs, if a
monitor section is present the server will associate it with an output to
preserve compatibility for previous single-head configurations.
.PP
Specifying video modes is optional because the server will use the DDC or other
information provided by the monitor to automatically configure the list of
modes available.
When modes are specified explicitly in the
.B Monitor
section (with the
.BR Modes ,
.BR ModeLine ,
or
.B UseModes
keywords), built-in modes with the same names are not included.
Built-in modes with different names are, however, still implicitly included,
when they meet the requirements of the monitor.
.PP
The entries that may be used in
.B Monitor
sections are described below.
.TP 7
.BI "VendorName \*q" vendor \*q
This optional entry specifies the monitor's manufacturer.
.TP 7
.BI "ModelName \*q" model \*q
This optional entry specifies the monitor's model.
.TP 7
.BI "HorizSync " "horizsync\-range"
gives the range(s) of horizontal sync frequencies supported by the
monitor.
.I horizsync\-range
may be a comma separated list of either discrete values or ranges of
values.
A range of values is two values separated by a dash.
By default the values are in units of kHz.
They may be specified in MHz or Hz
if
.B MHz
or
.B Hz
is added to the end of the line.
The data given here is used by the Xorg server to determine if video
modes are within the specifications of the monitor.
This information should be available in the monitor's handbook.
If this entry is omitted, a default range of 28\-33kHz is used.
.TP 7
.BI "VertRefresh " "vertrefresh\-range"
gives the range(s) of vertical refresh frequencies supported by the
monitor.
.I vertrefresh\-range
values.
By default the values are in units of Hz.
They may be specified in MHz or kHz
if
.B MHz
or
.B kHz
If this entry is omitted, a default range of 43\-72Hz is used.
.TP 7
.BI "DisplaySize " "width height"
This optional entry gives the width and height, in millimetres, of the
picture area of the monitor.
If given this is used to calculate the horizontal and vertical pitch (DPI) of
the screen.
.TP 7
.BI "Gamma " "gamma\-value"
.TP 7
.BI "Gamma " "red\-gamma green\-gamma blue\-gamma"
This is an optional entry that can be used to specify the gamma correction
for the monitor.
It may be specified as either a single value or as three separate RGB values.
The values should be in the range 0.1 to 10.0, and the default is 1.0.
Not all drivers are capable of using this information.
.TP 7
.BI "UseModes \*q" modesection\-id \*q
Include the set of modes listed in the
.B Modes
section called
.IR modesection\-id.
This makes all of the modes defined in that section available for use by
this monitor.
.TP 7
.BI "Mode \*q" name \*q
This is an optional multi-line entry that can be used to provide
definitions for video modes for the monitor.
In most cases this isn't necessary because the built-in set of VESA standard
modes will be sufficient.
The
.B Mode
keyword indicates the start of a multi-line video mode description.
The mode description is terminated with the
.B EndMode
keyword.
The mode description consists of the following entries:
.RS 7
.TP 4
.BI "DotClock " clock
is the dot (pixel) clock rate to be used for the mode.
.TP 4
.BI "HTimings " "hdisp hsyncstart hsyncend htotal"
specifies the horizontal timings for the mode.
.TP 4
.BI "VTimings " "vdisp vsyncstart vsyncend vtotal"
specifies the vertical timings for the mode.
.TP 4
.BI "Flags \*q" flag \*q " ..."
specifies an optional set of mode flags, each of which is a separate
string in double quotes.
.B \*qInterlace\*q
indicates that the mode is interlaced.
.B \*qDoubleScan\*q
indicates a mode where each scanline is doubled.
.B \*q+HSync\*q
and
.B \*q\-HSync\*q
can be used to select the polarity of the HSync signal.
.B \*q+VSync\*q
and
.B \*q\-VSync\*q
can be used to select the polarity of the VSync signal.
.B \*qComposite\*q
can be used to specify composite sync on hardware where this is supported.
Additionally, on some hardware,
.B \*q+CSync\*q
and
.B \*q\-CSync\*q
may be used to select the composite sync polarity.
.TP 4
.BI "HSkew " hskew
specifies the number of pixels (towards the right edge of the screen) by
which the display enable signal is to be skewed.
Not all drivers use this information.
This option might become necessary to override the default value supplied
by the server (if any).
\(lqRoving\(rq horizontal lines indicate this value needs to be increased.
If the last few pixels on a scan line appear on the left of the screen,
this value should be decreased.
.TP 4
.BI "VScan " vscan
specifies the number of times each scanline is painted on the screen.
Values less than 1 are treated as 1, which is the default.
Generally, the
.B \*qDoubleScan\*q
.B Flag
mentioned above doubles this value.
.RE
.TP 7
.BI "ModeLine \*q" name \*q " mode\-description"
This entry is a more compact version of the
.B Mode
entry, and it also can be used to specify video modes for the monitor.
is a single line format for specifying video modes.
In most cases this isn't necessary because the built\-in set of VESA
standard modes will be sufficient.
.PP
.RS 7
The
.I mode\-description
is in four sections, the first three of which are mandatory.
The first is the dot (pixel) clock.
This is a single number specifying the pixel clock rate for the mode in
MHz.
The second section is a list of four numbers specifying the horizontal
timings.
These numbers are the
.IR hdisp ,
.IR hsyncstart ,
.IR hsyncend ,
and
.I htotal
values.
The third section is a list of four numbers specifying the vertical
timings.
.IR vdisp ,
.IR vsyncstart ,
.IR vsyncend ,
and
.I vtotal
values.
The final section is a list of flags specifying other characteristics of
the mode.
.B Interlace
.B DoubleScan
.B +HSync
and
.B \-HSync
.B +VSync
and
.B \-VSync
.B Composite
.B +CSync
and
.B \-CSync
The
.B HSkew
and
.B VScan
options mentioned above in the
.B Modes
entry description can also be used here.
.RE
.TP 7
.BI "Option " "\*qDPMS\*q " \*qbool\*q
This option controls whether the server should enable the DPMS extension
for power management for this screen. The default is to enable the
extension.
.TP 7
.BI "Option " "\*qSyncOnGreen\*q " \*qbool\*q
This option controls whether the video card should drive the sync signal
on the green color pin. Not all cards support this option, and most
monitors do not require it. The default is off.
.TP 7
.BI "Option " "\*qTargetRefresh\*q " \*qrate\*q
This optional entry specifies the vertical refresh rate that the server
should aim for when selecting video modes. Without this option, the
default is to prefer modes with higher refresh rates.
.TP 7
.BI "Option " "\*qPreferredMode\*q " \*qstring\*q
This optional entry specifies a mode to be marked as the preferred initial mode
of the monitor.
(RandR 1.2-supporting drivers only)
.TP 7
.BI "Option " "\*qPosition\*q " "\*qx y\*q"
This optional entry specifies the position of the monitor within the X
screen.
.TP 7
.BI "Option " "\*qLeftOf\*q " \*qoutput\*q
This optional entry specifies that the monitor should be positioned to the
left of the output (not monitor) of the given name.
.TP 7
.BI "Option " "\*qRightOf\*q " \*qoutput\*q
right of the output (not monitor) of the given name.
.TP 7
.BI "Option " "\*qAbove\*q " \*qoutput\*q
This optional entry specifies that the monitor should be positioned above the
.TP 7
.BI "Option " "\*qBelow\*q " \*qoutput\*q
This optional entry specifies that the monitor should be positioned below the
.TP 7
.BI "Option " "\*qEnable\*q " \*qbool\*q
This optional entry specifies whether the monitor should be turned on
at startup. By default, the server will attempt to enable all connected
monitors.
.TP 7
.BI "Option " "\*qMinClock\*q " \*qfrequency\*q
This optional entry specifies the minimum dot clock, in kHz, that is supported
by the monitor.
.TP 7
.BI "Option " "\*qMaxClock\*q " \*qfrequency\*q
This optional entry specifies the maximum dot clock, in kHz, that is supported
by the monitor.
.TP 7
.BI "Option " "\*qIgnore\*q " \*qbool\*q
This optional entry specifies that the monitor should be ignored entirely,
and not reported through RandR. This is useful if the hardware reports the
presence of outputs that don't exist.
.TP 7
.BI "Option " "\*qRotate\*q " \*qrotation\*q
This optional entry specifies the initial rotation of the given monitor.
Valid values for rotation are \*qnormal\*q, \*qleft\*q, \*qright\*q, and
\*qinverted\*q.
.SH "MODES SECTION"
.B Modes
sections, or none.
These sections provide a way of defining sets of video modes independently
of the
.B Monitor
sections.
.B Monitor
sections may include the definitions provided in these sections by
using the
.B UseModes
keyword.
In most cases the
.B Modes
sections are not necessary because the built\-in set of VESA standard modes
will be sufficient.
.PP
.B Modes
.PP
.RS 4
.nf
.B "Section \*qModes\*q"
.I " entries"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
entry specifies the unique name for this set of mode descriptions.
The other entries permitted in
.B Modes
sections are the
.B Mode
and
.B ModeLine
entries that are described above in the
.B Monitor
section.
.SH "SCREEN SECTION"
.B Screen
sections.
There must be at least one, for the \(lqscreen\(rq being used.
A \(lqscreen\(rq represents the binding of a graphics device
.RB ( Device
section) and a monitor
.RB ( Monitor
section).
A
.B Screen
section is considered \(lqactive\(rq if it is referenced by an active
.B ServerLayout
section or by the
.B \-screen
If neither of those is present, the first
.B Screen
section found in the config file is considered the active one.
.PP
.B Screen
.PP
.RS 4
.nf
.B "Section \*qScreen\*q"
.BI " Device \*q" devid \*q
.BI " Monitor \*q" monid \*q
.I " entries"
.I " ..."
.BI " SubSection \*qDisplay\*q"
.I " entries"
.I " ...
.B " EndSubSection"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
and
.B Device
entries are mandatory.
All others are optional.
.PP
The
.B Identifier
entry specifies the unique name for this screen.
The
.B Screen
section provides information specific to the whole screen, including
screen\-specific
.BR Options .
In multi\-head configurations, there will be multiple active
.B Screen
sections, one for each head.
The entries available
for this section are:
.TP 7
.BI "Device \*q" device\-id \*q
This mandatory entry specifies the
.B Device
section to be used for this screen.
This is what ties a specific graphics card to a screen.
The
.I device\-id
must match the
.B Identifier
of a
.B Device
section in the config file.
.TP 7
.BI "Monitor \*q" monitor\-id \*q
specifies which monitor description is to be used for this screen.
If a
.B Monitor
name is not specified, a default configuration is used.
Currently the default configuration may not function as expected on all
platforms.
.TP 7
.BI "VideoAdaptor \*q" xv\-id \*q
specifies an optional Xv video adaptor description to be used with this
screen.
.TP 7
.BI "DefaultDepth " depth
specifies which color depth the server should use by default.
The
.B \-depth
command line option can be used to override this.
If neither is specified, the default depth is driver\-specific, but in most
cases is 8.
.TP 7
.BI "DefaultFbBpp " bpp
specifies which framebuffer layout to use by default.
The
.B \-fbbpp
In most cases the driver will chose the best default value for this.
The only case where there is even a choice in this value is for depth 24,
where some hardware supports both a packed 24 bit framebuffer layout and a
sparse 32 bit framebuffer layout.
.TP 7
.B Options
Various
.B Option
.B Screen
section.
Some are driver\-specific and are described in the driver documentation.
Others are driver\-independent, and will eventually be described here.
.\" XXX These should really be in an xaa man page.
.TP 7
.BI "Option \*qAccel\*q"
Enables XAA (X Acceleration Architecture), a mechanism that makes video cards'
2D hardware acceleration available to the Xorg server.
This option is on by default, but it may be necessary to turn it off if
there are bugs in the driver.
There are many options to disable specific accelerated operations, listed
below.
Note that disabling an operation will have no effect if the operation is
not accelerated (whether due to lack of support in the hardware or in the
driver).
.TP 7
.BI "Option \*qInitPrimary\*q \*q" boolean \*q
Use the Int10 module to initialize the primary graphics card.
Normally, only secondary cards are soft-booted using the Int10 module, as the
primary card has already been initialized by the BIOS at boot time.
Default: false.
.TP 7
.BI "Option \*qNoInt10\*q \*q" boolean \*q
Disables the Int10 module, a module that uses the int10 call to the BIOS
of the graphics card to initialize it.
Default: false.
.TP 7
.BI "Option \*qNoMTRR\*q"
Disables MTRR (Memory Type Range Register) support, a feature of modern
processors which can improve video performance by a factor of up to 2.5.
Some hardware has buggy MTRR support, and some video drivers have been
known to exhibit problems when MTRR's are used.
.TP 7
.BI "Option \*qXaaNoCPUToScreenColorExpandFill\*q"
Disables accelerated rectangular expansion blits from source patterns
stored in system memory (using a memory\-mapped aperture).
.TP 7
.BI "Option \*qXaaNoColor8x8PatternFillRect\*q"
Disables accelerated fills of a rectangular region with a full\-color
pattern.
.TP 7
.BI "Option \*qXaaNoColor8x8PatternFillTrap\*q"
Disables accelerated fills of a trapezoidal region with a full\-color
pattern.
.TP 7
.BI "Option \*qXaaNoDashedBresenhamLine\*q"
Disables accelerated dashed Bresenham line draws.
.TP 7
.BI "Option \*qXaaNoDashedTwoPointLine\*q"
Disables accelerated dashed line draws between two arbitrary points.
.TP 7
.BI "Option \*qXaaNoImageWriteRect\*q"
Disables accelerated transfers of full\-color rectangular patterns from
system memory to video memory (using a memory\-mapped aperture).
.TP 7
.BI "Option \*qXaaNoMono8x8PatternFillRect\*q"
Disables accelerated fills of a rectangular region with a monochrome
pattern.
.TP 7
.BI "Option \*qXaaNoMono8x8PatternFillTrap\*q"
Disables accelerated fills of a trapezoidal region with a monochrome
pattern.
.TP 7
.BI "Option \*qXaaNoOffscreenPixmaps\*q"
Disables accelerated draws into pixmaps stored in offscreen video memory.
.TP 7
.BI "Option \*qXaaNoPixmapCache\*q"
Disables caching of patterns in offscreen video memory.
.TP 7
.BI "Option \*qXaaNoScanlineCPUToScreenColorExpandFill\*q"
stored in system memory (one scan line at a time).
.TP 7
.BI "Option \*qXaaNoScanlineImageWriteRect\*q"
system memory to video memory (one scan line at a time).
.TP 7
.BI "Option \*qXaaNoScreenToScreenColorExpandFill\*q"
.TP 7
.BI "Option \*qXaaNoScreenToScreenCopy\*q"
Disables accelerated copies of rectangular regions from one part of
video memory to another part of video memory.
.TP 7
.BI "Option \*qXaaNoSolidBresenhamLine\*q"
Disables accelerated solid Bresenham line draws.
.TP 7
.BI "Option \*qXaaNoSolidFillRect\*q"
Disables accelerated solid\-color fills of rectangles.
.TP 7
.BI "Option \*qXaaNoSolidFillTrap\*q"
Disables accelerated solid\-color fills of Bresenham trapezoids.
.TP 7
.BI "Option \*qXaaNoSolidHorVertLine\*q"
Disables accelerated solid horizontal and vertical line draws.
.TP 7
.BI "Option \*qXaaNoSolidTwoPointLine\*q"
Disables accelerated solid line draws between two arbitrary points.
.PP
Each
.B Screen
section may optionally contain one or more
.B Display
subsections.
Those subsections provide depth/fbbpp specific configuration information,
and the one chosen depends on the depth and/or fbbpp that is being used for
the screen.
The
.B Display
subsection format is described in the section below.
.SH "DISPLAY SUBSECTION"
Each
.B Screen
section may have multiple
.B Display
subsections.
The \(lqactive\(rq
.B Display
subsection is the first that matches the depth and/or fbbpp values being
used, or failing that, the first that has neither a depth or fbbpp value
specified.
The
.B Display
subsections are optional.
When there isn't one that matches the depth and/or fbbpp values being used,
all the parameters that can be specified here fall back to their defaults.
.PP
.B Display
subsections have the following format:
.PP
.RS 4
.nf
.B " SubSection \*qDisplay\*q"
.BI " Depth " depth
.I " entries"
.I " ..."
.B " EndSubSection"
.fi
.RE
.TP 7
.BI "Depth " depth
This entry specifies what colour depth the
.B Display
subsection is to be used for.
This entry is usually specified, but it may be omitted to create a match\-all
.B Display
subsection or when wishing to match only against the
.B FbBpp
parameter.
The range of
.I depth
values that are allowed depends on the driver.
Most drivers support 8, 15, 16 and 24.
Some also support 1 and/or 4, and some may support other values (like 30).
Note:
.I depth
means the number of bits in a pixel that are actually used to determine
the pixel colour.
32 is not a valid
.I depth
value.
Most hardware that uses 32 bits per pixel only uses 24 of them to hold the
colour information, which means that the colour depth is 24, not 32.
.TP 7
.BI "FbBpp " bpp
This entry specifies the framebuffer format this
.B Display
This entry is only needed when providing depth 24 configurations that allow
a choice between a 24 bpp packed framebuffer format and a 32bpp sparse
framebuffer format.
In most cases this entry should not be used.
.TP 7
.BI "Weight " "red\-weight green\-weight blue\-weight"
This optional entry specifies the relative RGB weighting to be used
for a screen is being used at depth 16 for drivers that allow multiple
formats.
This may also be specified from the command line with the
.B \-weight
option (see
.BR Xorg(1)).
.TP 7
.BI "Virtual " "xdim ydim"
This optional entry specifies the virtual screen resolution to be used.
.I xdim
must be a multiple of either 8 or 16 for most drivers, and a multiple
of 32 when running in monochrome mode.
The given value will be rounded down if this is not the case.
Video modes which are too large for the specified virtual size will be
rejected.
If this entry is not present, the virtual screen resolution will be set to
accommodate all the valid video modes given in the
.B Modes
entry.
Some drivers/hardware combinations do not support virtual screens.
Refer to the appropriate driver\-specific documentation for details.
.TP 7
.BI "ViewPort " "x0 y0"
This optional entry sets the upper left corner of the initial display.
This is only relevant when the virtual screen resolution is different
from the resolution of the initial video mode.
If this entry is not given, then the initial display will be centered in
the virtual display area.
.TP 7
.BI "Modes \*q" mode\-name \*q " ..."
This optional entry specifies the list of video modes to use.
Each
.I mode\-name
specified must be in double quotes.
They must correspond to those specified or referenced in the appropriate
.B Monitor
section (including implicitly referenced built\-in VESA standard modes).
The server will delete modes from this list which don't satisfy various
requirements.
The first valid mode in this list will be the default display mode for
startup.
The list of valid modes is converted internally into a circular list.
It is possible to switch to the next mode with
and to the previous mode with
.BR Ctrl+Alt+Keypad\-Minus .
When this entry is omitted, the valid modes referenced by the appropriate
.B Monitor
section will be used. If the
.B Monitor
section contains no modes, then the selection will be taken from the
built-in VESA standard modes.
.TP 7
.BI "Visual \*q" visual\-name \*q
This optional entry sets the default root visual type.
This may also be specified from the command line (see the
.BR Xserver(1)
man page).
The visual types available for depth 8 are (default is
.BR PseudoColor ):
.PP
.RS 11
.nf
.B StaticGray
.B GrayScale
.B StaticColor
.B PseudoColor
.B TrueColor
.B DirectColor
.fi
.RE
.PP
.RS 7
The visual type available for the depths 15, 16 and 24 are (default is
.BR TrueColor ):
.PP
.RS 4
.nf
.B TrueColor
.B DirectColor
.fi
.RE
.PP
Not all drivers support
.B DirectColor
at these depths.
.PP
The visual types available for the depth 4 are (default is
.BR StaticColor ):
.PP
.RS 4
.nf
.B StaticGray
.B GrayScale
.B StaticColor
.B PseudoColor
.fi
.RE
.PP
The visual type available for the depth 1 (monochrome) is
.BR StaticGray .
.RE
.TP 7
.BI "Black " "red green blue"
This optional entry allows the \(lqblack\(rq colour to be specified.
This is only supported at depth 1.
The default is black.
.TP 7
.BI "White " "red green blue"
This optional entry allows the \(lqwhite\(rq colour to be specified.
The default is white.
.TP 7
.B Options
.B Display
subsections.
These may include driver\-specific options and driver\-independent options.
Some of the latter are described above in the section about the
.B Screen
.SH "SERVERLAYOUT SECTION"
.B ServerLayout
sections.
A \(lqserver layout\(rq represents the binding of one or more screens
.RB ( Screen
sections) and one or more input devices
.RB ( InputDevice
sections) to form a complete configuration.
In multi\-head configurations, it also specifies the relative layout of the
heads.
A
.B ServerLayout
section is considered \(lqactive\(rq if it is referenced by the
.B \-layout
command line option or by an
.B "Option \*qDefaultServerLayout\*q"
entry in the
.B ServerFlags
section (the former takes precedence over the latter).
If those options are not used, the first
.B ServerLayout
If no
.B ServerLayout
sections are present, the single active screen and two active (core)
input devices are selected as described in the relevant sections above.
.PP
.B ServerLayout
.PP
.RS 4
.nf
.B "Section \*qServerLayout\*q"
.BI " Screen \*q" screen\-id \*q
.I " ..."
.BI " InputDevice \*q" idev\-id \*q
.I " ..."
.I " options"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
Each
.B ServerLayout
section must have an
.B Identifier
entry and at least one
.B Screen
entry.
.PP
The
.B Identifier
entry specifies the unique name for this server layout.
The
.B ServerLayout
section provides information specific to the whole session, including
session\-specific
.BR Options .
The
.B ServerFlags
options (described above) may be specified here, and ones given here
override those given in the
.B ServerFlags
section.
.PP
The entries that may be used in this section are described here.
.TP 7
.BI "Screen " "screen\-num" " \*qscreen\-id\*q " "position\-information"
One of these entries must be given for each screen being used in
a session.
The
.I screen\-id
field is mandatory, and specifies the
.B Screen
section being referenced.
The
.I screen\-num
field is optional, and may be used to specify the screen number
in multi\-head configurations.
When this field is omitted, the screens will be numbered in the order that
they are listed in.
The numbering starts from 0, and must be consecutive.
The
.I position\-information
field describes the way multiple screens are positioned.
There are a number of different ways that this information can be provided:
.RS 7
.TP 4
.I "x y"
.TP 4
.BI "Absolute " "x y"
These both specify that the upper left corner's coordinates are
.RI ( x , y ).
The
.B Absolute
keyword is optional.
Some older versions of XFree86 (4.2 and earlier) don't recognise the
.B Absolute
keyword, so it's safest to just specify the coordinates without it.
.TP 4
.BI "RightOf \*q" screen\-id \*q
.TP 4
.BI "LeftOf \*q" screen\-id \*q
.TP 4
.BI "Above \*q" screen\-id \*q
.TP 4
.BI "Below \*q" screen\-id \*q
.TP 4
.BI "Relative \*q" screen\-id \*q " x y"
These give the screen's location relative to another screen.
The first four position the screen immediately to the right, left, above or
below the other screen.
When positioning to the right or left, the top edges are aligned.
When positioning above or below, the left edges are aligned.
The
.B Relative
form specifies the offset of the screen's origin (upper left corner)
relative to the origin of another screen.
.RE
.TP 7
.BI "InputDevice \*q" idev\-id "\*q \*q" option \*q " ..."
One of these entries should be given for each input device being used in
a session.
Normally at least two are required, one each for the core pointer and
keyboard devices.
If either of those is missing, suitable
.B InputDevice
entries are searched for using the method described above in the
.B INPUTDEVICE
section. The
.I idev\-id
field is mandatory, and specifies the name of the
.B InputDevice
Multiple
.I option
fields may be specified, each in double quotes.
The options permitted here are any that may also be given in the
.B InputDevice
sections.
Normally only session\-specific input device options would be used here.
The most commonly used options are:
.PP
.RS 11
.nf
.B \*qCorePointer\*q
.B \*qCoreKeyboard\*q
.B \*qSendCoreEvents\*q
.fi
.RE
.PP
.RS 7
and the first two should normally be used to indicate the core pointer
and core keyboard devices respectively.
.RE
.TP 7
.B Options
In addition to the following, any option permitted in the
.B ServerFlags
section may also be specified here.
When the same option appears in both places, the value given here overrides
the one given in the
.B ServerFlags
section.
.TP 7
.BI "Option \*qIsolateDevice\*q \*q" bus\-id \*q
Restrict device resets to the specified
.IR bus\-id .
See the
.B BusID
option (described in
.BR "DEVICE SECTION" ,
above) for the format of the
.I bus\-id
parameter.
This option overrides
.BR SingleCard ,
if specified.
At present, only PCI devices can be isolated in this manner.
.TP 7
.BI "Option \*qSingleCard\*q \*q" boolean \*q
As
.BR IsolateDevice ,
except that the bus ID of the first device in the layout is used.
.PP
Here is an example of a
.B ServerLayout
section for a dual headed configuration with two mice:
.PP
.RS 4
.nf
.B " Identifier \*qLayout 1\*q"
.B " Screen \*qMGA 1\*q"
.B " Screen \*qMGA 2\*q RightOf \*qMGA 1\*q"
.B " InputDevice \*qKeyboard 1\*q \*qCoreKeyboard\*q"
.B " InputDevice \*qMouse 1\*q \*qCorePointer\*q"
.B " InputDevice \*qMouse 2\*q \*qSendCoreEvents\*q"
.B " Option \*qBlankTime\*q \*q5\*q"
.B "EndSection"
.fi
.RE
.SH "DRI SECTION"
This optional section is used to provide some information for the
Direct Rendering Infrastructure.
Details about the format of this section
can be found in the README.DRI document, which is also available on-line at
.IR <http://dri.freedesktop.org/> .
.SH "VENDOR SECTION"
The optional
.B Vendor
section may be used to provide vendor\-specific configuration information.
Multiple
.B Vendor
sections may be present, and they may contain an
.B Identifier
entry and multiple
.B Option
flags.
The data therein is not used in this release.
.PP
.SH "SEE ALSO"
General:
.BR X (7),
.BR Xserver (1),
.BR Xorg (1),
.BR cvt (1),
.BR gtf (1).
.PP
.B "Not all modules or interfaces are available on all platforms."
.PP
Display drivers:
.BR apm (4),
.BR ati (4),
.BR chips (4),
.BR cirrus (4),
.BR cyrix (4),
.BR fbdev (4),
.BR glide (4),
.BR glint (4),
.BR i128 (4),
.BR i740 (4),
.BR imstt (4),
.BR intel (4),
.BR mga (4),
.BR neomagic (4),
.BR nv (4),
.BR openchrome (4),
.BR r128 (4),
.BR radeon (4),
.BR rendition (4),
.BR savage (4),
.BR s3virge (4),
.BR siliconmotion (4),
.BR sis (4),
.BR sisusb (4),
.BR sunbw2 (4),
.BR suncg14 (4),
.BR suncg3 (4),
.BR suncg6 (4),
.BR sunffb (4),
.BR sunleo (4),
.BR suntcx (4),
.BR tdfx (4),
.\" .BR tga (4),
.BR trident (4),
.BR tseng (4),
.BR vesa (4),
.BR vmware (4),
.BR voodoo (4),
.BR wsfb (4),
.BR xgi (4),
.BR xgixp (4).
.PP
Input drivers:
.BR acecad (4),
.BR calcomp (4),
.BR citron (4),
.BR dmc (4),
.BR dynapro (4),
.BR elographics (4),
.BR evdev (4),
.BR fpit (4),
.BR js_x (4),
.BR joystick (4),
.BR kbd (4),
.BR magictouch (4),
.BR microtouch (4),
.BR mousedrv (4),
.BR mutouch (4),
.BR palmax (4),
.BR penmount (4),
.BR synaptics (4),
.BR tek4957 (4),
.BR ur98 (4),
.BR vmmouse (4),
.BR void (4),
.BR wacom (4).
.PP
Other modules and interfaces:
.BR exa (4),
.BR fbdevhw (4),
.\" .BR shadowfb (4),
.BR v4l (4).
.br
.SH AUTHORS
This manual page was largely rewritten by David Dawes
.IR <dawes@xfree86.org> .[/spoiler]
[spoiler]
![Изображение](http://image.torrent.kg/images/g6118111.png)
еще это нашел
xorg.conf.5
[spoiler].\" $XdotOrg: xserver/xorg/hw/xfree86/doc/man/xorg.conf.man.pre,v 1.7 2006/05/26 00:12:18 reed Exp $
.\" shorthand for double quote that works everywhere.
.ds q \N'34'
.TH xorg.conf 5 "xorg-server 1.6.5" "X Version 11"
.SH NAME
xorg.conf \- configuration File for Xorg X server
.SH INTRODUCTION
.B Xorg
supports several mechanisms for supplying/obtaining configuration and
run-time parameters: command line options, environment variables, the
xorg.conf configuration file, auto-detection, and fallback defaults.
When the same information is supplied in more than one way, the highest
precedence mechanism is used. The list of mechanisms is ordered from
highest precedence to lowest. Note that not all parameters can be
supplied via all methods. The available command line options and
environment variables (and some defaults) are described in the Xserver(1)
and Xorg(1) manual pages. Most configuration file parameters, with
their defaults, are described below. Driver and module specific
configuration parameters are described in the relevant driver or module
manual page.
.SH DESCRIPTION
.B Xorg
uses a configuration file called
.I xorg.conf
for its initial setup.
This configuration file is searched for in the following places when the
server is started as a normal user:
.PP
.RS 4
.nf
.IR /etc/X11/ <cmdline>
.IR /usr/etc/X11/ <cmdline>
.IB /etc/X11/ $XORGCONFIG
.IB /usr/etc/X11/ $XORGCONFIG
.I /etc/X11/xorg.conf\-4
.I /etc/xorg.conf
.IR /usr/etc/X11/xorg.conf. <hostname>
.I /usr/etc/X11/xorg.conf\-4
.IR /usr/lib/X11/xorg.conf. <hostname>
.I /usr/lib/X11/xorg.conf\-4
.fi
.RE
.PP
where
.I <cmdline>
is a relative path (with no \(lq..\(rq components) specified with the
.B \-config
.B $XORGCONFIG
is the relative path (with no \(lq..\(rq components) specified by that
environment variable, and
.I <hostname>
is the machine's hostname as reported by
.BR gethostname (3).
.PP
When the Xorg server is started by the \(lqroot\(rq user, the config file
search locations are as follows:
.PP
.RS 4
.nf
<cmdline>
.B $XORGCONFIG
.I /etc/xorg.conf
.fi
.RE
.PP
where
.I <cmdline>
is the path specified with the
.B \-config
command line option (which may be absolute or relative),
.B $XORGCONFIG
is the path specified by that
environment variable (absolute or relative),
.B $HOME
is the path specified by that environment variable (usually the home
directory), and
.I <hostname>
.PP
The
.I xorg.conf
file is composed of a number of sections which may be present in any order.
Each section has the form:
.PP
.RS 4
.nf
.BI "Section \*q" SectionName \*q
.RI " " SectionEntry
.B EndSection
.fi
.RE
.PP
The section names are:
.PP
.RS 4
.nf
.BR "Files " "File pathnames"
.BR "ServerFlags " "Server flags"
.BR "Module " "Dynamic module loading"
.BR "Extensions " "Extension enabling"
.BR "InputDevice " "Input device description"
.BR "Device " "Graphics device description"
.BR "VideoAdaptor " "Xv video adaptor description"
.BR "Monitor " "Monitor description"
.BR "Modes " "Video modes descriptions"
.BR "Screen " "Screen configuration"
.BR "ServerLayout " "Overall layout"
.BR "DRI " "DRI\-specific configuration"
.BR "Vendor " "Vendor\-specific configuration"
.fi
.RE
.PP
The following obsolete section names are still recognised for compatibility
purposes.
In new config files, the
.B InputDevice
section should be used instead.
.PP
.RS 4
.nf
.BR "Keyboard " "Keyboard configuration"
.BR "Pointer " "Pointer/mouse configuration"
.fi
.RE
.PP
The old
.B XInput
section is no longer recognised.
.PP
The
.B ServerLayout
sections are at the highest level.
They bind together the input and output devices that will be used in a session.
The input devices are described in the
.B InputDevice
sections.
Output devices usually consist of multiple independent components (e.g.,
a graphics board and a monitor).
These multiple components are bound together in the
.B Screen
sections, and it is these that are referenced by the
.B ServerLayout
section.
Each
.B Screen
section binds together a graphics board and a monitor.
The graphics boards are described in the
.B Device
sections, and the monitors are described in the
.B Monitor
sections.
.PP
Config file keywords are case\-insensitive, and \(lq_\(rq characters are
ignored.
Most strings (including
.B Option
names) are also case-insensitive, and insensitive to white space and
\(lq_\(rq characters.
.PP
Each config file entry usually takes up a single line in the file. They
consist of a keyword, which is possibly followed by one or more arguments,
with the number and types of the arguments depending on the keyword.
The argument types are:
.PP
.RS 4
.nf
.BR "Integer " "an integer number in decimal, hex or octal"
.BR "Real " "a floating point number"
.BR "String " "a string enclosed in double quote marks (\*q)"
.fi
.RE
.PP
Note: hex integer values must be prefixed with \(lq0x\(rq, and octal values
with \(lq0\(rq.
.PP
A special keyword called
.B Option
may be used to provide free\-form data to various components of the server.
The
.B Option
keyword takes either one or two string arguments.
The first is the option name, and the optional second argument is the
option value.
Some commonly used option value types include:
.PP
.RS 4
.nf
.BR "String " "a sequence of characters"
.BR "Boolean " "a boolean value (see below)"
.BR "Frequency " "a frequency value (see below)"
.fi
.RE
.PP
Note that
.I all
.B Option
values, not just strings, must be enclosed in quotes.
.PP
Boolean options may optionally have a value specified.
When no value is specified, the option's value is
.BR TRUE .
The following boolean option values are recognised as
.BR TRUE :
.PP
.RS 4
.BR 1 ,
.BR on ,
.BR true ,
.B yes
.RE
.PP
and the following boolean option values are recognised as
.BR FALSE :
.PP
.RS 4
.BR 0 ,
.BR off ,
.BR false ,
.B no
.RE
.PP
If an option name is prefixed with
.RB \*q No \*q,
then the option value is negated.
.PP
Example: the following option entries are equivalent:
.PP
.RS 4
.nf
.B "Option \*qAccel\*q \*qOff\*q"
.B "Option \*qNoAccel\*q"
.B "Option \*qNoAccel\*q \*qOn\*q"
.B "Option \*qAccel\*q \*qfalse\*q"
.B "Option \*qAccel\*q \*qno\*q"
.fi
.RE
.PP
Frequency option values consist of a real number that is optionally
followed by one of the following frequency units:
.PP
.RS 4
.BR Hz ,
.BR k ,
.BR kHz ,
.BR M ,
.B MHz
.RE
.PP
When the unit name is omitted, the correct units will be determined from
the value and the expectations of the appropriate range of the value.
It is recommended that the units always be specified when using frequency
option values to avoid any errors in determining the value.
.SH "FILES SECTION"
The
.B Files
section is used to specify some path names required by the server.
Some of these paths can also be set from the command line (see
.BR Xserver (1)
and
.BR Xorg (1)).
The command line settings override the values specified in the config
file.
The
.B Files
section is optional, as are all of the entries that may appear in it.
.PP
The entries that can appear in this section are:
.TP 7
.BI "FontPath \*q" path \*q
sets the search path for fonts.
This path is a comma separated list of font path elements which the Xorg
server searches for font databases.
Multiple
.B FontPath
entries may be specified, and they will be concatenated to build up the
fontpath used by the server. Font path elements can be absolute
directory paths, catalogue directories or a font server identifier. The
formats of the later two are explained below:
.PP
.RS 7
Catalogue directories:
.PP
.RS 4
Catalogue directories can be specified using the prefix \fBcatalogue:\fR
before the directory name. The directory can then be populated with
symlinks pointing to the real font directories, using the following
syntax in the symlink name:
.PP
.RS 4
.IR <identifier> : [attribute]: pri= <priority>
.RE
.PP
where
.I <identifier>
is an alphanumeric identifier,
.I [attribute]
is an attribute which will be passed to the underlying FPE and
.I <priority>
is a number used to order the fontfile FPEs. Examples:
.PP
.RS 4
.nf
.I 75dpi:unscaled:pri=20 -> /usr/share/X11/fonts/75dpi
.I gscript:pri=60 -> /usr/share/fonts/default/ghostscript
.I misc:unscaled:pri=10 \-> /usr/share/X11/fonts/misc
.fi
.PP
.RE .RE .RE
.PP
.RS 7
Font server identifiers:
.PP
.RS 4
Font server identifiers have the form:
.RS 4
.PP
.IR <trans> / <hostname> : <port\-number>
.RE
.PP
where
.I <trans>
is the transport type to use to connect to the font server (e.g.,
.B unix
for UNIX\-domain sockets or
.B tcp
for a TCP/IP connection),
.I <hostname>
is the hostname of the machine running the font server, and
.I <port\-number>
is the port number that the font server is listening on (usually 7100).
.RE
.PP
When this entry is not specified in the config file, the server falls back
to the compiled\-in default font path, which contains the following
font path elements (which can be set inside a catalogue directory):
.PP
.RS 4
.nf
.I /usr/lib/X11/fonts/misc/
.I /usr/lib/X11/fonts/TTF/
.I /usr/lib/X11/fonts/Type1/
.I /usr/lib/X11/fonts/75dpi/
.I /usr/lib/X11/fonts/100dpi/
.fi
.RE
.PP
The recommended font path contains the following font path elements:
.PP
.RS 4
.nf
.I /usr/lib/X11/fonts/local/
.I /usr/lib/X11/fonts/75dpi/:unscaled
.I /usr/lib/X11/fonts/100dpi/:unscaled
.fi
.RE
.PP
Font path elements that are found to be invalid are removed from the
font path when the server starts up.
.RE
.TP 7
.BI "ModulePath \*q" path \*q
sets the search path for loadable Xorg server modules.
This path is a comma separated list of directories which the Xorg server
searches for loadable modules loading in the order specified.
Multiple
.B ModulePath
entries may be specified, and they will be concatenated to build the
module search path used by the server.
.\" The LogFile keyword is not currently implemented
.ig
.TP 7
.BI "LogFile \*q" path \*q
sets the name of the Xorg server log file.
The default log file name is
.PP
.RS 11
.RI /var/log/Xorg. <n> .log
.RE
.PP
.RS 7
where
.I <n>
is the display number for the Xorg server.
.SH "SERVERFLAGS SECTION"
In addition to options specific to this section (described below), the
.B ServerFlags
section is used to specify some global
Xorg server options.
All of the entries in this section are
.BR Options ,
although for compatibility purposes some of the old style entries are
still recognised.
Those old style entries are not documented here, and using them is
discouraged.
The
.B ServerFlags
section is optional, as are the entries that may be specified in it.
.PP
.B Options
specified in this section (with the exception of the
.B \*qDefaultServerLayout\*q
.BR Option )
may be overridden by
.B Options
specified in the active
.B ServerLayout
section.
Options with command line equivalents are overridden when their command
line equivalent is used.
The options recognised by this section are:
.TP 7
.BI "Option \*qDefaultServerLayout\*q \*q" layout\-id \*q
This specifies the default
.B ServerLayout
section to use in the absence of the
.B \-layout
command line option.
.TP 7
.BI "Option \*qNoTrapSignals\*q \*q" boolean \*q
This prevents the Xorg server from trapping a range of unexpected fatal
signals and exiting cleanly.
Instead, the Xorg server will die and drop core where the fault occurred.
The default behaviour is for the Xorg server to exit cleanly, but still drop a
core file.
In general you never want to use this option unless you are debugging an Xorg
server problem and know how to deal with the consequences.
.TP 7
.BI "Option \*qDontVTSwitch\*q \*q" boolean \*q
This disallows the use of the
.BI Ctrl+Alt+F n
sequence (where
.RI F n
refers to one of the numbered function keys).
That sequence is normally used to switch to another \*qvirtual terminal\*q
on operating systems that have this feature.
When this option is enabled, that key sequence has no special meaning and
is passed to clients.
Default: off.
.TP 7
.BI "Option \*qDontZap\*q \*q" boolean \*q
.B Terminate_Server
XKB action (usually on Ctrl+Alt+Backspace, depending on XKB options).
This action is normally used to terminate the Xorg server.
When this option is enabled, the action has no effect.
Default: off.
.TP 7
.BI "Option \*qZapWarning\*q \*q" boolean \*q
This warns the user loudly when the
.B Ctrl+Alt+Backspace
sequence is pressed for the first time but still terminates the Xorg
server when this key-sequence is pressed again shortly after.
Default: on.
.TP 7
.BI "Option \*qDontZoom\*q \*q" boolean \*q
.B Ctrl+Alt+Keypad\-Plus
and
.B Ctrl+Alt+Keypad\-Minus
sequences.
These sequences allows you to switch between video modes.
When this option is enabled, those key sequences have no special meaning
and are passed to clients.
Default: off.
.TP 7
.BI "Option \*qDisableVidModeExtension\*q \*q" boolean \*q
This disables the parts of the VidMode extension used by the xvidtune client
that can be used to change the video modes.
Default: the VidMode extension is enabled.
.TP 7
.BI "Option \*qAllowNonLocalXvidtune\*q \*q" boolean \*q
This allows the xvidtune client (and other clients that use the VidMode
extension) to connect from another host.
Default: off.
.TP 7
.BI "Option \*qAllowMouseOpenFail\*q \*q" boolean \*q
This allows the server to start up even if the mouse device can't be
opened/initialised.
Default: false.
.TP 7
.BI "Option \*qVTSysReq\*q \*q" boolean \*q
enables the SYSV\-style VT switch sequence for non\-SYSV systems
which support VT switching.
This sequence is
.B Alt\-SysRq
followed by a function key
.RB ( Fn ).
This prevents the Xorg server trapping the
keys used for the default VT switch sequence, which means that clients can
access them.
Default: off.
.TP 7
.BI "Option \*qXkbDisable\*q \*q" boolean \*q
disable/enable the XKEYBOARD extension.
The \-kb command line option overrides this config file option.
Default: XKB is enabled.
.\" The following four options are "undocumented".
.ig
.TP 7
.BI "Option \*qPciProbe1\*q"
Use PCI probe method 1.
Default: set.
.TP 7
.BI "Option \*qPciProbe2\*q"
Use PCI probe method 2.
Default: not set.
.TP 7
.BI "Option \*qPciForceConfig1\*q"
Force the use PCI config type 1.
Default: not set.
.TP 7
.BI "Option \*qPciForceConfig2\*q"
Force the use PCI config type 2.
Default: not set.
.TP 7
.BI "Option \*qBlankTime\*q \*q" time \*q
sets the inactivity timeout for the
.B blank
phase of the screensaver.
.I time
is in minutes.
This is equivalent to the Xorg server's
.B \-s
flag, and the value can be changed at run\-time with
.BR xset(1).
Default: 10 minutes.
.TP 7
.BI "Option \*qStandbyTime\*q \*q" time \*q
.B standby
phase of DPMS mode.
.I time
is in minutes, and the value can be changed at run\-time with
.BR xset(1).
Default: 20 minutes.
This is only suitable for VESA DPMS compatible monitors, and may not be
supported by all video drivers.
It is only enabled for screens that have the
.B \*qDPMS\*q
option set (see the MONITOR section below).
.TP 7
.BI "Option \*qSuspendTime\*q \*q" time \*q
.B suspend
phase of DPMS mode.
.I time
.BR xset(1).
Default: 30 minutes.
.B \*qDPMS\*q
.TP 7
.BI "Option \*qOffTime\*q \*q" time \*q
.B off
phase of DPMS mode.
.I time
.BR xset(1).
Default: 40 minutes.
.B \*qDPMS\*q
.TP 7
.BI "Option \*qPixmap\*q \*q" bpp \*q
This sets the pixmap format to use for depth 24.
Allowed values for
.I bpp
are 24 and 32.
Default: 32 unless driver constraints don't allow this (which is rare).
Note: some clients don't behave well when this value is set to 24.
.TP 7
.BI "Option \*qPC98\*q \*q" boolean \*q
Specify that the machine is a Japanese PC\-98 machine.
This should not be enabled for anything other than the Japanese\-specific
PC\-98 architecture.
Default: auto\-detected.
.\" Doubt this should be documented.
.ig
.TP 7
.BI "Option \*qEstimateSizesAggressively\*q \*q" value \*q
This option affects the way that bus resource sizes are estimated.
Default: 0.
.TP 7
.BI "Option \*qNoPM\*q \*q" boolean \*q
Disables something to do with power management events.
Default: PM enabled on platforms that support it.
.TP 7
.BI "Option \*qXinerama\*q \*q" boolean \*q
enable or disable XINERAMA extension.
Default is disabled.
.TP 7
.BI "Option \*qHandleSpecialKeys\*q \*q" when \*q
This option controls when the server uses the builtin handler to process
special key combinations (such as
.BR Ctrl+Alt+Backspace ).
Normally the XKEYBOARD extension keymaps will provide mappings for each of
the special key combinations, so the builtin handler is not needed unless
the XKEYBOARD extension is disabled.
The value of
.I when
can be
.BR Always ,
.BR Never ,
or
.BR WhenNeeded .
Default: Use the builtin handler only if needed.
The server will scan the keymap for a mapping to the
.B Terminate
action and, if found, use XKEYBOARD for processing actions, otherwise
the builtin handler will be used.
.TP 7
.BI "Option \*qAIGLX\*q \*q" boolean \*q
enable or disable AIGLX. AIGLX is enabled by default.
.TP 7
.BI "Option \*qGlxVisuals\*q \*q" string \*q
This option controls how many GLX visuals the GLX modules sets up.
The default value is
.BR "typical" ,
which will setup up a typical subset of
the GLXFBConfigs provided by the driver as GLX visuals. Other options are
.BR "minimal" ,
which will set up the minimal set allowed by the GLX specification and
.BR "all"
which will setup GLX visuals for all GLXFBConfigs.
.TP 7
.BI "Option \*qUseDefaultFontPath\*q \*q" boolean \*q
Include the default font path even if other paths are specified in
xorg.conf. If enabled, other font paths are included as well. Enabled by
default.
.TP 7
.BI "Option \*qIgnoreABI\*q \*q" boolean \*q
Allow modules built for a different, potentially incompatible version of
the X server to load. Disabled by default.
.TP 7
.BI "Option \*qAllowEmptyInput\*q \*q" boolean \*q
If enabled, don't add the standard keyboard and mouse drivers, if there are no
input devices in the config file. Enabled by default if AutoAddDevices and
AutoEnableDevices is enabled, otherwise disabled.
If AllowEmptyInput is on, devices using the kbd, mouse or vmmouse driver are ignored.
.TP 7
.BI "Option \*qAutoAddDevices\*q \*q" boolean \*q
If this option is disabled, then no devices will be added from HAL events.
Enabled by default.
.TP 7
.BI "Option \*qAutoEnableDevices\*q \*q" boolean \*q
If this option is disabled, then the devices will be added (and the
DevicePresenceNotify event sent), but not enabled, thus leaving policy up
to the client.
Enabled by default.
.TP 7
.BI "Option \*qLog\*q \*q" string \*q
This option controls whether the log is flushed and/or synced to disk after
each message.
Possible values are
.B flush
or
.BR sync .
Unset by default.
.SH "MODULE SECTION"
The
.B Module
section is used to specify which Xorg server modules should be loaded.
This section is ignored when the Xorg server is built in static form.
The types of modules normally loaded in this section are Xorg server
extension modules, and font rasteriser modules.
Most other module types are loaded automatically when they are needed via
other mechanisms.
The
.B Module
section is optional, as are all of the entries that may be specified in
it.
.PP
Entries in this section may be in two forms.
The first and most commonly used form is an entry that uses the
.B Load
keyword, as described here:
.TP 7
.BI "Load \*q" modulename \*q
This instructs the server to load the module called
.IR modulename .
The module name given should be the module's standard name, not the
module file name.
The standard name is case\-sensitive, and does not include the \(lqlib\(rq
prefix, or the \(lq.a\(rq, \(lq.o\(rq, or \(lq.so\(rq suffixes.
.PP
.RS 7
Example: the FreeType font rasteriser can be loaded with the following entry:
.PP
.RS 4
.B "Load \*qfreetype\*q"
.RE
.RE
.TP 7
.BI "Disable \*q" modulename \*q
This instructs the server to not load the module called
.IR modulename .
Some modules are loaded by default in the server, and this overrides that
default. If a
.B Load
instruction is given for the same module, it overrides the
.B Disable
instruction and the module is loaded. The module name given should be the
module's standard name, not the module file name. As with the
.B Load
instruction, the standard name is case-sensitive, and does not include the
"lib" prefix, or the ".a", ".o", or ".so" suffixes.
.PP
The second form of entry is a
.BR SubSection,
with the subsection name being the module name, and the contents of the
.B SubSection
being
.B Options
that are passed to the module when it is loaded.
.PP
Example: the extmod module (which contains a miscellaneous group of
server extensions) can be loaded, with the XFree86\-DGA extension
disabled by using the following entry:
.PP
.RS 4
.nf
.B "SubSection \*qextmod\*q"
.B " Option \*qomit XFree86\-DGA\*q"
.B EndSubSection
.fi
.RE
.PP
Modules are searched for in each directory specified in the
.B ModulePath
search path, and in the drivers, input, extensions, fonts, and
internal subdirectories of each of those directories.
In addition to this, operating system specific subdirectories of all
the above are searched first if they exist.
.PP
To see what font and extension modules are available, check the contents
of the following directories:
.PP
.RS 4
.nf
/usr/lib/modules/fonts
/usr/lib/modules/extensions
.fi
.RE
.PP
The \(lqextmod\(rq, \(lqdbe\(rq, \(lqglx\(rq, and \(lqdri\(rq extension
modules are loaded automatically, unless disabled with \*qDisable\*q entries.
It is recommended
that at very least the \(lqextmod\(rq extension module be loaded.
If it isn't, some commonly used server extensions (like the SHAPE
extension) will not be available.
.SH "EXTENSIONS SECTION"
The
.B Extensions
section is used to specify which X11 protocol extensions should be enabled
or disabled.
The
.B Extensions
it.
.PP
Entries in this section are listed as Option statements with the name of
the extension as the first argument, and a boolean value as the second.
The extension name is case\-sensitive, and matches the form shown in the output
of \*qXorg -extension ?\*q.
.PP
.RS 7
Example: the MIT-SHM extension can be disabled with the following entry:
.PP
.RS 4
.nf
.B "Section \*qExtensions\*q"
.B " Option \*qMIT-SHM\*q \*qDisable\*q"
.B "EndSection"
.fi
.RE
.RE
.SH "INPUTDEVICE SECTION"
The config file may have multiple
.B InputDevice
sections.
There will normally be at least two: one for the core (primary) keyboard,
and one of the core pointer.
If either of these two is missing, a default configuration for the missing
ones will be used.
Currently the default configuration may not work as expected on all platforms.
.PP
.B InputDevice
.PP
.RS 4
.nf
.B "Section \*qInputDevice\*q"
.BI " Identifier \*q" name \*q
.BI " Driver \*q" inputdriver \*q
.I " options"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
and
.B Driver
entries are required in all
.B InputDevice
sections.
.PP
The
.B Identifier
entry specifies the unique name for this input device.
The
.B Driver
entry specifies the name of the driver to use for this input device.
When using the loadable server, the input driver module
.RI \*q inputdriver \*q
will be loaded for each active
.B InputDevice
section.
An
.B InputDevice
section is considered active if it is referenced by an active
.B ServerLayout
section, if it is referenced by the
.B \-keyboard
or
.B \-pointer
command line options, or if it is selected implicitly as the core pointer
or keyboard device in the absence of such explicit references.
The most commonly used input drivers are
.BR evdev (4)
on Linux systems, and
.BR kbd (4)
and
.BR mouse (4)
on other platforms.
.PP
In the absence of an explicitly specified core input device, the first
.B InputDevice
marked as
.B CorePointer
(or
.BR CoreKeyboard )
is used.
If there is no match there, the first
.B InputDevice
that uses the \(lqmouse\(rq (or \(lqkbd\(rq) driver is used.
The final fallback is to use built\-in default configurations.
.PP
.B InputDevice
.BR Options ,
which are described here.
See the individual input driver manual pages for a description of the
.TP 7
.BI "Option \*qCorePointer\*q"
When this is set, the input device is installed as the core (primary)
pointer device.
There must be exactly one core pointer.
If this option is not set here, or in the
.B ServerLayout
section, or from the
.B \-pointer
command line option, then the first input device that is capable of
being used as a core pointer will be selected as the core pointer.
This option is implicitly set when the obsolete
.B Pointer
section is used.
.TP 7
.BI "Option \*qCoreKeyboard\*q"
When this is set, the input device is to be installed as the core
(primary) keyboard device.
There must be exactly one core keyboard.
If this option is not set here, in the
.B ServerLayout
.B \-keyboard
being used as a core keyboard will be selected as the core keyboard.
.B Keyboard
section is used.
.TP 7
.BI "Option \*qAlwaysCore\*q \*q" boolean \*q
.TP 7
.BI "Option \*qSendCoreEvents\*q \*q" boolean \*q
Both of these options are equivalent, and when enabled cause the
input device to always report core events.
This can be used, for example, to allow an additional pointer device to
generate core pointer events (like moving the cursor, etc).
.TP 4
.BI "Option \*qHistorySize\*q \*q" number \*q
Sets the motion history size.
Default: 0.
.TP 7
.BI "Option \*qSendDragEvents\*q \*q" boolean \*q
.SH "DEVICE SECTION"
.B Device
sections.
There must be at least one, for the video card being used.
.PP
.B Device
.PP
.RS 4
.nf
.B "Section \*qDevice\*q"
.BI " Driver \*q" driver \*q
.I " entries"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
and
.B Driver
.B Device
sections. All other entries are optional.
.PP
The
.B Identifier
entry specifies the unique name for this graphics device.
The
.B Driver
entry specifies the name of the driver to use for this graphics device.
When using the loadable server, the driver module
.RI \*q driver \*q
.B Device
section.
A
.B Device
.B Screen
section.
.PP
.B Device
sections recognise some driver\-independent entries and
.BR Options ,
Not all drivers make use of these
driver\-independent entries, and many of those that do don't require them
to be specified because the information is auto\-detected.
See the individual graphics driver manual pages for further information
about this, and for a description of the device\-specific options.
Note that most of the
.B Options
listed here (but not the other entries) may be specified in the
.B Screen
section instead of here in the
.B Device
section.
.TP 7
.BI "BusID \*q" bus\-id \*q
This specifies the bus location of the graphics card.
For PCI/AGP cards,
the
.I bus\-id
string has the form
.BI PCI: bus : device : function
(e.g., \(lqPCI:1:0:0\(rq might be appropriate for an AGP card).
This field is usually optional in single-head configurations when using
In multi-head configurations, or when using a secondary graphics card in a
single-head configuration, this entry is mandatory.
Its main purpose is to make an unambiguous connection between the device
section and the hardware it is representing.
This information can usually be found by running the pciaccess tool
scanpci.
.TP 7
.BI "Screen " number
This option is mandatory for cards where a single PCI entity can drive more
than one display (i.e., multiple CRTCs sharing a single graphics accelerator
and video memory).
One
.B Device
section is required for each head, and this
parameter determines which head each of the
.B Device
sections applies to.
The legal values of
.I number
range from 0 to one less than the total number of heads per entity.
Most drivers require that the primary screen (0) be present.
.TP 7
.BI "Chipset \*q" chipset \*q
This usually optional entry specifies the chipset used on the graphics
board.
In most cases this entry is not required because the drivers will probe the
hardware to determine the chipset type.
Don't specify it unless the driver-specific documentation recommends that you
do.
.TP 7
.BI "Ramdac \*q" ramdac\-type \*q
This optional entry specifies the type of RAMDAC used on the graphics
board.
This is only used by a few of the drivers, and in most cases it is not
required because the drivers will probe the hardware to determine the
RAMDAC type where possible.
do.
.TP 7
.BI "DacSpeed " speed
.TP 7
.BI "DacSpeed " "speed\-8 speed\-16 speed\-24 speed\-32"
This optional entry specifies the RAMDAC speed rating (which is usually
printed on the RAMDAC chip).
The speed is in MHz.
When one value is given, it applies to all framebuffer pixel sizes.
When multiple values are given, they apply to the framebuffer pixel sizes
8, 16, 24 and 32 respectively.
This is not used by many drivers, and only needs to be specified when the
speed rating of the RAMDAC is different from the defaults built in to
driver, or when the driver can't auto-detect the correct defaults.
do.
.TP 7
.BI "Clocks " "clock ..."
specifies the pixel that are on your graphics board.
The clocks are in MHz, and may be specified as a floating point number.
The value is stored internally to the nearest kHz.
The ordering of the clocks is important.
It must match the order in which they are selected on the graphics board.
Multiple
.B Clocks
lines may be specified, and each is concatenated to form the list.
Most drivers do not use this entry, and it is only required for some older
boards with non-programmable clocks.
Don't specify this entry unless the driver-specific documentation explicitly
recommends that you do.
.TP
.BI "ClockChip \*q" clockchip\-type \*q
This optional entry is used to specify the clock chip type on graphics
boards which have a programmable clock generator.
Only a few Xorg drivers support programmable clock chips.
For details, see the appropriate driver manual page.
.TP 7
.BI "VideoRam " "mem"
This optional entry specifies the amount of video ram that is installed
This is measured in kBytes.
In most cases this is not required because the Xorg server probes
the graphics board to determine this quantity.
The driver-specific documentation should indicate when it might be needed.
.TP 7
.BI "BiosBase " "baseaddress"
This optional entry specifies the base address of the video BIOS for
the VGA board.
This address is normally auto-detected, and should only be specified if the
driver-specific documentation recommends it.
.TP 7
.BI "MemBase " "baseaddress"
This optional entry specifies the memory base address of a graphics
board's linear frame buffer.
This entry is not used by many drivers, and it should only be specified if
the driver-specific documentation recommends it.
.TP 7
.BI "IOBase " "baseaddress"
This optional entry specifies the IO base address.
.TP 7
.BI "ChipID " "id"
This optional entry specifies a numerical ID representing the chip type.
For PCI cards, it is usually the device ID.
This can be used to override the auto-detection, but that should only be done
when the driver-specific documentation recommends it.
.TP 7
.BI "ChipRev " "rev"
This optional entry specifies the chip revision number.
.TP 7
.BI "TextClockFreq " "freq"
This optional entry specifies the pixel clock frequency that is used
for the regular text mode.
The frequency is specified in MHz.
This is rarely used.
.TP 7
.BI "Option \*qModeDebug\*q \*q" boolean \*q
Enable printing of additional debugging information about modesetting to
the server log.
.ig
.TP 7
This optional entry allows an IRQ number to be specified.
.TP 7
.B Options
Option flags may be specified in the
.B Device
sections.
These include driver\-specific options and driver\-independent options.
The former are described in the driver\-specific documentation.
Some of the latter are described below in the section about the
.B Screen
section, and they may also be included here.
.SH "VIDEOADAPTOR SECTION"
Nobody wants to say how this works.
Maybe nobody knows ...
.SH "MONITOR SECTION"
.B Monitor
sections.
There should normally be at least one, for the monitor being used,
but a default configuration will be created when one isn't specified.
.PP
.B Monitor
.PP
.RS 4
.nf
.B "Section \*qMonitor\*q"
.I " entries"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The only mandatory entry in a
.B Monitor
section is the
.B Identifier
entry.
.PP
The
.B Identifier
entry specifies the unique name for this monitor.
The
.B Monitor
section may be used to provide information about the specifications of the
monitor, monitor-specific
.BR Options ,
and information about the video modes to use with the monitor.
.PP
With RandR 1.2-enabled drivers, monitor sections may be tied to specific
outputs of the video card. Using the name of the output defined by the video
driver plus the identifier of a monitor section, one associates a monitor
section with an output by adding an option to the Device section in the
following format:
.B Option \*qMonitor-outputname\*q \*qmonitorsection\*q
(for example,
.B Option \*qMonitor-VGA\*q \*qVGA monitor\*q
for a VGA output)
.PP
In the absence of specific association of monitor sections to outputs, if a
monitor section is present the server will associate it with an output to
preserve compatibility for previous single-head configurations.
.PP
Specifying video modes is optional because the server will use the DDC or other
information provided by the monitor to automatically configure the list of
modes available.
When modes are specified explicitly in the
.B Monitor
section (with the
.BR Modes ,
.BR ModeLine ,
or
.B UseModes
keywords), built-in modes with the same names are not included.
Built-in modes with different names are, however, still implicitly included,
when they meet the requirements of the monitor.
.PP
.B Monitor
sections are described below.
.TP 7
.BI "VendorName \*q" vendor \*q
This optional entry specifies the monitor's manufacturer.
.TP 7
.BI "ModelName \*q" model \*q
This optional entry specifies the monitor's model.
.TP 7
.BI "HorizSync " "horizsync\-range"
gives the range(s) of horizontal sync frequencies supported by the
monitor.
.I horizsync\-range
may be a comma separated list of either discrete values or ranges of
values.
A range of values is two values separated by a dash.
By default the values are in units of kHz.
They may be specified in MHz or Hz
if
.B MHz
or
.B Hz
is added to the end of the line.
The data given here is used by the Xorg server to determine if video
modes are within the specifications of the monitor.
This information should be available in the monitor's handbook.
If this entry is omitted, a default range of 28\-33kHz is used.
.TP 7
.BI "VertRefresh " "vertrefresh\-range"
gives the range(s) of vertical refresh frequencies supported by the
monitor.
.I vertrefresh\-range
values.
By default the values are in units of Hz.
They may be specified in MHz or kHz
if
.B MHz
or
.B kHz
If this entry is omitted, a default range of 43\-72Hz is used.
.TP 7
.BI "DisplaySize " "width height"
This optional entry gives the width and height, in millimetres, of the
picture area of the monitor.
If given this is used to calculate the horizontal and vertical pitch (DPI) of
the screen.
.TP 7
.BI "Gamma " "gamma\-value"
.TP 7
.BI "Gamma " "red\-gamma green\-gamma blue\-gamma"
This is an optional entry that can be used to specify the gamma correction
for the monitor.
It may be specified as either a single value or as three separate RGB values.
The values should be in the range 0.1 to 10.0, and the default is 1.0.
Not all drivers are capable of using this information.
.TP 7
.BI "UseModes \*q" modesection\-id \*q
Include the set of modes listed in the
.B Modes
section called
.IR modesection\-id.
This makes all of the modes defined in that section available for use by
this monitor.
.TP 7
.BI "Mode \*q" name \*q
This is an optional multi-line entry that can be used to provide
definitions for video modes for the monitor.
In most cases this isn't necessary because the built-in set of VESA standard
The
.B Mode
keyword indicates the start of a multi-line video mode description.
The mode description is terminated with the
.B EndMode
keyword.
The mode description consists of the following entries:
.RS 7
.TP 4
.BI "DotClock " clock
is the dot (pixel) clock rate to be used for the mode.
.TP 4
.BI "HTimings " "hdisp hsyncstart hsyncend htotal"
specifies the horizontal timings for the mode.
.TP 4
.BI "VTimings " "vdisp vsyncstart vsyncend vtotal"
specifies the vertical timings for the mode.
.TP 4
.BI "Flags \*q" flag \*q " ..."
specifies an optional set of mode flags, each of which is a separate
string in double quotes.
.B \*qInterlace\*q
indicates that the mode is interlaced.
.B \*qDoubleScan\*q
indicates a mode where each scanline is doubled.
.B \*q+HSync\*q
and
.B \*q\-HSync\*q
can be used to select the polarity of the HSync signal.
.B \*q+VSync\*q
and
.B \*q\-VSync\*q
can be used to select the polarity of the VSync signal.
.B \*qComposite\*q
can be used to specify composite sync on hardware where this is supported.
Additionally, on some hardware,
.B \*q+CSync\*q
and
.B \*q\-CSync\*q
may be used to select the composite sync polarity.
.TP 4
.BI "HSkew " hskew
specifies the number of pixels (towards the right edge of the screen) by
which the display enable signal is to be skewed.
Not all drivers use this information.
This option might become necessary to override the default value supplied
by the server (if any).
\(lqRoving\(rq horizontal lines indicate this value needs to be increased.
If the last few pixels on a scan line appear on the left of the screen,
this value should be decreased.
.TP 4
.BI "VScan " vscan
specifies the number of times each scanline is painted on the screen.
Values less than 1 are treated as 1, which is the default.
Generally, the
.B \*qDoubleScan\*q
.B Flag
mentioned above doubles this value.
.RE
.TP 7
.BI "ModeLine \*q" name \*q " mode\-description"
This entry is a more compact version of the
.B Mode
entry, and it also can be used to specify video modes for the monitor.
is a single line format for specifying video modes.
In most cases this isn't necessary because the built\-in set of VESA
standard modes will be sufficient.
.PP
.RS 7
The
.I mode\-description
is in four sections, the first three of which are mandatory.
The first is the dot (pixel) clock.
This is a single number specifying the pixel clock rate for the mode in
MHz.
The second section is a list of four numbers specifying the horizontal
timings.
These numbers are the
.IR hdisp ,
.IR hsyncstart ,
.IR hsyncend ,
and
.I htotal
values.
The third section is a list of four numbers specifying the vertical
timings.
.IR vdisp ,
.IR vsyncstart ,
.IR vsyncend ,
and
.I vtotal
values.
The final section is a list of flags specifying other characteristics of
the mode.
.B Interlace
.B DoubleScan
.B +HSync
and
.B \-HSync
.B +VSync
and
.B \-VSync
.B Composite
.B +CSync
and
.B \-CSync
The
.B HSkew
and
.B VScan
options mentioned above in the
.B Modes
entry description can also be used here.
.RE
.TP 7
.BI "Option " "\*qDPMS\*q " \*qbool\*q
This option controls whether the server should enable the DPMS extension
for power management for this screen. The default is to enable the
extension.
.TP 7
.BI "Option " "\*qSyncOnGreen\*q " \*qbool\*q
This option controls whether the video card should drive the sync signal
on the green color pin. Not all cards support this option, and most
monitors do not require it. The default is off.
.TP 7
.BI "Option " "\*qTargetRefresh\*q " \*qrate\*q
This optional entry specifies the vertical refresh rate that the server
should aim for when selecting video modes. Without this option, the
default is to prefer modes with higher refresh rates.
.TP 7
.BI "Option " "\*qPreferredMode\*q " \*qstring\*q
This optional entry specifies a mode to be marked as the preferred initial mode
of the monitor.
(RandR 1.2-supporting drivers only)
.TP 7
.BI "Option " "\*qPosition\*q " "\*qx y\*q"
This optional entry specifies the position of the monitor within the X
screen.
.TP 7
.BI "Option " "\*qLeftOf\*q " \*qoutput\*q
This optional entry specifies that the monitor should be positioned to the
left of the output (not monitor) of the given name.
.TP 7
.BI "Option " "\*qRightOf\*q " \*qoutput\*q
right of the output (not monitor) of the given name.
.TP 7
.BI "Option " "\*qAbove\*q " \*qoutput\*q
This optional entry specifies that the monitor should be positioned above the
.TP 7
.BI "Option " "\*qBelow\*q " \*qoutput\*q
This optional entry specifies that the monitor should be positioned below the
.TP 7
.BI "Option " "\*qEnable\*q " \*qbool\*q
This optional entry specifies whether the monitor should be turned on
at startup. By default, the server will attempt to enable all connected
monitors.
.TP 7
.BI "Option " "\*qMinClock\*q " \*qfrequency\*q
This optional entry specifies the minimum dot clock, in kHz, that is supported
by the monitor.
.TP 7
.BI "Option " "\*qMaxClock\*q " \*qfrequency\*q
This optional entry specifies the maximum dot clock, in kHz, that is supported
by the monitor.
.TP 7
.BI "Option " "\*qIgnore\*q " \*qbool\*q
This optional entry specifies that the monitor should be ignored entirely,
and not reported through RandR. This is useful if the hardware reports the
presence of outputs that don't exist.
.TP 7
.BI "Option " "\*qRotate\*q " \*qrotation\*q
This optional entry specifies the initial rotation of the given monitor.
Valid values for rotation are \*qnormal\*q, \*qleft\*q, \*qright\*q, and
\*qinverted\*q.
.SH "MODES SECTION"
.B Modes
sections, or none.
These sections provide a way of defining sets of video modes independently
of the
.B Monitor
sections.
.B Monitor
sections may include the definitions provided in these sections by
using the
.B UseModes
keyword.
In most cases the
.B Modes
sections are not necessary because the built\-in set of VESA standard modes
will be sufficient.
.PP
.B Modes
.PP
.RS 4
.nf
.B "Section \*qModes\*q"
.I " entries"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
entry specifies the unique name for this set of mode descriptions.
The other entries permitted in
.B Modes
sections are the
.B Mode
and
.B ModeLine
entries that are described above in the
.B Monitor
section.
.SH "SCREEN SECTION"
.B Screen
sections.
There must be at least one, for the \(lqscreen\(rq being used.
A \(lqscreen\(rq represents the binding of a graphics device
.RB ( Device
section) and a monitor
.RB ( Monitor
section).
A
.B Screen
section is considered \(lqactive\(rq if it is referenced by an active
.B ServerLayout
section or by the
.B \-screen
If neither of those is present, the first
.B Screen
section found in the config file is considered the active one.
.PP
.B Screen
.PP
.RS 4
.nf
.B "Section \*qScreen\*q"
.BI " Device \*q" devid \*q
.BI " Monitor \*q" monid \*q
.I " entries"
.I " ..."
.BI " SubSection \*qDisplay\*q"
.I " entries"
.I " ...
.B " EndSubSection"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
The
.B Identifier
and
.B Device
entries are mandatory.
All others are optional.
.PP
The
.B Identifier
entry specifies the unique name for this screen.
The
.B Screen
section provides information specific to the whole screen, including
screen\-specific
.BR Options .
In multi\-head configurations, there will be multiple active
.B Screen
sections, one for each head.
The entries available
for this section are:
.TP 7
.BI "Device \*q" device\-id \*q
This mandatory entry specifies the
.B Device
section to be used for this screen.
This is what ties a specific graphics card to a screen.
The
.I device\-id
must match the
.B Identifier
of a
.B Device
section in the config file.
.TP 7
.BI "Monitor \*q" monitor\-id \*q
specifies which monitor description is to be used for this screen.
If a
.B Monitor
name is not specified, a default configuration is used.
Currently the default configuration may not function as expected on all
platforms.
.TP 7
.BI "VideoAdaptor \*q" xv\-id \*q
specifies an optional Xv video adaptor description to be used with this
screen.
.TP 7
.BI "DefaultDepth " depth
specifies which color depth the server should use by default.
The
.B \-depth
command line option can be used to override this.
If neither is specified, the default depth is driver\-specific, but in most
cases is 8.
.TP 7
.BI "DefaultFbBpp " bpp
specifies which framebuffer layout to use by default.
The
.B \-fbbpp
In most cases the driver will chose the best default value for this.
The only case where there is even a choice in this value is for depth 24,
where some hardware supports both a packed 24 bit framebuffer layout and a
sparse 32 bit framebuffer layout.
.TP 7
.B Options
Various
.B Option
.B Screen
section.
Some are driver\-specific and are described in the driver documentation.
Others are driver\-independent, and will eventually be described here.
.\" XXX These should really be in an xaa man page.
.TP 7
.BI "Option \*qAccel\*q"
Enables XAA (X Acceleration Architecture), a mechanism that makes video cards'
2D hardware acceleration available to the Xorg server.
This option is on by default, but it may be necessary to turn it off if
there are bugs in the driver.
There are many options to disable specific accelerated operations, listed
below.
Note that disabling an operation will have no effect if the operation is
not accelerated (whether due to lack of support in the hardware or in the
driver).
.TP 7
.BI "Option \*qInitPrimary\*q \*q" boolean \*q
Use the Int10 module to initialize the primary graphics card.
Normally, only secondary cards are soft-booted using the Int10 module, as the
primary card has already been initialized by the BIOS at boot time.
Default: false.
.TP 7
.BI "Option \*qNoInt10\*q \*q" boolean \*q
Disables the Int10 module, a module that uses the int10 call to the BIOS
of the graphics card to initialize it.
Default: false.
.TP 7
.BI "Option \*qNoMTRR\*q"
Disables MTRR (Memory Type Range Register) support, a feature of modern
processors which can improve video performance by a factor of up to 2.5.
Some hardware has buggy MTRR support, and some video drivers have been
known to exhibit problems when MTRR's are used.
.TP 7
.BI "Option \*qXaaNoCPUToScreenColorExpandFill\*q"
Disables accelerated rectangular expansion blits from source patterns
stored in system memory (using a memory\-mapped aperture).
.TP 7
.BI "Option \*qXaaNoColor8x8PatternFillRect\*q"
Disables accelerated fills of a rectangular region with a full\-color
pattern.
.TP 7
.BI "Option \*qXaaNoColor8x8PatternFillTrap\*q"
Disables accelerated fills of a trapezoidal region with a full\-color
pattern.
.TP 7
.BI "Option \*qXaaNoDashedBresenhamLine\*q"
Disables accelerated dashed Bresenham line draws.
.TP 7
.BI "Option \*qXaaNoDashedTwoPointLine\*q"
Disables accelerated dashed line draws between two arbitrary points.
.TP 7
.BI "Option \*qXaaNoImageWriteRect\*q"
Disables accelerated transfers of full\-color rectangular patterns from
system memory to video memory (using a memory\-mapped aperture).
.TP 7
.BI "Option \*qXaaNoMono8x8PatternFillRect\*q"
Disables accelerated fills of a rectangular region with a monochrome
pattern.
.TP 7
.BI "Option \*qXaaNoMono8x8PatternFillTrap\*q"
Disables accelerated fills of a trapezoidal region with a monochrome
pattern.
.TP 7
.BI "Option \*qXaaNoOffscreenPixmaps\*q"
Disables accelerated draws into pixmaps stored in offscreen video memory.
.TP 7
.BI "Option \*qXaaNoPixmapCache\*q"
Disables caching of patterns in offscreen video memory.
.TP 7
.BI "Option \*qXaaNoScanlineCPUToScreenColorExpandFill\*q"
stored in system memory (one scan line at a time).
.TP 7
.BI "Option \*qXaaNoScanlineImageWriteRect\*q"
system memory to video memory (one scan line at a time).
.TP 7
.BI "Option \*qXaaNoScreenToScreenColorExpandFill\*q"
.TP 7
.BI "Option \*qXaaNoScreenToScreenCopy\*q"
Disables accelerated copies of rectangular regions from one part of
video memory to another part of video memory.
.TP 7
.BI "Option \*qXaaNoSolidBresenhamLine\*q"
Disables accelerated solid Bresenham line draws.
.TP 7
.BI "Option \*qXaaNoSolidFillRect\*q"
Disables accelerated solid\-color fills of rectangles.
.TP 7
.BI "Option \*qXaaNoSolidFillTrap\*q"
Disables accelerated solid\-color fills of Bresenham trapezoids.
.TP 7
.BI "Option \*qXaaNoSolidHorVertLine\*q"
Disables accelerated solid horizontal and vertical line draws.
.TP 7
.BI "Option \*qXaaNoSolidTwoPointLine\*q"
Disables accelerated solid line draws between two arbitrary points.
.PP
Each
.B Screen
section may optionally contain one or more
.B Display
subsections.
Those subsections provide depth/fbbpp specific configuration information,
and the one chosen depends on the depth and/or fbbpp that is being used for
the screen.
The
.B Display
subsection format is described in the section below.
.SH "DISPLAY SUBSECTION"
Each
.B Screen
section may have multiple
.B Display
subsections.
The \(lqactive\(rq
.B Display
subsection is the first that matches the depth and/or fbbpp values being
used, or failing that, the first that has neither a depth or fbbpp value
specified.
The
.B Display
subsections are optional.
When there isn't one that matches the depth and/or fbbpp values being used,
all the parameters that can be specified here fall back to their defaults.
.PP
.B Display
subsections have the following format:
.PP
.RS 4
.nf
.B " SubSection \*qDisplay\*q"
.BI " Depth " depth
.I " entries"
.I " ..."
.B " EndSubSection"
.fi
.RE
.TP 7
.BI "Depth " depth
This entry specifies what colour depth the
.B Display
subsection is to be used for.
This entry is usually specified, but it may be omitted to create a match\-all
.B Display
subsection or when wishing to match only against the
.B FbBpp
parameter.
The range of
.I depth
values that are allowed depends on the driver.
Most drivers support 8, 15, 16 and 24.
Some also support 1 and/or 4, and some may support other values (like 30).
Note:
.I depth
means the number of bits in a pixel that are actually used to determine
the pixel colour.
32 is not a valid
.I depth
value.
Most hardware that uses 32 bits per pixel only uses 24 of them to hold the
colour information, which means that the colour depth is 24, not 32.
.TP 7
.BI "FbBpp " bpp
This entry specifies the framebuffer format this
.B Display
This entry is only needed when providing depth 24 configurations that allow
a choice between a 24 bpp packed framebuffer format and a 32bpp sparse
framebuffer format.
In most cases this entry should not be used.
.TP 7
.BI "Weight " "red\-weight green\-weight blue\-weight"
This optional entry specifies the relative RGB weighting to be used
for a screen is being used at depth 16 for drivers that allow multiple
formats.
This may also be specified from the command line with the
.B \-weight
option (see
.BR Xorg(1)).
.TP 7
.BI "Virtual " "xdim ydim"
This optional entry specifies the virtual screen resolution to be used.
.I xdim
must be a multiple of either 8 or 16 for most drivers, and a multiple
of 32 when running in monochrome mode.
The given value will be rounded down if this is not the case.
Video modes which are too large for the specified virtual size will be
rejected.
If this entry is not present, the virtual screen resolution will be set to
accommodate all the valid video modes given in the
.B Modes
entry.
Some drivers/hardware combinations do not support virtual screens.
Refer to the appropriate driver\-specific documentation for details.
.TP 7
.BI "ViewPort " "x0 y0"
This optional entry sets the upper left corner of the initial display.
This is only relevant when the virtual screen resolution is different
from the resolution of the initial video mode.
If this entry is not given, then the initial display will be centered in
the virtual display area.
.TP 7
.BI "Modes \*q" mode\-name \*q " ..."
This optional entry specifies the list of video modes to use.
Each
.I mode\-name
specified must be in double quotes.
They must correspond to those specified or referenced in the appropriate
.B Monitor
section (including implicitly referenced built\-in VESA standard modes).
The server will delete modes from this list which don't satisfy various
requirements.
The first valid mode in this list will be the default display mode for
startup.
The list of valid modes is converted internally into a circular list.
It is possible to switch to the next mode with
and to the previous mode with
.BR Ctrl+Alt+Keypad\-Minus .
When this entry is omitted, the valid modes referenced by the appropriate
.B Monitor
section will be used. If the
.B Monitor
section contains no modes, then the selection will be taken from the
built-in VESA standard modes.
.TP 7
.BI "Visual \*q" visual\-name \*q
This optional entry sets the default root visual type.
This may also be specified from the command line (see the
.BR Xserver(1)
man page).
The visual types available for depth 8 are (default is
.BR PseudoColor ):
.PP
.RS 11
.nf
.B StaticGray
.B GrayScale
.B StaticColor
.B PseudoColor
.B TrueColor
.B DirectColor
.fi
.RE
.PP
.RS 7
The visual type available for the depths 15, 16 and 24 are (default is
.BR TrueColor ):
.PP
.RS 4
.nf
.B TrueColor
.B DirectColor
.fi
.RE
.PP
Not all drivers support
.B DirectColor
at these depths.
.PP
The visual types available for the depth 4 are (default is
.BR StaticColor ):
.PP
.RS 4
.nf
.B StaticGray
.B GrayScale
.B StaticColor
.B PseudoColor
.fi
.RE
.PP
The visual type available for the depth 1 (monochrome) is
.BR StaticGray .
.RE
.TP 7
.BI "Black " "red green blue"
This optional entry allows the \(lqblack\(rq colour to be specified.
This is only supported at depth 1.
The default is black.
.TP 7
.BI "White " "red green blue"
This optional entry allows the \(lqwhite\(rq colour to be specified.
The default is white.
.TP 7
.B Options
.B Display
subsections.
These may include driver\-specific options and driver\-independent options.
Some of the latter are described above in the section about the
.B Screen
.SH "SERVERLAYOUT SECTION"
.B ServerLayout
sections.
A \(lqserver layout\(rq represents the binding of one or more screens
.RB ( Screen
sections) and one or more input devices
.RB ( InputDevice
sections) to form a complete configuration.
In multi\-head configurations, it also specifies the relative layout of the
heads.
A
.B ServerLayout
section is considered \(lqactive\(rq if it is referenced by the
.B \-layout
command line option or by an
.B "Option \*qDefaultServerLayout\*q"
entry in the
.B ServerFlags
section (the former takes precedence over the latter).
If those options are not used, the first
.B ServerLayout
If no
.B ServerLayout
sections are present, the single active screen and two active (core)
input devices are selected as described in the relevant sections above.
.PP
.B ServerLayout
.PP
.RS 4
.nf
.B "Section \*qServerLayout\*q"
.BI " Screen \*q" screen\-id \*q
.I " ..."
.BI " InputDevice \*q" idev\-id \*q
.I " ..."
.I " options"
.I " ..."
.B "EndSection"
.fi
.RE
.PP
Each
.B ServerLayout
section must have an
.B Identifier
entry and at least one
.B Screen
entry.
.PP
The
.B Identifier
entry specifies the unique name for this server layout.
The
.B ServerLayout
section provides information specific to the whole session, including
session\-specific
.BR Options .
The
.B ServerFlags
options (described above) may be specified here, and ones given here
override those given in the
.B ServerFlags
section.
.PP
The entries that may be used in this section are described here.
.TP 7
.BI "Screen " "screen\-num" " \*qscreen\-id\*q " "position\-information"
One of these entries must be given for each screen being used in
a session.
The
.I screen\-id
.B Screen
section being referenced.
The
.I screen\-num
field is optional, and may be used to specify the screen number
in multi\-head configurations.
When this field is omitted, the screens will be numbered in the order that
they are listed in.
The numbering starts from 0, and must be consecutive.
The
.I position\-information
field describes the way multiple screens are positioned.
There are a number of different ways that this information can be provided:
.RS 7
.TP 4
.I "x y"
.TP 4
.BI "Absolute " "x y"
These both specify that the upper left corner's coordinates are
.RI ( x , y ).
The
.B Absolute
keyword is optional.
Some older versions of XFree86 (4.2 and earlier) don't recognise the
.B Absolute
keyword, so it's safest to just specify the coordinates without it.
.TP 4
.BI "RightOf \*q" screen\-id \*q
.TP 4
.BI "LeftOf \*q" screen\-id \*q
.TP 4
.BI "Above \*q" screen\-id \*q
.TP 4
.BI "Below \*q" screen\-id \*q
.TP 4
.BI "Relative \*q" screen\-id \*q " x y"
These give the screen's location relative to another screen.
The first four position the screen immediately to the right, left, above or
below the other screen.
When positioning to the right or left, the top edges are aligned.
When positioning above or below, the left edges are aligned.
The
.B Relative
form specifies the offset of the screen's origin (upper left corner)
relative to the origin of another screen.
.RE
.TP 7
.BI "InputDevice \*q" idev\-id "\*q \*q" option \*q " ..."
One of these entries should be given for each input device being used in
a session.
Normally at least two are required, one each for the core pointer and
keyboard devices.
If either of those is missing, suitable
.B InputDevice
entries are searched for using the method described above in the
.B INPUTDEVICE
section. The
.I idev\-id
field is mandatory, and specifies the name of the
.B InputDevice
Multiple
.I option
fields may be specified, each in double quotes.
The options permitted here are any that may also be given in the
.B InputDevice
sections.
Normally only session\-specific input device options would be used here.
The most commonly used options are:
.PP
.RS 11
.nf
.B \*qCorePointer\*q
.B \*qCoreKeyboard\*q
.B \*qSendCoreEvents\*q
.fi
.RE
.PP
.RS 7
and the first two should normally be used to indicate the core pointer
and core keyboard devices respectively.
.RE
.TP 7
.B Options
In addition to the following, any option permitted in the
.B ServerFlags
section may also be specified here.
When the same option appears in both places, the value given here overrides
the one given in the
.B ServerFlags
section.
.TP 7
.BI "Option \*qIsolateDevice\*q \*q" bus\-id \*q
Restrict device resets to the specified
.IR bus\-id .
See the
.B BusID
option (described in
.BR "DEVICE SECTION" ,
above) for the format of the
.I bus\-id
parameter.
This option overrides
.BR SingleCard ,
if specified.
At present, only PCI devices can be isolated in this manner.
.TP 7
.BI "Option \*qSingleCard\*q \*q" boolean \*q
As
.BR IsolateDevice ,
except that the bus ID of the first device in the layout is used.
.PP
Here is an example of a
.B ServerLayout
section for a dual headed configuration with two mice:
.PP
.RS 4
.nf
.B " Identifier \*qLayout 1\*q"
.B " Screen \*qMGA 1\*q"
.B " Screen \*qMGA 2\*q RightOf \*qMGA 1\*q"
.B " InputDevice \*qKeyboard 1\*q \*qCoreKeyboard\*q"
.B " InputDevice \*qMouse 1\*q \*qCorePointer\*q"
.B " InputDevice \*qMouse 2\*q \*qSendCoreEvents\*q"
.B " Option \*qBlankTime\*q \*q5\*q"
.B "EndSection"
.fi
.RE
.SH "DRI SECTION"
This optional section is used to provide some information for the
Direct Rendering Infrastructure.
Details about the format of this section
can be found in the README.DRI document, which is also available on-line at
.IR <http://dri.freedesktop.org/> .
.SH "VENDOR SECTION"
The optional
.B Vendor
section may be used to provide vendor\-specific configuration information.
Multiple
.B Vendor
sections may be present, and they may contain an
.B Identifier
entry and multiple
.B Option
flags.
The data therein is not used in this release.
.PP
.SH "SEE ALSO"
General:
.BR X (7),
.BR Xserver (1),
.BR Xorg (1),
.BR cvt (1),
.BR gtf (1).
.PP
.B "Not all modules or interfaces are available on all platforms."
.PP
Display drivers:
.BR apm (4),
.BR ati (4),
.BR chips (4),
.BR cirrus (4),
.BR cyrix (4),
.BR fbdev (4),
.BR glide (4),
.BR glint (4),
.BR i128 (4),
.BR i740 (4),
.BR imstt (4),
.BR intel (4),
.BR mga (4),
.BR neomagic (4),
.BR nv (4),
.BR openchrome (4),
.BR r128 (4),
.BR radeon (4),
.BR rendition (4),
.BR savage (4),
.BR s3virge (4),
.BR siliconmotion (4),
.BR sis (4),
.BR sisusb (4),
.BR sunbw2 (4),
.BR suncg14 (4),
.BR suncg3 (4),
.BR suncg6 (4),
.BR sunffb (4),
.BR sunleo (4),
.BR suntcx (4),
.BR tdfx (4),
.\" .BR tga (4),
.BR trident (4),
.BR tseng (4),
.BR vesa (4),
.BR vmware (4),
.BR voodoo (4),
.BR wsfb (4),
.BR xgi (4),
.BR xgixp (4).
.PP
Input drivers:
.BR acecad (4),
.BR calcomp (4),
.BR citron (4),
.BR dmc (4),
.BR dynapro (4),
.BR elographics (4),
.BR evdev (4),
.BR fpit (4),
.BR js_x (4),
.BR joystick (4),
.BR kbd (4),
.BR magictouch (4),
.BR microtouch (4),
.BR mousedrv (4),
.BR mutouch (4),
.BR palmax (4),
.BR penmount (4),
.BR synaptics (4),
.BR tek4957 (4),
.BR ur98 (4),
.BR vmmouse (4),
.BR void (4),
.BR wacom (4).
.PP
Other modules and interfaces:
.BR exa (4),
.BR fbdevhw (4),
.\" .BR shadowfb (4),
.BR v4l (4).
.br
.SH AUTHORS
This manual page was largely rewritten by David Dawes
.IR <dawes@xfree86.org> .[/spoiler]
![Изображение](https://img.sysadmins.ws/upload_image/694b49fc714586ebbaa8c737c6460870.jpg)
Re: проблема с мышем и клавай
Видюха какая?
Вот мой конфиг xorg от OpenSuSE 11,2
Тут тебе нужно будет изменить:
Все эти параметры можно уточнить в xorg.conf в твоем /etc от лайв CD
# SaX generated X11 config file
# Created on: 2009-08-04T04:03:56+0600.
# Version: 8.1
# Contact: Marcus Schaefer <sax@suse.de>, 2005
# Contact: SaX-User list <https://lists.berlios.de/mailman/listinfo/sax-users>
# Automatically generated by [ISaX] (8.1)
# PLEASE DO NOT EDIT THIS FILE!
Section "Files"
FontPath "/usr/share/fonts/misc:unscaled"
FontPath "/usr/share/fonts/local"
FontPath "/usr/share/fonts/75dpi:unscaled"
FontPath "/usr/share/fonts/100dpi:unscaled"
FontPath "/usr/share/fonts/Type1"
FontPath "/usr/share/fonts/URW"
FontPath "/usr/share/fonts/Speedo"
FontPath "/usr/share/fonts/PEX"
FontPath "/usr/share/fonts/cyrillic"
FontPath "/usr/share/fonts/latin2/misc:unscaled"
FontPath "/usr/share/fonts/latin2/75dpi:unscaled"
FontPath "/usr/share/fonts/latin2/100dpi:unscaled"
FontPath "/usr/share/fonts/latin2/Type1"
FontPath "/usr/share/fonts/latin7/75dpi:unscaled"
FontPath "/usr/share/fonts/baekmuk:unscaled"
FontPath "/usr/share/fonts/japanese:unscaled"
FontPath "/usr/share/fonts/kwintv"
FontPath "/usr/share/fonts/truetype"
FontPath "/usr/share/fonts/uni:unscaled"
FontPath "/usr/share/fonts/CID"
FontPath "/usr/share/fonts/ucs/misc:unscaled"
FontPath "/usr/share/fonts/ucs/75dpi:unscaled"
FontPath "/usr/share/fonts/ucs/100dpi:unscaled"
FontPath "/usr/share/fonts/hellas/misc:unscaled"
FontPath "/usr/share/fonts/hellas/75dpi:unscaled"
FontPath "/usr/share/fonts/hellas/100dpi:unscaled"
FontPath "/usr/share/fonts/hellas/Type1"
FontPath "/usr/share/fonts/misc/sgi:unscaled"
FontPath "/usr/share/fonts/xtest"
FontPath "/opt/kde3/share/fonts"
InputDevices "/dev/gpmdata"
InputDevices "/dev/input/mice"
EndSection
Section "ServerFlags"
# Uncomment the following option to reenable kbd/mouse driver input sections.
# Otherwise evdev driver is used.
#Option "AutoAddDevices" "off"
Option "AllowMouseOpenFail" "on"
Option "ZapWarning" "on"
EndSection
Section "Module"
Load "dbe"
Load "type1"
Load "freetype"
Load "extmod"
Load "glx"
EndSection
Section "InputDevice"
Driver "kbd"
Identifier "Keyboard[0]"
Option "Protocol" "Standard"
Option "XkbLayout" "us,ru"
Option "XkbModel" "microsoftpro"
Option "XkbOptions" "grp:ctrl_shift_toggle,grp_led:scroll"
Option "XkbRules" "xfree86"
Option "XkbVariant" ",winkeys"
EndSection
Driver "mouse"
Identifier "Mouse[1]"
Option "Buttons" "5"
Option "Device" "/dev/input/mice"
Option "Name" "ImPS/2 Generic Wheel Mouse"
Option "Protocol" "explorerps/2"
Option "Vendor" "Sysp"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
DisplaySize 304 228
HorizSync 30-85
Identifier "Monitor[0]"
ModelName "ACER ACER FP559"
Option "DPMS"
Option "PreferredMode" "1024x768"
VendorName "API"
VertRefresh 50-85
UseModes "Modes[0]"
EndSection
Section "Modes"
Identifier "Modes[0]"
EndSection
Section "Screen"
DefaultDepth 16
SubSection "Display"
Depth 15
Modes "1024x768" "1024x600" "800x600" "768x576" "640x480"
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
Depth 8
EndSubSection
Device "Device[0]"
Identifier "Screen[0]"
Monitor "Monitor[0]"
EndSection
Section "Device"
BoardName "ProSavage DDR-K"
BusID "1:0:0"
Driver "savage"
Identifier "Device[0]"
Screen 0
VendorName "S3"
EndSection
Section "ServerLayout"
Identifier "Layout[all]"
InputDevice "Keyboard[0]" "CoreKeyboard"
InputDevice "Mouse[1]" "CorePointer"
Option "Clone" "off"
Option "Xinerama" "off"
Screen "Screen[0]"
EndSection
Section "DRI"
Group "video"
Mode 0660
EndSection
Section "Extensions"
EndSection
Section "Device"
BoardName "Имя твоей видеокарты"
BusID "Айдишник твоей видюхи"
Driver "драйвер"
Screen 0
VendorName "Производитель"
EndSection
Section "Monitor"
DisplaySize здесь подставь параметры поддерживаемые твоим монитором
HorizSync здесь подставь параметры поддерживаемые твоим монитором
ModelName "Модель твоего монитора"
Option "DPMS"
VertRefresh здесь подставь параметры поддерживаемые твоим монитором
UseModes "Modes[0]"
EndSection
Значит в секциюBaHbKa писал(а):nvidia FX 5200
прописываешьRaven писал(а): Driver "драйвер"
Driver "nv"
